Question about Frigidaire FGF316 Gas Kitchen Range
Burner flame size
I have a 2001 model frigidaire Gallery gas range that was converted to propane. The flame size on the range top burners, particularly the large diameter burner is too small. It takes forever to boil a pot with a gallon of water. Can the flame size be increased? It looks like there is an adjustmant device at the back of the stove, accessable from the front if you pull out the bottom drawer.
ngfam1
  • 639 Answers
SOURCE: burner will not turn off
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
UH OH, This is dangerous !
Waste no time and call factory service!!!!!!!!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
barkencoa
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
DeBruce
  • 145 Answers
SOURCE: stains on the stove-top
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Posted on Aug 24, 2009
mark24354
  • 776 Answers
SOURCE: top burners are propane. we are used to propane
If it is new fromt the factory, you many have the natural gas (methane) jets in the burners. You will need to check your bag of parts to find the propane parts (LP parts). LP jets allow a different fuel/air mixture to burn at the right heat. Check the owner's manual for details how to make the change.
Please rate me - Good luck.
Posted on Nov 20, 2009
SOURCE: stove top flame is small, it takes forever to boil
number one is this a problem you have had for a while or is it slowley decresing is it just one element or all one thing you can do is to take a dipper pin or a needle stick it through the orifice what your trying to do is to clean out some of the debre that collects a that tip dont try to inlarge the opening just try to clean it out if that does not work there is a gas flo adjustment but call around and see if some one with knowlege can help u over the phone gas adjustments can be dangerious
Posted on Apr 12, 2010
Oven flame is to high. How do I fix it?
You have selected an electric range, what is your true gas range model number?
Aug 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
Fridgatare modle #FGG3054KFB I have a frigidaire range that has been converted to propane. When the oven is turned of it has a strong propane smell and there is alot of moistier inside. The flame is about...
It shouldn't be burning yellow and emitting soot at all;sounds like on of these possible causes-
(a)blocked burner airways(this can lead to yellow tipping and sooting on LPG powered appliances because insufficient air is getting through to the burner causing it;you can also get this effect on LPG barbecues say if dead insects or spiderwebs are in the burner pipes and airways after a period of storage),
(b)incorrect aeration being set when the burner was converted using LPG jets(too much gas and not enough air causing yellow flames/smells and sooting),
or (c) if you use propane cylinder gas a dicky or faulty regulator. I would get it looked at investigating all the possibilities I mention and taking action to correct this where necessary ie clearing the burner airways(if this is causing your problem), adjusting the aeration in the burners until you get a clear noiseless blue flame without any excessive yellow and sooting(but even after good adjustment you may find still get a very slight yellow tip without sooting at the top of the flame;this does happen with propane gas and there is a slight tendancy for this to happen more often with butane-butane tends to display very slight yellow tips on ignition increasing slightly as the burner warms up to full temperature) or if you use propane cylinder gas replacing the regulator if that is necessary.
Nov 22, 2010 | Frigidaire FGB24S5A Gas Single Oven
I have a Frigidaire Stove, Model # FGF316ASA. It was changed from propane to natural gas. The oven works well. The burners, however, will only burn a low flame. Is there a solution for this?
When converting an appliance from propane gas to natural sometimes a technician will drill the orifice to a larger size rather than replace the orifices. Either way is fine, but sometimes the orifices don't get drilled to the correct size. The regulator must be on the propane setting if it is a convertible regulator. If your oven is working fine.... the top burner orifices probably need to be checked that they are the correct size. A simple fix.
Tom
Aug 11, 2010 | Frigidaire FGF316 Gas Kitchen Range
79012 / 79014 / 79019 Gas Kitchen Range: The propane converson seems to be done right, howe...
It sounds like during the conversion process a step or two may have been missed.
The gas orifice for the main oven burner is most likely to large (was not converted to LP), or the air shutter on the burner was not adjusted. I would not use the oven with the flames that way.
There should be instructions with the installation instructions on how to convert the oven, basically on most oven burners the orifice is screwed down (tightened) until the flame is the right size, then the air shutter on the burner is adjusted for a blue flame.
Let me know if you have questions
May 05, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The southbend 436d range gives a yellow flame at the burners
Hello. Please advise if your unit is supposed to run on propane, at the bottom of the oven door is a smaller panel, depending on age, it either lifts slightly, and then folds down, or clearly has screws on the front. Your Model/rating plate is behind this, either on the back of the panel, a tag screwed to the frame, or on the bottom ledge of this area. It should state what gas the unit is meant for, propane or natural. If it was not converted to run on propane, or made to run on propane, this is your problem. If it was built/converted for propane I would suggest you contact your propane supplier, or a restaurant service company to look at it, it would require a few specialized tools, pressure testing, orifice size req., and burner BTU. to go much further than cleaning the dust out of the burner, and cleaning the orifice.
Hope that helps, and thank you.
Feb 12, 2009 | Southbend 436D-2GR Gas Kitchen Range
How do you adjust flow regulator in gas oven
how do I adjust my regulator on a gas range
Dec 02, 2008 | Kitchen Ranges
Frigidaire Stove
you may have to adjust the flame size so you can simmer.
Nov 05, 2008 | Frigidaire FEF355 Electric Kitchen Range
Frigidaire FGF316 Gas Kitchen Range Logo
175 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
