My onkyo tx-ds989 cuts out when I turn it on than the red led flashes next to the on button
    Genius:
  • 1,550 Answers
Your audio amplifiers ICs are damaged you gotta change him.Good luck.
Posted on Apr 24, 2008
Onkyo TX-SR805 Receiver power-on button not working, only the led red light indicator appears. Tried to reset by holding/press vcr/dvr & standby/on button, no result. Please help me solve this problem
Hello, Sorry, if the receiver does not turn on we can't do any troubleshooting. I suggest having your receiver serviced or traded in. Thank you, Onkyo USA
Feb 26, 2017 | Onkyo Audio Players & Recorders
How can I disassemble?
HI Riccardo, if you are looking to order replacement remotes you can do so by calling our Parts and Service Department at 800-229-1687, Thanks, JT
Nov 20, 2015 | Onkyo Home Audio Receiver Remote Control...
TX DS989 turns off after 3 seconds
Sorry but it does sound like an Amp failure and testing the unit for other electronic component failure will be needed
Jan 03, 2014 | Onkyo TX-DS989 Receiver
I have a Onkyo TX-DS989, I have my xbox connected to it but only the red and white wires, my question is I have an optical cable that I wish to connect to it. i know where it goes but I get no audio....
You have to assign any digital audio inputs and that requires a functioning controller.
http://remotes.com/remotes/servlet/rs?&smodel=RC875&brand_pn=DENON_RC875&o=c&o=c&a=Search&uid=0&m=Onkyo+TX-DS989&uuid=A13121693494221
http://cgi.ebay.com/RC-390M-ONKYO-HOME-THEATER-CONTROLLER-/120752334524?pt=LH_DefaultDomain_0&hash=item1c1d6666bc
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
http://www.remotes.com/
Jul 31, 2011 | Onkyo TX-DS989 Receiver
When I turn on my Onkyo TX-DS 989, the standby LED does not light up and you can not turn on the amp, but after about half an hour the LED lights stby and then you can turn on the amp and everything works...
The trouble is almost certainly bad capacitors in the power supply. As they age they become very slow to charge up (think of them like buckets that store electricity for other parts to draw on, and it's taking them much longer than normal to fill). As a result it's a while until the rest of the circuitry starts working properly. But once they've charged, the thing works like it should.
If you know someone with some electronics skills, they could check the capacitors and replace any that are visibly bad or don't measure correctly. Or you could see about getting the receiver serviced if you have a shop in your area. Musician's supply stores are a good place to check, or ask retailers if they have anyone they suggest. Since the receiver is basically okay otherwise, having this repaired would probably be worthwhile.
Mar 04, 2011 | Onkyo TX-DS989 Receiver
Just purchased a Panasonic DMT-350 with analog 7.1 out and hooked up to my Onkyo 989 but tried everything and i mean everything to get my rear surround to play but no luck....pleeeeeease help me.
Hi.
Connect the Panasonic to one of the AV inputs on the Onkyo. Use red white and yellow AV cables. Connect the output from the Panasonic to one of the five AV video inputs on the Onkyo (or use the DVD dedicated input in the Onkyo backpanel). I indicated this option using red arrows. You can use any of the AV inputs or the DVD input at the bottom. Just ensure you do not connect to an output at the back of the Onkyo.
Alternatively use component cables and optical audio input, as indicated using the blue arrows in picture below. Select source and listen surround from the Onkyo.
There are more options. In some case you may decide to connect the DVD video output to TV and the audio to the Onkyo.
Here a manual for the TX DS989.
Here the backpanel:
Dec 26, 2010 | Onkyo TX-DS989 Receiver
Onkyo TX-DS989 not staying on
This sounds like the action of some protection circuit that is monitoring some condition or voltage that isn't within its design limits. If it was mine, I'd look for an Onkyo forum to see if others have experienced the same problem.
Sep 10, 2008 | Onkyo TX-DS989 Receiver
 Grubhead
Grubhead
