Question about Sony Televison & Video
Sony model kv2197M3. picture with low retrace lines .green cathode volt 50
techman
  • 3130 Answers
SOURCE: Blue Saturation with retrace lines visable
could be but there are a few checks that need to be donr first.. Try to turn down the g2 control just a bit on the flyback transformer. If no effect unsoder the blure drive transistor on the crt board If the blue is still there that means the crt is shorted and you could try to clean the elements with a crt rejuvenator and see if that helps. If the screen goes to red and green after you disconnect the blue drive transistor then you need to check the osd drivers as well as the rgb output drive from the video IC. If the blue gun in the tube shorted or leaky I have in the past and it really works a isolation transformer that plugs in to the crt socket and the other end plugs into the crt. What this does is isolate the the gun of the crt from the filiments and thats where they get shorted or leaky but for how long it will last who knows.
Posted on Mar 26, 2006
welcomejee
  • 10594 Answers
SOURCE: SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Posted on Aug 14, 2009
eagle338
  • 4889 Answers
SOURCE: philip 50pf9630a 50 inch plasma got a picture and
Yes I have seen this a 1000 times before. This problem is usually caused by capacitor plague on the sustain boards of your tv. I have recently helped a customer fix this for under 10$(by replacing the 6 100uF capacitors). Just unplug the set from the power supply and locate the boards labeled "X-Main" and "Y-Main". Look for damaged capacitors on the same . They are usually visually identifiable by means of tiny holes, cracks(at the X on the center) . If you find nothing, then let me know and we will do a continuity test to nail them(unless you just want to swap both of the boards for 200$).
Posted on Dec 07, 2010
jdvillanueva
  • 2098 Answers
SOURCE: kp-fx532m91 green blinking and followed by red blinks
10 blinks is a high voltage protection. This is why it has a retrace lines on the picture. It can't be fixed by reset or unplugging the set from the outlet because there's a faulty parts inside. It needs to troubleshoot the deflection circuitry to determine which part(s) gone bad. You need to ask for an assistance of a qualified TV Technician because this kind of symptoms is not DIY unless you have an experienced in electronics.
Also, check if you're unit is under warranty period/extended warranty, avail it because the manufacturer will fix it for free. Opening the rear cover will void the warranty.
Posted on Nov 12, 2011
  • 56 Answers
SOURCE: sony KV-27FS120 ,no video
open resister 18k locatio r584
Posted on Nov 16, 2011
Sorry if this posts twice. I think I might have posted an ealier question in an improper area. I have a Sony Wega 32" Trinitron Model KV-32F S200 (Year 2003) Recently, I've been getting a Green...
Hello
There are two causes for this problem. One is related with green output transistor, and the other is to chroma Ic. The most common cause is with the transistor said above. You just check the video output voltage points at picture tube base board. There are three cathodes may be marked as R,Gand B. In trinitron picture tubes, these pins are pin number [8 Blue KB], pin number [9 Green KG] and pin number [10 Red KR]; and the voltages must come approximately equal to KR=154, KB=155, and KG=163, and the main video output voltage goes to these transistors will come around 225VDC. These are not accurate voltages tor refer. It may vary by 2% to set by set. All the three transistors used will be identical in number, and usually found 2SC3271N. In your TVs case, green cathode voltage may be very low from the fault stated above I thinks. When cathode voltages goes low, emission of that cathode will increases, and colour of that cathode will be predominent. You just check these voltages, and check the main video input voltage said above too. There are three resistors of 2W fitted to the the main video voltage and collector of each transistor said above; and if any one,say the resistor fitted to green output transistor collector is faulty, or open or loose sodered, the voltage at the green cathode [pin-9] will be low causing this problem. If the transistor said above gor a leak with collector to emitter will also may the cause.
Just check it. Normally this base card of Sony TVs are marked C board. If all the transisors are found okl, and still the problem perisits, the fault must be in the Chroma Ic. It may need replacement.
In practice,I found this fault to be due to bad solderings in the base card. You just check it first and go forward.
If any doubts, contact me through Fixya. OK.
Nov 10, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
There are re-trace lines across the CRT.
check the G2 ,if to high retrace lines wil be vissable.If ok check the RGB,12V on picturetube panel.
Are the lines in one collor then check the circuit of theat collor
Jul 27, 2009 | Televison & Video
Tip
White Raster with thin lines; Sound Ok.
White raster with retrace lines: No picture, Sound OK
(picture tube based telivisions.)
