Greetings. I have my Duplo dbm 120 with the Paper Jam In Stapler error on the screen with Jam Code 6 but the actions that given in manual didnt help me out because in fact there is no any paper in the device. Is any possibilityto reset this error? Thank you.
jackboy
  • 2985 Answers
SOURCE: Paper jam
The various parts that open up to allow access are monitored by a micro switch. Switch the machine off and open all the access points locate the switch and make sure it is freely working and the connections are all in place. Then come back
Posted on Jun 06, 2007
  • 163 Answers
SOURCE: paper jam, and check film error messages
dear sir the film sensing sensor and paper path sensors are abnormal or dusty pleaz check them
Posted on Sep 21, 2007
checkitright
  • 1362 Answers
SOURCE: Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Posted on Dec 26, 2007
Guru Guy
  • 95 Answers
SOURCE: paper jam inside
You may also have a problem with the paper feed (clutch, dirty feed/pick up tires) section, or even a dirty sensor as Jay mentioned. A sensor in modern office equipment is generally a photo sensor, which means it shoots light from one side to be detected on the other side of it. If it's dirty, it will give you a flase reading. Try cleaning the tires that pick up the paer from the tray (don't force them down if they won't rotate easily) with mild soap and water on a rag, and also try fresh paper. Sometimes if paper has been sitting for a while, or in damp conditions, it will pick up moisture and give you paper feed problems... which is what it sounds like you are having. Sounds like the paper may need even be making it to the sensor in the 1st place if it on comes out of the tray 1/2 an inch. Good luck
Posted on Dec 27, 2007
Ajkill
  • 2035 Answers
SOURCE: E3 error code
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 31, 2009
Please help me, I have a Duplo machine DP L500 and it's giving me service call E001. What would be the problem?
    ewol3i Apr 01, 2012
    main motor error..check main motor boards fuse at the back of the machine or the timing belt might be damage
  • Joseph Nov 28, 2013
    check the encoder sensor
ERROR CODE E001 DUPLO DP C120 Duplo Office Equipment Supplies
The manual is here, although it does not mention error codes.
http://www.toshiba-sa.net/Documentation%20%20Duplo/DPL-500/DPL-500_Instruction_Manual.pdf
Duplo machine DP L500 error E001 Google Search
Mar 07, 2018 | The Office Equipment & Supplies
Good night i need manual DUPLO DBM-200 THANKS
Try Googling (duplo)(DBM-200)(manual) without parens.
Sep 13, 2017 | Office Equipment & Supplies
81 01 error
Paper-Axis shutdown - usually a paper-jam caused by a blockage of the
Paper-axis System.
Action- Try the following= If this error code was caused by a paper-jam, unplug the power cable from the printer and clear the blockage. Plug in the power cable again and check if the Error Code has disappeared
-If this error code appeared but was NOT caused by a paper jam,
replace the Paper-Axis Motor Drive Assembly
Jan 14, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
Would like to download owners manual for Duplo DP21
YOU CAN DOWNLOAD IT VIA WWW.GETMANUAL BUT HAS TO PAY SMALL FEES VIA CREDIT CARD
Mar 31, 2010 | Duplo DP21L Copier
Duplo DF-520 Error Code
you will find it in the operation guide. i uploaded the pdf copy here: http://www.mediafire.com/view/?7wvzv3jqwcyga1g
Jan 15, 2010 | Office Equipment & Supplies
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
Got error code e104 duplo DP-460H
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Jan 08, 2009 | Duplo DP460H Copier
629 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
