Question about LG 32LD450 32 In. LCD HDTV
Cant get sky code so sky remote wont turn sound down
  • 476 Answers
Hello Heidi, you will need the brand and model number for your TV when you click in to sky.com. after you do you might have to sign in or register if you haven't done so. Then click on watching sky, then remote control help, this will take you to the find your code, this is where you'll need the model and make for your TV.
Posted on Jul 28, 2010
I need a code for a ue40d5oo0
on ur sky remote,,
  1. Switch on the TV set
  2. Press the TV button on the Sky Remote
  3. Hold down the Select and Red buttons for 2-3 seconds until the LED blinks twice
  4. Enter the digit code - 0646
  5. Press the Select button to store
  6. then press tv and check the volume if it works on sky remote..
    if u still cant do it go to
    http://www.skyuser.co.uk/tools/remotecodes/index.php
May 05, 2012 | Samsung Televison & Video
I have a 30" Targa Visionary TV, model LT 3020. I cannot find a code to make it respond to the latest, rev 9 (or older) Sky Remote.
you will have to ask for the sky operator for the code sir.
mostly there wont be any code. just ask him if you need to change some settings to make it respond.
Aug 02, 2008 | Televison & Video
I cant get sky to work on my LG plasma tv
Hello
Codes to check for LG with Sky are;
065 244 405 318 037 398 191 459 245 389 080 275
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions
Mar 12, 2011 | LG 32LH30 32 in. LCD HDTV
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Looking for code for sky remote for television
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
sky.com/portal/site/skycom/skyhelpcentre/producthelp
also check the below link -
Good Luck!!
Jun 14, 2010 | Televison & Video
Need the sky remote code for bush s626d lcd tv. cant find it anywhere!!!please help
The Sky engineer told me that there wasn't a code for this model TV but thanks to the guys at:
http://genuinecopies.tv/skyCodes.asp?brand=bush&model=s626d
I was able to find it the code is : 206
This was for a REV Ver 8 Sky remote.
Their code finder should work for other models too.
Feb 28, 2010 | Televison & Video
Cant get code for 40 inch evotel to work sky plus
I've tryed all the codes I can find and still nothing!
Feb 05, 2010 | Televison & Video
I NEED A CODE FOR SKY REMOTE
Hi.
Here available codes for Sky Remote: sky remote codes
Nov 05, 2009 | Televison & Video
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Sky code for a goodmans gtvl19w17 hdv
Try this : Turn TV on, point remote away from TV, press TV button on your SKY remote...hold down SELECT and the RED key together for about two seconds, until the red light (LED) on the remote blinks twice...key in the remote code for your model of TV on the remote keypad ( for Goodmans, try 065, or 0335 ) then press SELECT button ( the LED should blink twice to show code accepted ) press SKY button to exit. point remote at TV and test.....Job Done . !
Nov 19, 2007 | Goodmans W280NS Television
LG 32LD450 32 In. LCD HDTV Logo
189 people viewed this question