It is a common fault to occur in most of the CRT based telvisions, regardless of which brand it is. There will be sound OK, and a bright screen with thin white horizontal lines across; at about an inch space, all over the screen area. This fault may occur along with colur shades also, like blue screen with white retrace line, red screen with white retrace lines, green screen with white retrace lines. Let us take the first case. A white raster with white thin retrace line acorss the screen. These are call vertcial retrace lines technically. To make it mor understand, we have to go to some picture tube electrode details. There are three colour cathodes for a colour picture tube, Red, Blue and Green. Two girds are there called Focus and Screen. Focus grid is supplied with focus voltage which in turn determine the cocus of picture, and screen grid is supplied with screen volrage which determine the emission of the picture tube; in short. There is a final anode to all the picture tubes, which supplied with Extra High Tension voltage, can be located at the top side of the picture tube, to which the EHT voltage from LOT is connected with the help of rubber ****** and clip. Without these three voltages, EHT, Screen and Fcous, no raster will be produced. Therefore in our case, there is a raster, so, horizontal output section including Line Output Transformer [LOT] is functioning well, and as far as sound is there, tuner and video IF section are working well. In fact, all other section except, video output section is working properly.
There are three cathode points on the base card, marked as Bk, Rk and Gk. Check the voltages of these three cathodes. In our case, it will be very low or approximately equal to zero. When cathode voltages goes low, emission of the CRT increases, is the reason. There must be a voltage between 120 and 135VDC at these points. Find out the reason for this voltage drop is the next step. The video drive voltages in most TVs comes from LOT windings, after rectification and filtering. There will be one reisitor of low value, say one Ohms or so, will be connected series with this winding, in between diode and winding. Check the voltage at the cathode of this rectifier diode first. If found low replace the diode and the smoothin capcitor. The smoothing capacitor will be between 33 and 47MFD 250VDC rating. Replace both of them. If there is volatge, say 200VDC or so, check whether this voltage comes to the CRT base board or not, If not, check the conducting wire, serial resistors; if used for open. There is no chance of transistor shortage at this time as the raster we see is white. If raser we see have a specific colour predominent, that is green, blue or red, check the revalent video out transistors and replace it. It is best to replace all the three video output transisors at the same time with same batch and number.
on Apr 18, 2011 | Televison & Video
Sir ihave philips tv 21PT94M tv will goes stand by & green retrace lines plese solve problem
pls check 180v dc from Eht or SMPS
[2]Video transister is sort or open if yes then replace
[3] Green cathode and filament is sorting in inside pictur tube.if yes then
STEP:
1. filament voltage is less then normal
2. tube charging mathod to solve this problum.
Jan 22, 2010 | Philips Televison & Video
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Thanks.
Aug 14, 2009 | Sony Televison & Video
Have 46 samsung dlp that has green lines all over the screen . menu still works but doesnt go away on the menu mode. the green is so thick that you cant see any picture in the background.
Red, green, or blue retrace lines ( a quote from "Notes on the Troubleshooting and Repair of Television Sets", found at http://www.repairfaq.org/sam/tvfaq.htm#tvrgbrlin )
Where only one color is showing, suspect an incorrectly adjusted individual background/bias control or bad part on the CRT neck board for that color.
  • Individual brightness/background/bias control(s) - mark setting of pot for the problem color and then see if a slight adjustment removes the retrace lines. See the chapter: "TV Adjustments". Of course, if this happened suddenly, the problem is not due to a misadjusted control though a dirty pot is possible - turn it back and forth - this might clean it and restore normal operation.
  • Component or connection on CRT neck board - insufficient voltage to or incorrect biasing of the video driver for this color can result in the CRT never totally blanking. Compare voltages and signals, and swap components between good and bad channels to confirm.
  • Blanking circuit - this may be a part of the video/chroma chip or separate. Check and compare waveforms of good and bad colors to determine if the blanking pulses are making it to the video output.
There is a slight possibility that a bad CRT may result in visible retrace lines. To eliminate this possibility:
  • Disconnect the filament - all evidence of a picture, raster, and retrace lines should disappear once the filaments/cathodes have cooled (15 seconds or so. If there are still visible retrace lines, the CRT is suffering from cold or field emission from someplace (may not even be the cathode).
  • Turn down the screen (G2) control on the flyback (usually). If one color remains no matter how you set the control, again there is some kind of weird emission from the CRT. However, if white/gray retrace lines remain, the problem may be in the screen supply.
(quote ends)
You will be greatly helped if you have a schematic for your TV set, and you may need to change some parts, clean some connector contacts and/or tweak settings inside the set, so remember the original settings before you tweak them...
Good luck
3rq8 (Triarcuate)
Jul 23, 2009 | Televison & Video
Sony KP65WS500 5 blinks
1st set Brightness and Contrast settings to 50% at tv menu.
You need to cover 2 CRTs with any thing like thick paper while adjusting 3rd CRT.
For example, lets adjust Red CRT G2 volts, Select audio-video input 1 and cover green and blue lens with paper note-book and rotate Screen control up to level where you see retrace lines on projection screen, now decrease screen volts (G2) so retrace lines disappear and projection screen should be blank.
Now do same process with green and blue adjustment while other lenses should be covered.
Im not sure I conveyed it to you properly or not because English is not my 1st language.
Thank you.
Sep 23, 2008 | Televison & Video
Televison & Video Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
