Question about Dishwashers
Water does not drain from dishwasher even when cancel/drain is pressed
  • Anonymous Jun 17, 2008
    INTAKE DRAIN BLOCKED
  • endaki Dec 21, 2008
    I AM NEW T0 REPAIRING MY OWN APPLIANCES I HAVE PUT VINGER IN THE BOTTOM OF THE DISHWASHER LET IT SET AND IT DID NOT DRAIN HOW DO I CHECK THE BLOCKAGE OF MY DRAIN LINE
    Genius:
  • 1,073 Answers
Is the pump running, if so check for blockage in the drain line or in the pump
Posted on Apr 24, 2008
Why is there water standing in the bottom of my dishwasher after it has completed the wash and dry cycles.......
If water remains in the dishwasher after the cycles end, check the kitchen sink drain to make sure it's not clogged. If there's no clog, try pressing the Cancel button; most dishwashers run the drain pump when the Cancel button is pressed.
Check the dishwasher drain line, drain path and drain pump.
Oct 25, 2017 | Dishwashers
Dishwasher not draining
The problem is a clog in the hose or the check valve from the drain pump. I will post back shortly with directions to unclog it.
Thanks/Mike
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Dishwasher was not draining. I cleaned out everything and now it wont start
I have the same problem with another Kitchenaid model. I've had better results at keeping the water drained by running two back to back water saver cycles than running a full pots and pans cycle.
Nov 06, 2017 | KitchenAid 24 in. KUDS01FLSS Built-In...
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Kenmore ultra wash dishwasher 15835 it runs fine, but when is sets after its finished it get water in it and you have to press cancel to drain it again. Any idea?
Water inlet valve needs replacing. (about $50 for the part)
The valve is leaking and allowing water to enter the dishwasher even when it's off. You can turn off the supply line shut off between uses until you get the part.
Jun 14, 2010 | Kenmore Dishwashers
Kitchen aid dishwasher not draining....help
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Apr 05, 2010 | KitchenAid 24 in. KUDM01TJ - Multiple...
Water not draining from the bottom of the dishwasher
vacuum it out with wet/dry vac and see if filter is dirty big peices of food will accumulate and stop it up if not check under sink where drain hose connects to main drain
Feb 19, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Feb 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
155 people viewed this question
Top Dishwashers Experts
