Question about Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum
HOW DO YOU REMOVE THE DYSON04 SWITCH
HOW DO YOU REMOVE THE DYSON 04 SWITCH
Dyson sell a bent screwdriver.....
.... to make it easier to remove the switch cover:
I have used an ordinary screwdriver pushed into the tiny gap between the flat side of the switch cover (see picture above) to force the 'tooth' away from its housing, and then pull cover off.
Underneath is a torx-headed screw, which when removed allows withdrawal of the switch assembly.
Posted on Feb 06, 2011
Does anyone have "duct" assembly instructions for Dyson DC 24? (Not the owners assembly manual)
Google Dyson. co On the drop down window, find your model, type in Dyson DC 24, at bottom of page click on shopping info, click parts. you can order from there.
Oct 19, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
How to remove clutch on dyson dc07
This service is hard to explain. Try googling it so you watch a video of how it is done. You can purchase belts and rebuild the clutch with the new belts or you can purchase a new clutch with belts already installed
Mar 27, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Will not stay on.
Hi There,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums . The switch that Dyson uses for their vacuums is one of the cheapest switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
I took oictures of replacing the switch assembly on one of our customers repairs they brought in. It was having the same exact problem that yours is, it just wouldn't stay on. Here's how you can fix the switch on your Dyson:
- T15 Torx Bit Screw Driver
- Genuine Dyson DC07 & DC14 Replacement On/Off Switch Part 901181
- Needle Nose Plyers
- Patience (haha)
The switch above is actually a link back to our site if you have yet to purchase the switch yet. We carry most every Dyson part.
IMPORTANT: MAKE SURE YOUR VACUUM CLEANER IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 1. First thing you'll want to do is to unwrap the cord from the machine, and remove the handle from the upright part, then slide the hose all the way down the wand, and remove the hose from the handle assembly completely and set it aside. Also remove the dust bin assembly completely from the machine as well.
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay vacuum2_bing.gif on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson vacuums2_bing.gif are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
Here's what the vacuum should look like after the switch housing has been removed:
Step 4. Use your needle nose plyers to remove the terminals from both of the switch poles.
Step 5. Take out the new switch assembly. I find it the easiest to use my needle nose plyers to reattach the wires to the new switch, but it also can be done with just your hands. Connect both wires to your switch. If the cords have come loose while you have been working on the vacuum, you'll need to put the wires back into their proper places as well. This is how the switch and the wires should look like when you're done:
Step 6. Once the switch and cords are back to their normal places, simply put the switch housing cover back on, and screw in the one screw.
I hope that this repair was helpful to you, if you have any questions or have any problems, please feel free to use the clarification request form here on Fixya.
If you ever need any supplies for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
Thanks again,
Chris J.
GoVacuum
Apr 08, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Fix a belt on a dyson dc 04
need to know if your unit is clutch or clutchless but if you go onto youtube and look for fit dyson belt or fit dyson clutch that mite help
Oct 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Replace control switch on Dyson 04 Model
You have to remove the yellow on /off switch first. This is actualy a cover to the switch below. I removed mine with x1 of the centre prongs of a fork. Bend the centre prong to 90 degress to the fork handle, and put a tiny kink at the end of that prong. (you should end up with a funny lookink "Z" shape. Bend the remaining x3 prongs totally out of the way. Keeping the yellow switch cover up - use pliers here- push the singular prong down the flat egde of the cover. ie inboard. When you think you have the clip pushed in pull the cover up with the pliers and - hey presto access to the actual sw and wires is revealed.
Oct 02, 2009 | Vacuums
Stopped running. won't turn on
check power cord or replaced Powercord Assy part no : 905449-04
check power switch or replaced power switch part no : 910971-01
Oct 01, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Dyson dc 04
Hi.
Which machine have you got Dc04 or Dc05 ?
Jul 01, 2008 | Dyson DC05 Cylinder Bagless Canister...
Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum Logo
231 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
