Question about Gateway 838GM (RB838GM) PC Desktop
Frequency out of range
The monitor on my Gateway desktop is diplaying the message'' frequency out of range'' and will not respond to any keystrokes. How do I fix this?
    Problem Solver:
  • 14 Answers
Try this
Start the computer in Safe mode.
From the Start menu, click Run.
In the Run dialog box, type: regedit, and then click OK.
In the Registry Editor dialog box, double-click HKEY_LOCAL_MACHINE, Config, 0001, and then Display, Settings.
In the right pane, double-click RefreshRate.
Change the value data to 60, and then click OK.
Double-click Resolution.
Change the value data to 640,480, and then click OK.
Restart the computer in Normal mode
If that doesn't work, you may have some video card issues.
Check to make sure all cables are properly connected and they are in good condition.
Hope It works =)
Posted on Jul 28, 2010
    Sergeant:
    Champion:
  • 209 Answers
First of all press F8 key several times before window boots and then select last known good configuration otherwise go in safemode and then set the screen resolution to minimum.
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
Keep getting "frequency out of range" meassage
Sounds like there is an issue with the video card settings versus your monitor.
Try the following:
1.) Press F8 on boot and select VGA mode then once into the OS reset the video card options
2.) Try another monitor
3.) If you have video card, swap it out. If you have onboard graphics put a card in
Cheers...please post your results.
Nov 05, 2010 | Gateway D710 PC Desktop
In the middle of my screen a blue box is showing and in it this reads OUT OF RANGE H. FREQUENCY 68.7 KHz V. FREQUENCY 85.0Hz What does this mean and how can I fix it this was a gift...
That message appears when the Windoze display settings exceed the monitor capabilities. If you will boot into windoze safe mode (F8 at boot) and correct the display settings, the message should clear at the next boot. Afterwards you can right click on the desktop and access the display settings to make final adjustments.
In your case, the refresh rate (V Frequency) should not exceed 70 Hz
Nov 23, 2009 | Envision H22W 22" Monitor
Out of range message
This is caused by a resolution and/or refresh frequency setting in your computer's display properties that exceeds the values supported by the monitor.
Find out the optimum (native) resolution of your monitor (in case of AMV 17V5 it will be 1280x1024 pixels), and supported refresh frequency (usually 60Hz for LCD monitors), and set your display properties to these values.
Nov 23, 2009 | Amptron AMV 17V5 17" LCD Flat Panel...
"out of frequency range" message nothing works
Try booting to the ENABLE VGA mode off the F8 menu if you can get to the desktop and then you can go to display properties and see if you can reset the resolution to normal. If no go, try updating the video driver
Oct 02, 2009 | HP Compaq FS 7550 17 in.CRT Conventional...
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
view sonic -E70fB monitor displaying H.V frequency out of range
Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
Sonicview VG 2021 - Out of Range message
..hi..just select menu on the front panel of LCD the find the option Auto then click Auto..good luck..Thanks...^_^
May 11, 2009 | ViewSonic Graphic VG2021m LCD Monitor
You need to install the video drivers for your monitor. Go into SAFE mode to install them.
Mar 29, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Ps3 to gateway fdp1760 frequency out of range dvi to hdmi cable
what Frequency is the monitor set to run at ? u will get that mesg whan the monitor is receiving a signal that is greater than what it can handle say ur monitor can take 1024x768@60hz from ur PC and maybee ur PS3 is sending 720x720@100hz so ur monitor can handle the resolution but not the refresh rate that would be why u get that message
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
Need to unlock our radioshack pro 2018 200 channel desktop scanner
Easy to use right out of the box!
Explore preset frequencies used for non-trunked police/fire, aircraft, marine, NOAA weather and more. Just attach the antenna, switch it on and touch one of five buttons. With just two keystrokes, you can store a frequency you find in the 200-channel memory for later scanning or monitoring. You can also search for activity in frequency ranges you specify or program known "action" frequencies on the keyboard.
  • 1-touch search lets you find police/fire, HAM radio, marine and 7 NOAA WX frequencies fast
  • Built-in weather receiver sounds an alarm when your NOAA weather station sends an alert
  • 50-frequency search skip locks out undesired frequencies
  • Programmable by computer (requires Scanner PC Programming Kit #20-048)
Aug 06, 2008 | Computers & Internet
Computers & Internet Logo
220 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
