How do I connect a microphone with a 1/4" cable to my AV receiver with RCA connectors
  • tenemoh Apr 24, 2008
    I tried that but it didn't work.
    Sergeant:
    Champion:
  • 319 Answers
You can purchase adaptors at Radio Shack
Posted on Apr 24, 2008
  • Van Lake Apr 25, 2008
    Microphones require a high gain input -- higher than AUX, or other low gain inputs. You might try the the phono input. Depending on the mic, professional high impedance mics will work with phono input
How do I hook up my iphone 5s to my Onkyo TX-8511
You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1 . Connect from the headphone port of the iPhone and use the red & white RCA audio cables to connect into the RCA audio input terminals of your TX-8511.
Jan 02, 2015 | Onkyo TX-8511 Receiver
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
I have bought a 5.1 home theater with an av receiver and i want it connect to my computer. So how should i connect it ?
Just find the output of the computer's sound card and it should have a microphone style female connector that you plug a male connector into. The other end should have rca phono jacks that can accept stereo or left and right 2.1 connections. If you want 5.1 home theater from this signal, it may be possible or may not be possible depending on the input of the 5.1 home theater system.
Aug 19, 2010 | Computers & Internet
I need to set up my TV (without HDMI), amplifier, dvd recorder and Skybox so that I get the best sound - so using the amplifer.I really need a diagramatic picture
No diagram needed: just connect the video RCA connector (yellow) from the player and the box to the tv using 2 separate cable plugged in separate AV entries, and the audio RCA connectors (white and red)  using 2 separate audio cables to 2 RCA joiners like http://www.amazon.co.uk/Euronetwork-RCA-phono-adaptor-Gold/dp/B000ENC20E
and plug those in the audio connectors of the amplifiers - keep the same color all the way.
Jul 24, 2010 | Yamaha Televison & Video
Connecting cable to receiver
Do you mean 5 RCA audio outputs marked as FrontLeft, FrontRight, RearLeft, RearRight, Center? Unfortunately this receiver doesn't have discrete 5ch inputs (as yamaha calls it on its webpage).
But the cable box should have also digital audio SPDIF output - that is either optical (square connector) or coax (RCA usually orange). You can use this for connecting to receiver.
Mar 07, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Can I connect component av cables "in" to my Yamaha RX-V365 and connect "out" to my TV and get both audio and video?
Receiver does support 3x component inputs and one component output. Both these can carry only video signal, not audio. So you have to connect audio separately, either stereo via analog 2x RCA connectors and digital SPDIC via optical (2x) or coaxial (1x) cable.
Feb 23, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Microphone for my YAMAHA HTR-5440
Let me make this clear to you that your Yamaha does not support Microphone but the trick is you can still do it. All you need is a stereo jack to a RCA connector cable.Check this out http://www.mediacollege.com/audio/connection/jack-stereo-rca-2.html It is easily available in the market. The stereo jack will fit into your microphone and the RCA to your Amplifier/Reciever. Plug the RCA into CD/Tape input but not in the Phono n do your thing. Let me know if this works,coz I'm really curious.
Jun 02, 2009 | Yamaha HTR-5440 Receiver
Sub digital coax connection
You will need to get a y connector and split the sub out signal between the one it came with and your additional sub. The connector you need is an MFF, (1-male, 2- female) RCA type.
Good Luck,
BB
Jan 06, 2009 | Yamaha HTR-6130 Receiver
Set-up wireless karaoke Mic.
I can't seem to find any technical details on the output specifications of the karaoke mic, but IF it outputs in consumer standard RCA format (a cable with two ends, one red and one white - often seen with a third yellow cable for video), then you should be able to plug it into the back of the receiver without trouble. Simply choose one of the audio connectors in the back to function as your microphone playback system - I suggest the DBS connector, unless you have a satellite system already plugged in.
Connect the Red RCA cable to the RIGHT channel port on your receiver and the White RCA cable to the LEFT channel (Red = Right). Now, select the DBS (or whatever port you plugged it into) using your receiver remote control. Hit the "ANALOG/DIGITAL" button on the remote until "ANALOG" mode is displayed.
If you want to connect the mics to a Karaoke system using the same receiver, simply unplug the White RCA cable from the Microphones, and plug in the White RCA cable from your karaoke device. Now, you'll get music playing from one side of the speakers, and mic playback from the other side, simulating the karaoke experience.
NOTE: If the microphones do not have a RCA plug on the back, please post a picture of the reverse of the Microphone receiver, and I will see what I can do to help you further.
Dec 28, 2007 | Trident JT-306A Microphone
Connecting a Yamaha VX7 Subwoofer on my Yamaha HTR 5730 AV Receiver
Hello srqwrk,
You can connect the VX7 to the 5730 using an RCA Y cable like the one shown in the picture below. You get your one connection for the receiver and 2 for the VX7. These are available at any electronics store. Remember that the cable should be long enough to go from the receiver to where subwoofer will be placed.
Hope this helps. Let me know.
cancerags
Nov 26, 2007 | Yamaha HTR-5730 Receiver
52 people viewed this question
 Grubhead
Grubhead
