Question about Haier Energy Star ESA3183 Air Conditioner
Firstly, water was coming out the front of the holding tray. It was tilted at a proper angle and should have run the excess out the back. We investigated to try and find out why and to correct some of the wood rot that was happening. After we tried to start the machine and 88 code and all lights come on then it bounces to E2 message and the only way we can turn off that is to unplug. We have tried leaving the machine unplugged in order to get a reprogram set but to no avail. I sent an email to Haier 5 days ago with no response from them.
  • Patricia Reid Jul 28, 2010
    I have tried what was recommended previously and didn't work and the water problem and E2 not addressed
    I have given in depth descriptions and going to the commercial air conditioning manual does not solve the problem. I want to know why we were having liquid running out of the front of the tray. The machine is at 1/4 inch back tilt as required. When we turned machine back on after trying to determine what the problem is we got an 88 with all lights on then an E2 message. Manual is useless as does not tell us what the problem is. No email response form Haier and this is day 5. What is wrong with the machine????
  • Haier Master
  • 11,800 Answers
The water is coming out because the evacuation hole - or the pipe , or the pump attached to it is blocked by dirt. You must access all and clean them thoroughly. Ideally you should take the pump , pipe and tray out to clean them.
The E2 error is just about that - the evacuation pump isn't working.
Posted on Jul 28, 2010
  • 10,319 Answers
  • frank thomas wilson
    frank thomas wilson Jul 28, 2010
    If you can remove the unit from the outer housing and clean out the drain hole. It will be clogged up with debrie inside of it causing the run off inside your home. You can also fish a wire through the drain hole first to see if it will drain out too
    Genius:
  • 1,478 Answers
I will advice you try turning it off holding buttons each individually in for 3 secs then in an hour plug back in. leave the unit for an before you plug back, see if this will solve the problem.
Take care.
Frigidaire model FFRE1033SI window airconditioner tilt problem.
Water going outside is the important part. The hole is not necessarily the drain, the angle at most is an eyesore!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 19, 2017 | Frigidaire Heating & Cooling
Water is draining into my bedroom when a/c is on ihave a freidrich model#ss12j10ar-1? can it be fixed or should i just buy a new a/c?
Before you buy another one, check two things:
1. make sure the unit is tilted back in the window and not forward. The unit has to be tilted back away from the window about a half bubble on a level in order to drain out the back.
2. if the unit is tilted in the window properly and still draining out the front, you will have to take the case off the unit and wash it out good with a hose and sprayer. If the unit is not rusted out on the bottom, the drain is stopped up that drains the water from the front coil into the base of the unit. The water should be draining from the front to the back, and excess drains outside on the ground. Hopefully, it just needs a good cleaning. Hope this can save you from buying a new unit. Stay cool. Mark
Jul 10, 2011 | Friedrich QuietMaster Electronic SS12J10AR...
My dishwasher is leaking from just behind the door on the front left(left when I am looking so the washers right) I have cleaned the area, made sure all pieces are the same on both side and it is still...
can be a couple things, 1 is your dishwasher could be on an forward angle instead of tilting backwards slightly as theres nothing actually holding the water back from pouring out the front, 2 your using to much detergent and the excessive foam is foaming over the seal (very common) try using half what your using now, 3 the pressure switch within the machine is faulty, the pressure switch is the device which tells the control board the unit has filled with the correct amount of water and when all the water has drained when damaged they will not cut off the water which will eventually overflow the machine
Jan 03, 2011 | Frigidaire Professional Series 24 in....
NewAir AF-350 is blowing water out the front louvers. Unit is 2 days old.
water normally condenses in the evaporator .. this runs down to a pan that drains to the outside section of the air conditioner .. there it it used to help cool the condenser and overflow runs out a drain in the back ... your unit is not draining the water properly to the back section .. that is usually caused by the air conditioner being being mounted with its top tilted toward the inside ... it should be level or slightly tilted toward outside for proper drainage ... its also possible that paper or other debree has clogged the drains inside the unit from the front section going to the back section ..
Jul 25, 2010 | Heating & Cooling
My Beko dwd 5410 won't drain water
unplug at mains
remove the water and the plate trays
pull off bottom front small panel
undo the posidrive screws and the torques screws to get the angled metal plate off
tilt it right back and undo the screws hold ing the bottom plate on.
rotate the left of the impeller pump case to release it from the RHS bit
look in the tube for debris
Mar 29, 2010 | Dishwashers
Water leaking from machine after cycle is over
Sounds like the pump is leaking. Tilt the machine back and put two 2x4s under the front legs. Shine a light under the machine and use a mirror to see where the water is coming from.
To change the pump:
  1. Remove the two screws at the front right and left corners of the control panel. Tilt the panel back. Remove the 3 wire harness plug and the two gold clips on the right and left of the cabinet holding the cabinet to the back panel.
  2. Tilt the cabinet forward and remove cabinet.
  3. Locate the pump and remove the two hose clamps and the two clamps holding the pump to the front of the motor. Remove the pump.
  4. Install the new pump
  5. Reinstall the two hose clamps and the two clips holding the pump on.
  6. Reinstall the cabinet, the three wire harness plug and the two gold clips holding the cabinet to the rear panel.
  7. Tilt the control panel down and reinstall the two screws on each corner.
Your ready to do some more laundry.
Dec 31, 2009 | Roper RAS6233KQ Top Load Washer
Our viewsonic monitor tilts forward. how do we tilt it back?
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Mar 12, 2009 | ViewSonic VG1930WM LCD Monitor
Water in softener dispenser
the conditioner works by siphoning out when the water from filling mixes with it, the excess water then drains away the same way, when you took the drawer out, you must have either not cleared all the powder or not put it back together properly, if it worked before it has to be something you have done, sorry, just keep trying different ways and double check to see if all bits have been cleaned properly if i have helped please rate me
Sep 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Haier Energy Star ESA3183 Air Conditioner Logo
42 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
