Question about E-Machines eMachines T3830 PC Desktop
Monitor Hello and thanks for aswering my question. The monitor keeps going to the energy safe mode when trying to turn on. It says check cable cords or goes to energy safe mode. can you help thanks
  • 67 Answers
I would try going into your video settings, right click on your desktop then go to properties, In the window click on the Screen Saver tab and go to the bottom where it says monitor power click the button that says powermidway towards the bottom there will be 3 settings, the first being "turn off monitor" with a drop down menu... set it to Never. That should keep it from turning off. If there is something wrong with the cables and its stil shutting off, you may just need to gte a new power cord, its usually the same cord used for the computer power and they aren't very expensive, Radio Shack probably carries them. Hope thishelps, Good Luck!
Posted on Apr 24, 2008
When I turn on the computer the monitor starts to come on and then it goes into safe mode and goes off. I first get a green light for a couple of seconds then it goes to amber.
Have you tried with another computer? I suggest to do it first, before assuming this is your monitor problem...as this is usually caused by most of computer problem not monitor.
Aug 10, 2011 | Dell Computers & Internet
My laptop moniter turns on as usual with the proper reading. I start in safe mode as normal..wait about 10 min and screen goes white
hello
"I start in safe mode as normal."
safe mode is not a normal thing during your windows boot sequence :)
if your display works ok until those 10 minutes of safe mode are over i would say that reinstalling your windows operating system will most likely solve your monitor issues :)
Mar 24, 2010 | Princeton Digital LCD17 17" Flat Panel LCD...
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
When the computer is turned on the monitor goes to sleep mode
Go to safe mode,select boot in vga mode.
If this allows you to start,
Click start,Run type desk.cpl
Screen Saver tab | click on Energy
Under desk or office settings frame, set all values to "never".
Then click
Advanced Options, you'll see a frame asking you what to do.
Just select the options to turn off sleep mode.
check that out.
If you can't start this way,you need to try another monitor to change the setting above.
Please rate this a fixya
Feb 14, 2009 | Computers & Internet
Monitor in power saver mode
try to restart your computer in safe mode and see if that affect the monitor, also you may have the setting to go into hybernation quicker, to save the most energy, check those settings
Jun 06, 2008 | Computers & Internet
Monitor
Boot up using safe mode, then check the display properties for the Energy Monitor Power settings under the Screen Saver tab.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Thanks!
Dec 11, 2007 | Computers & Internet
Analogue LG Flatron
the monitor is working ok if it goes to safe mode with no input.which do you turn on first?(to work out which could be faulty)It is most likely that the monitor data cable is the fault(at either end) or the PC m'bd disp skt,try pluging an add on disp'card in to the PC. Regards Chook.
Apr 24, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
E-Machines eMachines T3830 PC Desktop Logo
49 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
