Question about LG WM-2277HW Front Load Washer
"OE" code cleaned all drain's,trap's and hoses. Took pump out tested it in sink worked fine no problems with pump. Re-installed pump same problem. Now what?
  • LG Master
  • 8,220 Answers
Well now how does the washer KNOW it took more than 10 minutes to empty the water? On the main control panel is a small hose connectect to a pressure sensor device. The control monitors this water pressure so when it drops the resistance changes and the control then thinks the water is gone. Remove the small hose and blow the sediment out of it. That is all it might take to get that dog a washing again. Let me see now. How does the washer know exactly how much water has entered into the machine and how does it know to put so much water and no more in there? Aha! The little tube going into the control is one thing it uses and another thing is a device which changes in resistance when
weight changes motor amp draw. When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water level frequency should be above 246. If it be below that number find the small tube going to the control and blow it out. Get rid of the sediment in the air bell and reconnect tightly. Pump out water and retry.
Rate it or Hate it:
WM2277HW REPAIR MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 28, 2010
  • walk_n_iron6 Jul 28, 2010
    OK did what you asked still no drain so I took the pump back off and took it apart and to my suprise there was a finishing nail stuck in the impeller. So when I took it out last time it msut of moved over and let the pump move freely, but when I put it back in it went right back into the impeller.
    All is well now and the wife is happy again thanks for the help.
    Troy,
  • Dan Webster
    Dan Webster Jul 28, 2010
    Glad ye could get er done. Thank you
I have a code that says OE what is that
OE means the machine has sensed slow to drain condition.Check out website below,
Most likely food debri in drain hose.or air gap.
Disconnect drain hose from sink and blow a little compressed air into it to shake things up.Run a rinse and drain with hose disconnected into bucket to see whats going on.Trap on sink may be restricted as well.
Hope this helps
http://lgknowledgebase.com/rms/kb_frame/
Aug 18, 2011 | LG LDS4821ST Stainless Steel 24 in....
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
I'm getting an OE code on my LG washer and I have cleaned the hose and filter and that is not working, I can hear that the water is not draining throgh the hose in the back, What can I do?
The OE as you know is a drain error.
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
You probably gonna need to get into that puppy and take the pump apart for the cleaning.
I have service manuals for LG HERE
Apr 02, 2011 | Washing Machines
I unscrewed the lower panel on the front and cleaned out the large black round cap on my LG Tromm Washer. I blow thru the small rubber hose and it sounds clear. I am still getting the OE when getting to...
As you know OE is drain error. you still have a drain problem and this could be because the pump impeller has a coin or similar jamming it, or it could be that the pump motor itself is failing. If the drain hose is clear and not kinked and the pump is working the machine should drain........Good luck....Nomess
May 27, 2010 | LG WM2688HWM TROMM SteamWasher
LG WM2075CW
Drain error= Not fully drained in 10 minutes. Must be a problemo with the pump or possibly the drain is slow? clean out that filter. Check that pump for objects. THIS will help.
May 22, 2010 | LG WM-0532HW Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Error Code OE and Door will not unlock
error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.try running the spin cycle alone till the water empties completely.If the problem still continues it means that the pump is clogged where you cant reach, since you've tested with the drain hose.
Dec 16, 2008 | Washing Machines
LG tromm front loader OE
All of the ways to solve this problem are right on--take the filter out (in front on the bottom left when facing the machine). Before you do, take time to drain out the water with the hose below. Once drained open the filter and clean out. Try on speed wash with no spin. Nine minutes in you will know if the drain works. If not, turn on side and remove the washer pump. To do this, remove the hoses first starting with clamps. Then remove the three screws in front where the filter is. It easily comes out. The top pump is the drain pump. First mark the wires--blue is positive and black is negative. Remove the pump and clean out.The pump comes out of the casing. Try removing this and cleaning. If you have a power source, test the pump. If works, put back and start in fast cycle with no spin. If not, then you have to replace the drain pump. You will not find anyone in town the has the pump unless you live in New York or Dallas Texas. To get the pump at a reasonable price and expedited call and order through Sears at 18004881222. These guys are good and well get it to you as promised. The entire job once recieved the pump took about 30 minutes. Also, saved about $100 in labor. Good luck and hope this helps...
Aug 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Intermittant 'OE' error code
OE means it has not fully drained with in 10 minutes. Check your button trap and make sure nothing is there. If you want, make sure there is nothing in the unit and you can put it into test mode and check out to see if the drain pump is working.
Sgt 48
Jun 01, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
42 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
