What is the wattage output for speakers on a ax 3030r
2 Suggested Answers
marsrover
  • 682 Answers
SOURCE: POWER OUTPUT OF A SHEERWOOD AMP MOD NO AX-4050Rwhat
100watt-rms.
Posted on Apr 26, 2008
Having trouble under standing rms with speakers. Some speakers rms is per speaker and other are for both speakers.I am looking for soundstream speakers that would be 150 rms per speaker. Thanks
rms is a method of measuring power (wattage) delivered from an amp to a speaker. In almost every case, wattage capacity of speakers is quoted PER SPEAKER. Likewise wattage output is quoted per amp output channel. Assuming a you plan on a single speaker on each output channel of your amp, you should be in good shape if your speaker wattage capacity equals or exceeds your amp's output rating. I've never seen speakers rated as wattage per pair.
(rms is the dominant way of measuring average watts of an ac sine wave signal)
Apr 23, 2017 | Car Audio & Video
Output wattage of sony speaker system model ss-cfx250
Passive speakers don't have an output wattage rating, that would be applied to the amplifier :-) The INPUT wattage rating of these speakers is 5 watts RMS per speaker.
Jul 14, 2014 | Sony Audio Players & Recorders
Sherwood ax 3030r
What is the question? More information is needed before somebody can help you. What type of watts are you asking, power input, output, music, RMS, etc.
May 14, 2014 | Audio Players & Recorders
I want to connect YST-Sw1500 sub woofer to the AX-596 amplifier .How can I do the connections .
on ur subwoofer u will see HPF output, connect this output to MAIN IN of ur power amp (first remove jumper between pre-out and main in from ur power amp) connect pre-out of ur power amp to input 2 L&R (Left is also for mono input). the HFP selector switch will cut off 80Hz or 100Hz to the main input depending on the position enabling u to have high frequency sound on your main speakers. connect the speakers to the main output terminal of ur power amp. do not connect speakers on the woofer ouput.
make sure u are using the right impedance speakers. do not switch speaker impedance selector while the unit is on.
Apr 04, 2010 | Yamaha AX-596 Amplifier
Says overload
Your speakers may be underpowered by your receiver. Check the watts and impedance of the speakers, and the wattage of your receiver to make sure they closely match. (impedance is calculated in ohms- indicated by an omega symbol written near the wattage rating)
"Overload" may also mean that the amp went into protect mode, and that means that you're OVER-powering your speakers and it wants to protect them from damage due to impedance mismatch.
But- if the impedance and wattage match between the speaker and the receiver/amp, you should check the polarity of the speaker cables (+/-) BTW- never put 2 speakers in 1 output- that will almost always cause something like this and will sound bad.
I hope this helps.
May 31, 2009 | Technics SA-AX540 Receiver
Convert passive speaker to active
You don't say anything about your passive speaker, only thing that I understand you have a Yamaha AX-396 witch have an Power output of 60 watts per channel into 8 ohms (stereo)! That means working great with your passive speaker!!!
Apr 27, 2009 | Yamaha AX-396 Amplifier
SHOULD I USE A B TERMINALS TO BI-WIRE ONE SET OF SPEAKERS N MY YAMAHA AX-496 AMP?
No,i've only wanted to know if I would be able to connect A+B to 1 set of speakers in BI-WIRE mode,A+B meaning output A(left,right),output B(left,right)
Apr 28, 2008 | Audio Players & Recorders
170 people viewed this question
 Grubhead
Grubhead
