Question about Philips 150S (White) 15" LCD Monitor
My philips lcd monitor 150S is failing me. I switch it on and then it shows and after few seconds the screen is black (meaning its off no picture) Then I off it and on again and then got picture for 2 secs then no more with switch still on, I off it and then on again and then the pic came for a few secs and then no more..Kept trying and trying but the picture would not sustain. Pls tell me what is wrong with my monitor.
    Problem Solver:
  • 6 Answers
Check connections are good. Check pins in plug. Check with another monitor. Check with another cable.
If all tests are satisfactory then replace faulty monitor. End of life!
Posted on Jul 13, 2017
3 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: helpme please
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Posted on Aug 25, 2008
  • 732 Answers
SOURCE: Philips 150S screen turns on for 1 sec. and then
nyounger4242, Very common problem!! learn to do flashlight test to evaluate "switch-mode-power-supply" status. Read my FIXYA profile to find out all you need to know about Black, or Black and Blank lcd screen fixes and the options you have. Your monitor NO DIFFERENT than any other CCFL Back-lit LCD monitor in it's basic design and operation!! Good luck with repair. Use warranty if possible. Read, Read, Read, before you do anything!!!! 12fixlouie
Posted on Feb 04, 2010
Testimonial: "Thanks,I did not think to use a flashlight"
I have monitor Philips 150S. It is increasing brightness up to 100% when switch on the monitor and unable to remove that brighness picture. Monitor hot keys also not work. I pluged this to a lap top but...
mohanjith, First thing to investigate is the lcd monitor internal power supply for failed electrolytic filter capacitors on the power supply circuit board. If swollen and leaky, then you might try to replace the bad ones with new ones. Visit YOUTUBE for video clips to see if you can do the investigation/repair. Search YOUTUBE using "lcd monitor disassembly" and "lcd monitor repair"!!! Lots ov video clips to learn how to do DIY repair. 12fixlouie
Nov 10, 2010 | Philips 150S (White) 15" LCD Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
Black screen
At this point I believe there are failed caps in your monitor.
http://www.badcaps.net/forum/showthread.php?p=73310
This is very common in all LCD monitors. Did the tech just push the power switch off and on?
From my experience at fixing broken monitors of all brands, I think it is the power supply problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
You can get second help from repair shop also.
Apr 20, 2010 | Gateway FPD2275W LCD Monitor
Philips 150S screen turns on for 1 sec. and then gose dark???
Feb 04, 2010 | Philips 150S4FB 15" LCD Monitor
Screen going to black no picture, shows a few second and disappears
First thing to look for are bad caps in the power supply section, see example of failed monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 16, 2010 | HP Pavilion F1703 17" LCD Monitor
Screen size
I think you will get an answer hre
http://ubuntuforums.org/
Oct 03, 2009 | Philips 150S (White) 15" LCD Monitor
I have a Philips 19" Lcd When i swithced it on everything was fine until about 5 seconds later the screen went black. I have found that if i switch the monitor off and then on it works ok until...
A 19" Philips LCD prefers a setting of 1440X900 if you are too far off this it will turn itself off.
Right click on the desktop, go to settings and set it to 1440X900 and then go to advanced and make sure the refresh rate is set to 60 Hertz. Shining a flashlight on the screen will help you see.
There other thing that might be causing this is the setting on the monitor itself. Press the Menu button on the LCD and adjust the brightness and contrast.
If all else fails, contact Philips. This is a premium brand and it comes witha 4 year warranty.
Oct 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
IC POWER CM2017 LCD MONITOR
Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
Jun 24, 2008 | Gateway FPD2275W LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
It started failing, now is dead.
If it is over a year or so old - simply replace it There are usually no economic repair solutions.
Jun 15, 2007 | Philips 150S (White) 15" LCD Monitor
Philips 150S (White) 15" LCD Monitor Logo
53 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
