Question about Tunturi T60F T60F Series Treadmill
T60f treadmill, intermitent "motor overload problem" what does this mean?
    Problem Solver:
  • 6 Answers
This is dinesh from AADHI FITNESS SERVICE CENTRE...
Search for the details in justdial india...
There are some specification for the motor and the human weight who works on that machine...
Contact no is 9986202487
Posted on Jul 29, 2010
Exp1000 runs for several minutes
The control circuit has an overload and will shut down to prevent a fire. It may not be the Motor at all, just the circuit board failing.
Feb 26, 2014 | Nordic Track Nordictrack Exp 1000xi...
Accuchek error code e5
excessive current. At this time the treadmill will start its self-protecting system. Adjust the machine and restart. Overload protecting the motor. Test the motor y/o control board see my personal TIPS for motor help.
Jun 11, 2013 | Exercise & Fitness
System overload
Step 1:
see the video and lube the rollers bearings too
Step 2:
test the input voltage motor, if there are the motor need repair
see the diagram attached.
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty,replace
see the block diagram
Jan 09, 2013 | Nautilus T914 Commercial Series Treadmill
Our machine display show the following masage MOTOR CONTROLLER COMM DRD
two possible issues
one, unplug treadmill remove hood and make sure the main power connector to the motor control box is in properly then turn treadmill back on this has worked for me before
two , you have blown the overload resistor on the motor control board (mcb) to check this unplug treadmill and remove the steel motor control box from under the hood remove the motor control board from inside the box and inspect it for damage and /or electrical burn smell
if you find damage you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping . it cost $200 plus shipping which is a deal since a new one is $1000,i have many repaired by them
a common issue for the overload to blow is friction between the belt and deck board . if you have an auto waxer , the waxer nozzle is usually plugged . the nozzle should be cleaned once a month
contact glide for their non clogging wax to resolve this issue
good luck
Dec 26, 2010 | Life Fitness 95Ti Treadmill 95 Ti
MOTOR OVER-LOAD E203
begin to explain what you mean E203 according to the technical manual:
High Motor Overload caused by one of the following:
1: Runner heavier than weight/speed envelope in conjunction with significant deck wear.
Recomendation: Restric use to people within the weight/speed specifications and check deck wear, replace if necessary.
2: Motor lead disconnected or loose
Recomendation: Check the motor leads to ensure all leads are connected. One loose or disconnected lead will cause the overload.
3: Electrical failure on the drive electronics
Recomendation: replace VSD (Electronic board)
at this point I suggest you check, a small electronic card that is in front of the machine. withdraw the engine cover and you can see it. has mounted two black wheels attached to each other. these are two thermistors are burned if you should change them. because if you change the VSD will cost you dearly
I hope this information helps you, but can write to cardiotech_me@hotmail.com
Sep 08, 2010 | RTO Stairmaster Clubtrack 510 Treadmill
Lift motor overload
" Turn the power switch off, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
The lower board software contains a protective current measurement, should the limit exceed, it will give the ’lift motor overload’ -error. Try calibrating the lift motor and if not successful. Unplug unit remove motor shroud locate the lift motor. The lift motor driven nut is never supposed to reach either of the ends of the lift motor screw. Should this happen, the nut is likely to get jammed. Check that the nut is not against the motor frame nor against the stopper in the end of the motor screw. In a case like this the lift motor needs to be removed and the nut released by hand.
May 15, 2010 | Tunturi T60F T60F Series Treadmill
I have a model T-10 endurance treadmill when it starts to run about 10 seconds it will stop and code E-1
Unplug unit and remove motor shroud ,check upper & lower wire for solid connections , check condition of magnet on front roller to see if missing or still in place if not replace the roller. Next to the front roller, their is a speed sensor ( reed switch ) unplug the leads going to the the lower board use a multi meter to check continuity of the switch by inserting the leads into the connector and manually rotating the front roller back and forth opening and closing the reed switch if not operating properly then replace the switch.
If the above procedure did not resolve problem and still ERROR 1 then check the Motor Control Board LEDs 6 & 7 If LED 6 isn't on, change a new upper console if on then motor control board needs to be replaced if LED 7 is not on ( that a mouth full )
If LED 7 on - current overload circuit meaning too much friction between belt and deck you will need to apply good quality silicon lubricant that may be purchase @ gympart.com part# TM001
If then if the overload problem, still exists and lubrication did not the help then the belt and deck are worn and need to be replaced. Very seldom do we need to replace the Drive Motor problem is around 8% failure rate. You will get plenty warning if the motor goes out.
May 12, 2010 | Endurance T10HRC Light Treadmill
My treadmill is making a noise a winding noise from the motor
HI,
To reduce noises from the machine itself, check to see if the machine has adequate lubrication in any places that should have it (see owner's manual). For vibrations due to the contact between the treadmill and the floor, try getting a thick rubber pad, or maybe a few and set the treadmill on top of these to keep the floor from vibrating from the treadmill motions.
I will assume that the belt is not rubbing on anything. There is a long roller that is on a shaft. The roller is what the belt is on. Oil the area where the shaft and the roller meet on both sides. It shouldn't take more then a few drops of oil or a short spray of WD-40.
thank you
vijay
(vote for me)
Sep 23, 2009 | Tunturi T60F T60F Series Treadmill
Tunturi T60F T60F Series Treadmill Logo
284 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Marvin
Marvin
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
