Question about Radio Shack 63-1217 Rangefinder
Need direcftions of use
63-1217 Rangefinder, looking for directions on how to use it
How do I clean a rusty rangefinder?
To know the proper process of cleaning a rusty rangefinder,
here is the full details you can see it: How to Clean a Rusty Rangefinder.
As a learner of knowing how to clean a rusty rangefinder, you should follow the few guidelines and procedures very carefully if you want to be successful in cleaning a rusty rangefinder.
Before cleaning any rusty rangefinder, you have to make all the parts of the rangefinder separate from each other so that you can clean it very well. It is essential for you to maintain because you can't clean well if all the parts of a rusty rangefinder are together.
Apr 03, 2018 | Optics
Which is the best rangefinder for accurate shot?
Sig Kilo 2000 Rangefinder
Sig is famous for its high-quality product, and Sig Sauer 2000 Kilos Rangefinder is no different. This rangefinder is being picked by most of the hunters and shooters for its 1000+ yard range which enables you to have the best hunting experience. But that is not all. The Sig kilo 2000 rangefinder review describes more about it.
The Sig Sauer Rangefinder consists of a Cordoba protective carrying case, a lanyard, battery, a manual for guidance and a box for protection. The size of the rangefinder is possibly same as the size of your palm which is very convenient to use. The specifications of this rangefinder are as follows:
Specifications
  • Magnification Range: 7x
  • Finish: Matte black w/Rubber
  • Objective: 25mm
  • Eye Relief: 0.59" (15mm)
  • FOV: 34.6' @100 yards
  • Max Range: 3400 yards on Reflective targets1500 yards on trees1200 yards on deers
  • Reticle: Circle with data
  • Battery: CR2
Mar 11, 2018 | The Optics
Which is the best golf laser range finder?
Bushnell Scout DX Rangefinder is a good one for golf.
It's a fantastic rangefinder.
It offers some amazing feature and specification like...
  • 6x magnification.
  • Range between 5-1000 yards.
  • 3-volt CR2 Battery.
  • Rangefinder Accuracy 5 yards.
The Bushnell Scout DX Rangefinder will help you to pick from 3 different user modes by pressing the Mode button at the left side of the unit. First is the usual mode which can be used for most purposes up to 1000 meters and works well towards the pretty reflective surface.
When turned on, the Scout 1000 Laser Rangefinder liquid crystal display (LCD) will directly display icons like the bow and rifle mode. The bow mode will provide you with true horizontal distances from 5-99yd away, depending on the angle. The rifle mode, however, will permit you to get the angle and drop/holdover of your shot to the target from 100-800yd.
Mar 03, 2018 | The Optics
Blurred numbers on Bushnell range finder.What's the problem?
Bushnell V3 display question - Toronto Golf Nuts - Greater Toronto ...
www.torontogolfnuts.com > Golf Discussion Forum > Golf Gear & Equipment
Apr 8, 2014 - 22 posts - ‎3 authors
Bushnell V3 display question Golf Gear & Equipment. ... When I start it, the numbers are clear but it does not stay like that the whole time. ... Yea I used that and turned all the way counterclockwise (all the way clockwise was very blurry). .... to read and drive and has a real problem using my rangefinder.
Bushnell blurry display Rangefinders Questions & Answers (with ...
www.fixya.com > Forum > Tags > blurry display > Rangefinders display the display appears but does not display yardage Here is the link to the instruction manual if you need it; ... Sight target needs adjustment When i look ...
DIY Fix For A Malfunctioning Rangefinder On The Cheap
fardevice.com/diy-fix-for-a-malfunctioning-rangefinder/ 4 Common Malfunctioning Rangefinder Encountered (and How to Fix Them), or blank ... Bushnell Tour V3 Jolt Standard Edition Golf Laser Rangefinder .... This could be rooted to a blurry focus lens or laser output, so it's really important to ...
Bushnell - I am having difficulty seeing through my scope, all images ...
bushnell.com/global/customer.../i-am-having-difficulty-seeing-through-my-scope,-al I am having difficulty seeing through my scope, all images seem blurry. How can I properly focus ... What battery does my rangefinder take? All my pictures are ...
