Question about Zebra Desktop T402 Printer
My new computer do not have LPT1 ports. I using prnt server but can't get printer print. I also try USB cable but I can't comunication with printer
  • 415 Answers
Try parallel to usb adapter, it may work
Posted on Jul 28, 2010
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
Unable to scan -- I think I downloaded software for Dell 926 and rebooted, turned off printere, back on again, no luck. Help! JJB
we have a hewlett packard t45. We got a new computer without a lpt1 port, so we got a usb cable. Now it will only print, the print requires a lpt1 port to operate properly. The new scanners and all-in-one printers use a usb cable. I had to got to the manufactures website and do some searching and reading to figure it out.
Aug 07, 2009 | Dell 926 All-In-One InkJet Printer
I have a HP Officejet All-in- One. Fax won't go through
We have a Hewlett packard officejet t45 all-in-one. We recently bought a new computer that didn't have a LPT1 port, only usb ports. So we bought a usb cable and now it only prints. I then went on the Hewlett Packard website and did some searching and reading and found that our all-in-one printer requires a LPT1 port and cable to work properly. If that is the same with you, you can buy a LPT1 card with the port to install in your computer.
Aug 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
Epson t88iii will not print
I would like to say sorry to you I got my serial port mixed up with the parallel port. I have resolved the problem, it was a DIP switch change which needed to be set. If anybody can not get their computer to communicate with the printer then I would suggest they download the Epson Technical reference guide and read it thoroughly, but only use the guides for your method of connection which is dependent on your model of printer. I found that for a baud rate of 38400 DIP switch SW 1 numbers 7 & 8 should be switched to ON .I hope this helps some else.
Dec 12, 2008 | Epson TM-T88III Thermal Printer
HP4500 Color laser and setup using USB
just try to change the LPT1 port to usb port..
Oct 28, 2008 | HP Color LaserJet 4500n Printer
I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Sep 30, 2008 | Epson Stylus Photo R220 InkJet Printer
Oki C5150 Not Communicating with Computer
lpt1 usually only works for parrallel printers unless a USB port has been mapped as lpt1.
Is this being installed on a Windows Vista computer?
Jun 19, 2008 | OKI C5100n Laser Printer
Samsung ML-4500 with IEEE 1284 to usb cable not working
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
May 14, 2008 | Computers & Internet
My Printer EPSON TM-U220 does not print....HELP!!!!!
Change port to Printer port Lpt1 not the esdprt. then uncheck enable bidirectional support/ Restart computer and then try to do a windows test page
Jan 14, 2008 | Epson TM-U220 Matrix Printer
Can Not Print to HP LJ 1020
hook the print server directly to the computer and program it with a static IP address.
than create a new printer port in add printer. Than setup the printer and use the port you just created and it will work fine
Dec 14, 2007 | D-Link DP-300U (DHDP300U) Print Server
Zebra Desktop T402 Printer Logo
123 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
