Question about Dell E172FP 17" LCD Flat Panel Monitor
My e153fpb monitor went dark
I have a dell desktop with a e153fpb monitor ... it was working fine then all of a sudden something happened and the screen got very dark it looks like it is not on but it is if u get really close u can see it is on but anyother way it is so dark it looks like it is turned off i tryed to fix the contrast and brightness of the monitor but it is not helpin much.... how can i fix the screen so i can see it
Khanesbabigirl09@aol.com
    Problem Solver:
  • 3 Answers
Try resetting the monitor to default settings by getting your manual out. It will guide you through the process. If that does'nt work then check for any updated drivers.
Posted on May 03, 2008
Screen is too dark. Have trying the auto adjust, itsn't helping.
Auto adjust would retore the screen to what is usual of the Tv not the users expectations. Usimng the brigtgness contrast buttons to control a picture quality accustomed.
Jan 29, 2011 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
The Dell E153FPb monitor works, but has a very dark screen. the picture is not clear at all, but i can see a small portion of it as if a bulb may be out.
Hello Breon, hi, most likely that the LCD back light is going bad, or the inverter board is giving up, or could be loose screws, this needs to be checked and diagnose.
Sep 20, 2010 | Dell E153FP 15" LCD Monitor
I have a Dell computer with a flat screen now all of a sudden there are fine pink verticle lines along the right side of the screen. There is also a group of fine pink verticle lines about 1.5 inches wide...
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer.let me know if this resolves ur issue.. if not then we need some other steps.. regards,guru
May 05, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Monitor problem
It sounds as if the backlights are failing. It is probably cheaper to replace the monitor than anything.
Feb 18, 2018 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Dell monitor E152fpb
The orange light means that the moitor is not seeing any signal. Make sure that the cable is in the correct position on the PC. If that is correct, try it on another PC to determine whether or not the monitor was damaged internally during moving or the PC is not sending out a video signal.
Dan
Mar 20, 2008 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Screen not working
there is a problem with the degausing coil of the monitor. just open the case and try to clean the degausing coil. thx jsut vote for me so that i can help u better.
Aug 29, 2007 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Dell E172FP 17" LCD Flat Panel Monitor Logo
360 people viewed this question
Alun Cox
