Question about RCA RT2380 Home Theatre System System
I have an rt2380bk. Once I got the system, it was working fine. Just recently the buttons would freeze up and not work. I would have to unplug it and try it again. And a couple days ago, when I would plug in the system, only the power light comes on and and when I push power, nothing happens.
SOURCE: Unit will not power on, has the standby light on
I took your advice I unpluged the unit then held the power button in then pluged it back into power outlet the unit came on. There is one thing I might add I had to do it twice before the unit came on. Now how long will it work? Who knows
Posted on Oct 11, 2008
  • 905 Answers
SOURCE: when i unplug my rca rt2250 home theater system.
this is the amp IC and while unplugging and plugging it in again helps reset the IC for a little while , it will eventually completely quit and will need replaced
make sure that none of the speaker wires(bare wires) are touching or look like they might be where they are connected at
also if turning up the volume makes it cut out or sound bad then this will also indicate a bad amp IC
Posted on Mar 12, 2009
petraman7
  • 1175 Answers
SOURCE: RCA surround sound system probs
HI...
MOst likely a component connection that opens" no circuit" when heated then "might" connect again at some future date..Maybe at the return of Jesus or something.
It's not something that a consumer can fix.
Take it to a tv /stereo repair shop and have them look for bad solder joints in the amplifier section
Posted on May 01, 2009
SOURCE: rca rt2870 wont turn on
I have the same problem. In my case, the problem was the transistor that command the relay that supply the main transformer. You can find it in the power supply board, near of the relay.
Posted on Dec 01, 2009
nuwan chinth
  • 111 Answers
SOURCE: RCA 5.1 surround sound system, The system was
power supply problem.
you mean, stand by ok.not power up right.?
ok it can be happen something wrong with its power supply ,standby circuit,system control cct problem, or loose connection on the printed board and loose connection on the connector in the pcb can happen.
some times it can be the power on off switch. anyway open the cower and clean it with compressed air or clean it with small brush then try to turn on again and please comeback with result.
Posted on Jan 12, 2010
Ps3 60gb freezing
Try this use your vacuum to suck out any dust that is in machine from front and back. Use compressed air (duster used on electronics) and spray the cd area and back area again, vacuum out. If this doesn\'t help then Call Sony PlayStation for replacement of machine.
Jun 25, 2013 | Atari Tales of Graces f - PlayStation 3
Screen freezes, and buttons don't work!
It sounds that the main digital board to your TV has the fault. To check and locate the fault to this board is a very skilled work. Contact any service technician.
May 28, 2013 | Vizio SV421XVT 42 in. LCD TV
I recently bought a norfrost chest freezer model c6aew,the freezer did not come with a manual or guide.i switched on the freezer set the dial to seven waited 24hrs and put some food into the freezer to...
Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
May 29, 2010 | Freezers
Re: Playstation 3 Console (60 GB) - Freezing I've had my 60GB PS3 for around 24 months and it has been fine. Recently, it has started freezing in two ways: 1. Either just leaving the playstation doing...
I seem to have a very similar problem to yours on the 60GB as well. I am curently doing the total reformat but it takes a long time to do it and i have to go to work while it is reformating. So anyway if it works i will let you know. me e mail george_masono@hotmail.com
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
Blu-ray playback freeze
1st DO NOT EXPOSE THE BLU-RAY FOR ANY REASON - You run the risk of blindness and radiation exposure!!!!!!!!!!!!!!!!!!!!!
Please advise what FirmWare Version you are currently running on. You can find this under;
Settings>System Settings>System Information.
Once I have this info I will provide you with the best fix if needed but It is probably down to out of date drivers. There have been a number of changes to the blurays drivers recently and if these havent been updated then this will most likely be your problem. To solve this all you need to do is take your system online and download the newest FirmWare update. - There are people who NEVER use the system online for different reasons. Since you brought the system BluRay has gone through 4 upgrades. Any BluRays you buy now wll likely be incompatible for playback with the drivers you have on your system.
If you need any further advice on getting online with thew PS3 please post it as a new issue and I will help you - but the PS3 talks you through it to be honest
Cruton
Cruton
Feb 24, 2009 | Sony Playstation 3 (PS3) Console
Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
Jan 20, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Ps3 freezes before getting to main menu!!
Try Accessing the Ps3 Recovery Menu
Turn off Ps3
Hold the power button down; the system will turn on and turn off once again
Once the system has been shutdown, re-press your finger until you hear 2 consecutive (quick) beeps
When you hear the 2 beeps take finger off power button
You will be prompted to plug in your controller via usb and then hit the ps button
The recovery menu will pop up
Recovery menu
* restart system
* restore default settings
* restore file system
*rebuild database
*restore ps3
*system update
Now I was not sure which one to choose. I clicked restart system and that did NOT work so I clicked restore ps3 and lost everything but it DEFINITELY WORKED!!
Nov 02, 2008 | Sony Playstation 3 (PS3) Console
PS button menu frozen
buy a new controller i am its happend to me to ill see if it works and tell u
Nov 27, 2007 | Sony Playstation 3 (PS3) Console
RCA RT2380 Home Theatre System System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
