Question about Canon PIXMA MP510 All-In-One InkJet Printer
Paper jam I had a paper jam which I cleared. It still says theres a jam but there isn't It wont print I've turned it off and on and unplugged and replugged it
    President:
  • 1,382 Answers
This particular error has a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.You can find the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display). Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Thank you !!
Posted on Jul 28, 2010
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
Paper jam message wont clear and alow printing, I have opened every possible area and there is no paper anywhere. I was printing fine when if gave me the message. the piece of paper it was printing at...
Check if there is a reset, or clear message function. or you may try this one:
1. With the printer turned on, if there is a door for the cartridge, open it.
2. Then, if there is a "Go" button, "Print", "Copy" button, press and hold it for 10 sec.
3. Close the cartridge door or cover. Turn it off then turn it on again.
Please advise what will be the result.
thanks
Jun 23, 2011 | Canon PIXMA MP600 all-In-One InkJet...
My lexmark x 3650 states there is paper jam. it never happened. i was low on black ink but have just replaced cartridge. how do i clear/
Try to remove the sheets of paper from the feeder. Open the printer and remove the cartridges. Then unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Load some paper. Try to print again.
Apr 08, 2011 | Lexmark X3650 Printer
HP 5510 says clear paper jam. There is no jam
You could try unplugging the printer from the wall outlet, wait a few seconds then replug. Often times HP printers require a memory reset to clear up problems. There is no need to unplug from the computer, just the outlet.
Jul 17, 2010 | HP Office Equipment & Supplies
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Printer will not print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 26, 2009 | HP PSC 1410v All-in-One Printer
"CLEAR THE CARIER JAM"
Hope that helps!
PREM
May 23, 2009 | Dell 924 All-in-One InkJet Printer
I cannot get the paper jam message to clear off computer.. There is no paper jam and I can't print a thing...help!
Hello
Unplug the printer from the mains waite for about 10 minutes replug and see if it works.
May 21, 2009 | Canon PIXMA MX310 All-In-One Printer
HP 5610 Paper Jam Error Won't Clear
http://h10025.www1.hp.com/ewfrf/wc/document?product=79488&lang=en&cc=us&lc=en&dlc=en&docname=c00042573
Dec 18, 2007 | HP PSC 2110 All-In-One InkJet Printer
Paper jam
I used the cardboard backing from an 8x11 tablet; I pushed it into the paperholder; it pushed out a small bit of paper which could not be seen; behold, the paper jam was no longer. I paid a computer repairman $15 to do the same thing with a plastic sheet.
Mar 30, 2007 | Dell 924 All-in-One InkJet Printer
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
76 people viewed this question
old marine
old marine
