Question about Vintage Keeper Koolspace Wine Cellar
The temperature continues to flucuate between 66 and 85 then alarm sounds ( can only hear if you open the door) I unplug for a few minutes then seemd to be ok for awhile.has been doing thie for a few weeks but yesterday 4 times. HELP
  • 360 Answers
Hi, you need to check if the compressor is running or not.The alarm is sounding because the temp is under the reqd. set point. If it is running continuously, then you either have a blockage in the system or there is a leak in the system. Quick check for a possible blockage which is repairable is to feel the small pipe on the compressor and see if it is hot or cold. If cold, there is possibly a leak. If hot, it could only be a blockage which can be repaired. Another very possible cause is simply the evaporator fan motor is not running.
Take care
Posted on Jul 28, 2010
Www frigidaire com
Hello Friend, this is Z. Thank you for your post!
I see that your question is listed under Frigidaire refrigerator (FPRH19D7LF) and that the alarm is sounding. First, did your refrigerator previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your refrigerator by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your refrigerator. After deactivating the alarm and your refrigerator has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your refrigerator may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. Best!
Sep 03, 2014 | Frigidaire FPRH19D7LF
My refrigerator has a temperature alarm that keeps sounding every few minutes, how do I reset it the alarm?
Hi Friend, that's a great question!
The alarm of your Frigidaire refrigerator may typically be reset by either unplugging it or flipping the household circuit breaker. It is good to wait roughly ten minutes and then turn on your refrigerator. After deactivating the alarm and your refrigerator has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your refrigerator may possibly be experiencing a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend reaching out to a professional to proceed further. Best - Z
Aug 16, 2014 | Frigidaire Refrigerators
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Door ajar light will not go off
Good Morning Friend, thank you for your inquiry!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. It is best to wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Best regards! - Z
Jun 14, 2014 | Frigidaire FKFH21F7HW Freezer
LG LFC21760ST Beeping Constantly again. Last time it cost me a fortune to replace the computer board. Isn't there a cheaper way to stop the sound?
I would suggest starting with the easiest troubleshooting tip first. Try unplugging it for 10 minutes and plugging it back in. Most (modern) appliances will reset to factory defaults when they are unplugged for a few minutes.
May 29, 2014 | LG LFC23760SB Three Door French Door...
Door left open for about 90 mins on freezer now red alarm light is on all the time?
Good Morning Martin, thank you for your post!
If the temperature of food rises to an unsafe level, the red light will glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Oct 04, 2013 | Frigidaire FVE145FF Upright Freezer
I cannot change the temperature on my Maytag MFC2061HES. Whenever I try to change either the refer or freezer temp, it creeps back down to 33 with the freezer going to 6. I cannot turn it off. The...
It sounds like your fridge has problem with the damper stuck open. The damper is in the top-back-center of the fresh food section. I can't tell by the pics I have how to get to it, but looks like it's simple to get to it - just remove the damper cover.
Check the damper for the ice buildup. Clean if needed. Unplug the fridge and check continuity on damper motor. Replace damper if no continuity.
Check the microswitch on the damper assembly. C on switch [where it connects to black wire] should make contact with NC [yellow/red] when button is not pressed, and C with NO [blue/red] should make contact when button is down).
With temp in the fresh food section so low, the damper should be closed, and if it isn't there should be power (110v ac) coming to the motor either continuously until it closes or for a short period of time within a few minutes after you try to set the temperature, can't tell by schematic. Unplug, connect your DMM in "volts ac" parallel to the damper motor (red and green/yellow wires), and plug fridge back in. If it does not show 110v immediately, set the DMM to show the maximum voltage registered, and leave in the fridge for 20-30 minutes, with doors closed. If there was 110v, and the damper is still open - replace damper. Otherwise it's very likely that the control board failed.
Parts:
Damper assembly: 67003903
Control board: 12782036SP
If you order from that site, use "New10" coupon code for 10% off.
Oct 25, 2009 | Maytag MFC2061HES Stainless Steel French...
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Vintage Keeper Koolspace Wine Cellar Logo
Top Vintage Keeper Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
Are you a Vintage Keeper Furniture Expert? Answer questions, earn points and help others
