Question about Roper REX4634KQ Electric Dryer
Roper REX4634KQ When pressing the switch to activate a cycle the dryer will immediately turn off when you let go of the switch. If you hold down the switch it will continue to run. Is the switch bad?
    Scholar:
  • 186 Answers
Possible bad relay. When you push the start button, you engage the start capacitor long enough to get the motor turning. When you release, either a run capacitor kicks in or a relay kicks in to keep power applied.
Posted on Apr 24, 2008
    Genius:
  • 1,028 Answers
Also note some models have a motor relay controled by "even heat" board if relay is not energized by the board or has bad contacts internally relay will not keep motor running
  • 145 Answers
That should be just a push to start switch. The start switch is inside the motor. When the motor turns fast enough it trips an internal switch to keep the motor running. It sounds like you have a motor on the way out.
I have a Roper electric dryer and stopped mid cycle. How/ where do I find the thermal fuse?
the thermal fuse is in the back on the dryer you will have to take the back cover off the fuse is white and is a few inchs long it usually only have 1 screw holding it on.
Sep 05, 2011 | Roper REX4634KQ Electric Dryer
My Roper dryer heats up but does not turn when I push the start button. What would cause the dryer to not spin?
one is the belt may be broken or have slipped off the pulley.the door switch could also be bad. try and hold the door open and depress the door switch at the same time someone is pushing/turning the start button and then try to rotate the drum be hand and see if it will turn. the motor could have alot of lint build up and cause the motor not to turn.
Oct 13, 2010 | Roper REX4634KQ Electric Dryer
Wont turn on checked outlet and breaker
Check the door switch with an ohmmeter AFTER removing power from the dryer. The switch should read zero ohms when the plunger is pressed into the switch.
Jul 07, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer by maytag press star button here noise but does not start?
you will nead someone to help you to see if you have a bad moter.first open door,with your right hand push in on the door switch.hold the switch in ,have someone push the start switch in and at the same time with your left hand turn the dryer drum clock wise,if the dryer starts than you have a bad moter.the cost of the moter would be 1/3off the cost off a new unit.
Nov 20, 2009 | Roper REX4634KQ Electric Dryer
Turns off during cycle
Motor is getting hot and shutting down. Probably have to replace motor or clean it.
Mar 26, 2008 | Roper REX4634KQ Electric Dryer
My roper dryer stopped working
right above the door where it closes, there should be a door switch actuator, although your closing the door it might not be activating door switch.
Feb 24, 2008 | Roper REX4634KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
179 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
