Question about Cobra 148 GTL 120-Channels Base CB Radio
A problem in the squelch and volume control knob.
  • 1205 Jun 22, 2008
    148gtl dx low vol from squelch no steps taken at moment except ive got a service manual
  • Dean Dishman May 11, 2010
    what problem are you having ? need more info
  • 27 Answers
What problem ?
Posted on Jun 22, 2008
  • flyingfox Jun 23, 2008
    Low speaker output in the cobra 148gtl is very common and was a problem when the sets when they were not as old as they are now. I think it is pension time for the old 148gtl...As a matter of interest almost all of the parts on the board are freely available with the exception of the onboard IC's>>>>TO 1205<<<< an emailed copy of the circuit diagram would be great if possiable.
    flyingfox@people.net.au
How do you set the volume on a motorola talk about mt 350
Here's a link to the user guide http://shop.giantintl.com/Manuals.asp select your model from the pulldown
Mar 05, 2014 | Motorola MT350R Talkabout MT350 Series...
How can i stop the squelch ive tryed turning the sqcuelch doesnt help
Plug the AC adapter into the back of the scanner and into a wall electrical outlet. Screw the antenna into the receptacle on the back of the scanner (extend the antenna to full length for best reception).
  • 2 Set the squelch level to allow signals to be heard by turning the squelch knob counterclockwise. Rotate the volume knob clockwise until you hear static. Slowly turn the squelch knob clockwise until the static noise disappears.
  • 3 Start programming frequencies into the scanner by pressing the "Manual" button.
  • 4 Press the up arrow or down arrow key until the channel you wish to program is visible on the display.
  • 5 Use the numbers on the keypad to enter the frequency for the local transmitter you wish to receive.
  • 6 Press the "E" key to complete the process of entering the frequency.
  • 7 Repeat steps 3 through 6 for each additional frequency you wish to monitor.
  • 8 Press the "Scan" key to start the scanning process. The scanner stops on a channel when it detects a signal strong enough to hear over the squelch setting. Two seconds after the signal stops, the scanning process resumes.
  • Dec 06, 2011 | Uniden BC248CLT Base Scanner
    Cb has power but no squelch,can't recieve or transmit
    Begin with
    • Volume knob 12 o'clock position
    • Squelch knob full counter clockwise
    • RF gain knob full clockwise
    • Pa/CB switch to CB
    • Mic plugged in
    • Check coax and antenna connections.
    • Make sure your antenna gommet/insulator is installed correctly or it will directed gound. Treat antenna shaft as it is the positive portion of circuit.
    If you have another CB check the antenna system with that rig. To verify it is a radio issue. Then dig deeper Microphone, PLL chip, Audio chip etc.
    Jan 11, 2011 | Cobra 29 LTD CB Radio
    I have 4 wires that came loose on my volume/squelch knob. 2 are black, 1 white, 1 green. trying to figure out where they go.
    Nothing Yellow Black
    Green White Black
    Orange Red
    The black wires are both ground connected into the same part in the board. Just connect them depending on length.
    This is the picture of the vol knob, with the dial upward looking down on the tabs. The top wires, yellow and black, are for the volume. The Middle row, green, white and black are for the squelch. the orange and the red are the power switch.
    Nov 25, 2010 | Cobra 29 LTD CB Radio
    My radio recieves ok but only whistles when i key the mike is this a major fix?
    Do you have talkback installed? It my be too loud and causing feed back. Back the mic gain down if so.
    Could also be improper mic wiring. If you use a mic that is wired for a different radio, it could just cause a hum, buzz or squeal.
    Another thing that can cause a hum, buzz or squeal is a faulty volume and or squelch knob depending on the radio.
    • Turn down or disable talk back.
    • If you cannot turn off or disable talk back, lower mic gain.
    • Try a different mic that you know is wired for cobra.
    • Play with volume and squelch knobs while TX and see if it stops at all. If it does replace knob.
    Oct 12, 2010 | Cobra 150 GTL DX Base CB Radio
    Every thing seems to work, but no sound and no squelch
    Most likely an open speaker, though water damage to volume/squelch controls is also a possibility. This can be checked by removing the knobs and inspecting the shafts for corrosion.
    Jul 08, 2010 | Raymarine Ray45VHF (53 Channels) 2-Way...
    Scanner acts like it doent have squelch control
    If your scanner is open squelched on one channel, try blocking that channel out. Some times a channel can get jammed if someone has a mic cue button stuck or something similar.
    Try locking out that particular channel and see if you get your squelch control back.
    Apr 07, 2010 | Radio Shack Pro-2052 Scanner
    All static when not sending
    There is a "squelch" control (may be a ring around the volume knob) that controls whether the radio thinks there is a signal to listen to. Adjust this until you don't hear the static (it should cut off all at once, that is where you want the control set).
    Aug 16, 2009 | Cobra MicroTalk PR 1100 WX (15 Channels)...
    Need to replace the RT side Volume and squelch control knobs on my 8800
    Yaesu Parts should be able to get them for you. Call: (714)827-7600
    Aug 13, 2009 | Vertex Radio Communications
    Scanner squelch
    I have a couple suggestions for you. The unit has probably gotten oxidized controls from age. Any thing with rotating contacts over a period of time will get dirty. You need to purchase some contact cleaner (Read info on the can that it is safe for plastics) and flush the squelch and volume controls. You may also have to open the unit and identify what they call 'pots' or little trimmers to clean and adjust. Set your squelch control at mid range and with an insulated tool turn the pots a little in both directions and return it to original the positon. This will clean the control and when you find the one that effects your squelch it may have drifted and need to be readjusted until you have better control on the front knob.
    Feb 13, 2009 | Uniden BC350C Base Scanner
    Cobra 148 GTL 120-Channels Base CB Radio Logo
    69 people viewed this question
    Top Cobra Radio Communications Experts
    AnyMHz.com
    AnyMHz.com
    Iron
    Iron
    Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
