Question about Garden
My murray riding mower would not start, does not make any sound when ignition switch is on
It is probably a safety switch. The model i own has two switches - one under the seat and one underneath along the frame. Find them and tape them so the button is pushed then try to start it. If that doesn't work it will probably be the ignition has gone bad.
Posted on Aug 11, 2010
Why murray riding mower wont crank when being jumped off
Some mowers have safety switches that unless you are sitting on the seat and the clutch pushed in they will not start. Not sure if this is the answer.
Jan 05, 2017 | Murray Garden
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
How do you check a ignition switch on a murray riding lawn mower to make sure it is operating properly?
You will need a multimeter... then you will need to check each wire port to see if voltage is registering . I would also disconnect the safety switch under the seat or.. plus put the emergency brake on as well... anything and all that will stop the engine from getting the signal to the coil to start up..
Nov 01, 2015 | Murray Garden
How do I fix my Murray riding lawn mower? The motor will not fire;
coil,safety switches,ignition switch,fuse,connected wrong,,,choose 1 to eliminate then go to the next,etc,,,etc,,
pull the black wire off of the coil,try to start,if it works,the safety switches(1 or 2 or 3 out of 3)are bad,seat,brake/clutch,deck switches,if not,then the coil is bad,pull the ign switch out,clean all contacts on back and plug back in
May 25, 2015 | Murray Garden
Murray 21hp/46
Sounds like a micro switch issue shutting the engine down, start by checking the seat switch, make sure the connecter is pushed well in.
Mar 12, 2012 | Murray Garden
Murray ridinglawn mower will not start..everything is new
sounds like you have a safety switch issue, i am the proud owner of 3 different Murray mowers, you have a seat switch, a blade disengage switch, and a clutch pedal switch, depending on model and year, unplug one at a time and re try, need anymore info, email me, niteman87@aol.com :) hope that helps,
May 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a 1983 Murray riding mower, I need to know the ignition wiring diagram. There's a yellow ignition switch and I don't know where it goes to. There's also a single wire that comes out from the front...
With the model number, you can obtain a users manual. I viewed their sample and it included the wiring diagram... SWEET!
Here is the link for your manual:
http://www.outdoordistributors.com/Murray/Murraypartslists.html
Hope this helps... Good luck!
Sep 22, 2009 | Garden
Murray riding mower motor wont turn over it just clicks
Clicking sound tells you the solinoid is working. There are several possible things causing it not to start. Check the following: Safety switches on the clutch, seat and deck lift handle. If any of these are not making contact, as in the button not pushing all the way in, the mower will not start.
If the safety switch on the deck lift is worn you might try pulling this handle futher back while trying to start the mower. This may work.
Check the key ignition to be sure the prongs on the back have not rusted. If they have and you know the switch is good try taking a small metal brush and clean the prongs.
A good small engine repair shop should be willing to check the ignition switch for you to see if it is good. P.S. If the solinoid was clicking to begin with before you replaced it then it was good and not the problem to start with.
Jun 23, 2009 | Garden
I have a 1993 murray lawn tractor 12.5hp Ignition Switch????
Take an ohm's and amp. meter and go to the ohm's setting and see which terminals are off and on. If you want to kill the engine put it on the off side. If you want to run anything put it on the start and run side of the switch. Hope this clears things up a bit. donnyb60.
Mar 24, 2009 | Garden
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Sep 06, 2008 | Garden
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
