My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv remote sensor.Had the same problem about 1 year ago.Sometimes i could program the remote and sometimes it wouldnt work.Than suddenly it started to work until now.
  • mariusz1492 Jul 28, 2010
    could take the back panel of my 65" toshiba cinema series tv myself and reset the remote sensor or shoul i call tv technician
  • 736 Answers
I can advise some basic remote troubleshooting. Try this first:
Turn off and unplug your television. Take the batteries out of the remote control that came with the television. Aim it at the remote sensor. Press and hold down the power button for 30 seconds. Press and release every button on the remote control twice. Plug the television back in and power it on. Put the batteries back in the remote control. Attempt to adjust the volume + and -. If this doesn't work try these steps.
Replace batteries in the remote control, gently with a microfiber cleaning cloth, wipe the IR sensor. You may want to lightly dampen the cloth with a light mist from a spray bottle.
Cover the ir sensor with a piece of electrical tape.
Look at your television's environment. What type of environmental interferences are there such as alarm system, other items in the room that function with remotes, (remote controlled fans, remote controlled lights, DVD/DVR/Cable Box/Satellite Box, Stereo), fluorescent lighting (includes the energy saving CFL bulbs), sunlight, smart house (sensor controlled lights and heat) or power lines by the house. Move sources (DVD/DVR/Cable Box/Satellite Box, Stereo) to another area of the room, not in the same IR path of the set.
Compact Fluorescent Light (CFL) bulbs are known to emit certain amounts of infra red radiation that can potentially interfere with electronic devices that use IR remote controls. Using CFL bulbs in sockets connected to a dimmer can result in occasional “pulsing” of light, even when the light switch is turned off. These IR pulses can be confused by the TV as IR commands and can potentially lock up the set. Use normal Incandescent bulbs
Move the TV away from CFL light sources
Try different CFL bulb brands. Professional Installers have recommended “Bright Effects” CFL bulbs available at Lowes for low amount of interference.
IR repeaters and some PC controlled IR transmitters can interfere, and should not be placed in or directed at the IR path of the set.
Lastly if possible move the set to a different room and see if you are still having the same problem.
If none of this applies then replace the ir sensor.
Posted on Jul 28, 2010
  • 11,800 Answers
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
    after I take the back panel of is it easy to get to the sensor connections or should i have repair technician do it ?
  • Azrael SRL Jul 28, 2010
    Quite easy to get to them and check them, you don't need a technician, they're just wires plugged on the motherboard. But the solderings of the wires, if they are damaged, must be done by somebody who has this stuff before. If you haven't then yes, it's time to call one.
  • 10,594 Answers
Remote sensor would be located at front of tv so front panel will be removed to replace remote sensor. TV repairman will do the job for you in safe manners, novice could damage some thing while removing front panel.
Call tv repairman to get tv fixed.
Thanks.
Posted on Jul 29, 2010
Toshiba 32A43 - suddenly stopped responding to both my Toshiba CT-90157 remote and Verizon FIOS Philips RC 1445301 remote. Replaced batteries in both remotes & tried to reprogram the Verizon remote...
hi
this kind of problem is usely comming from one of the front panel button if so the set will show the menu intermitently and no action from the remote. What i use to do i replace
all of the tack switches 6or 7 but i would suggest to consult your local tv repair shop if
you do not have some kind of experience.
Sep 28, 2010 | Toshiba 32A43 32" TV
1988 KAWASHO TV: Need remote control codes for VERIZON FIOS Remote Control
You may want to try a different universal remote, like the Logitech Harmony.
Apr 07, 2008 | Onkyo TX-SR605 Receiver
TOSHIBA 36AF42
Your Fios box seems to be faulty
Mar 29, 2008 | Toshiba 36AF42 36" TV
No codes for remote verizon fios control of tv came with tv or are listed for RC1445 302/oob manual
for my tru-tech i used the auto code finder on the Fios remote instructions it didn t take very long, I can t say the same for my memorex tv though.
May 10, 2009 | TruTech PLV1615T 15 in. LCD Television
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
NEED REMOTE CODE
Go on the Verizon website and request a new remote, the Verizon P265 Remote model. It will have all the newest firmware and it should have the code. I know this because I had a TCL 32" TV and the code wasn't on my old Philips RC 1445302 model. TV and new remote are "talking" just fine now. Verizon won't even want the old one back.
Dec 05, 2008 | Universal Remote Control Remote Control
FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Code for Verizon FIOS remote Control
Code 1292 worked like a charm for me!
Vizio SV421XVT
Dec 11, 2007 | Televison & Video
Televison & Video Logo
274 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