Bushnell Golf - Bushnell Golf
bushnellgolf.com/ The undisputed #1 Laser Rangefinder in golf ... Bushnell Tour Domination. The #1 Rangefinder in Professional Golf For Over A Decade. Learn More. The #1 ...
Bushnell Tour Z6 Laser Rangefinder - Review - MyGolfSpy.com
https://www.mygolfspy.com/bushnell-tour-z6-laser-rangefinder-review/ 6 posts - ‎4 authors
The Final Contender In The Rangefinder Round Up: The Bushnell Tour Z6 ... Our second entrant is the Callaway RAZR Rangefinder dropped a .... I have near perfect eyesight, but when target is clear, number is blurred and vice ...
Blurry vision Range finders - GPS/Range Finders/Mobile Apps - GolfWRX
www.golfwrx.com > ... > Equipment > GPS/Range Finders/Mobile Apps May 14, 2015 - 5 posts - ‎5 authors
What causes a range finder to have blurry vision through lens? Im looking to purchase a used Bushnell tour v2 in a couple minutes and I've ... Which Laser Rangefinder
2 Aug 2014
Pro 1M Slope = Bad, Bushnell = Good
1 Aug 2013
Problems with Bushnell Pinseeker 1500?
24 Jan 2009
More results from www.golfwrx.com
Jan 07, 2017 | Bushnell Optics
Use of bosch dlr165 when there is no direct line of vision
northerntool.com has a few wheel meters that roll along the ground and will give you a fairly close measurement. or you can use the string method where you take a string and stretch it as close to a straight line as possible then mark it then get it out to where you can measure the string.
Dec 24, 2009 | Bosch DLR165K Laser Rangefinder Kit
Bushnell 400 rangefinder won't show yardage stuck on 888
If the unit is stuck on 1888 the circuit board inside has lost its programming. Sounds like its about 10+ years old. Bushnell doesn't work on them anymore. If you use it for hunting I would suggest the Scout 1000 with ARC compensation, if you use it for golf look at the Medalist. You can see them both at bushnell.com
The hunting rangefinder will run about 250 bucks
The golf rangefinder will run about 220 bucks.
Both use advanced target locking systems.
mtg
Jun 01, 2009 | Bushnell Yardage Pro 500 Rangefinder
Where can I find a user manual bushnell yardage pro 600 laser rangefinder?
http://bushnell.com/manuals/rangefinders/20-1925_YardagePro_X500.pdf
Sep 28, 2008 | Bushnell Yardage Pro 500 Rangefinder
Bushnell rangefinder
IJ could not find a US email. You however could harrass them down under if you like. info@tasco.com.au
Dec 12, 2007 | Bushnell Yardage Pro 800 Compact...
Leica III camera focusing problem
Yes, if the vertical misalignment is small, say, about less than a tenth of the image size that is misaligned vertically, then try rotating the 'lens' that covers the front left (as viewed from front of camera body, in upright position) rangefinder window.That is, the front RF window near the slow speed setting dial. In order to do so, you will need to unscrew the decorative chrome bezel first. Unscrew in counterclockwise direction. Do not use pliers, etc. to remove bezel, or you will possibly distort and/or mar the chrome finish. Instead wrap bezel with two, or three layers of making tape, making certain masking tape is not contacting the body of the camera, but only the bezel. Usually, bezel can now be unscrewed by hand only; if not, use pliers gently with the masking tape acting to protect the bezel's finish. Once the bezel is off, the lens (it's actually a glass wedge prism) can be rotated using the prongs of a tweezer inserted in the two notches of the brass ring encompassing the 'lens', or glass wedge. First, rotate in both directions, cw and ccw, in small angles to determine which direction and how much wedge rotation is required to bring the two rangefinder images into coincidence vertically. Reassemle in the reverse order.
May 19, 2007 | Leica IIIg 35mm SLR Camera
Radio Shack 63-1217 Rangefinder Logo
56 people viewed this question
Top Radio Shack Optics Experts
Marvin
Marvin
james laughton
james laughton
ray gallant
Are you a Radio Shack Optic Expert? Answer questions, earn points and help others
