How do I connect my Kenwood Powered Subwoofer sw 22HT to the sterio system? There is a black cord on the back of the sterio that says it is for the subwoofer but the Subwoofer has no black cord connection to it?
4 Suggested Answers
SOURCE: Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Posted on Mar 21, 2009
  • 24 Answers
SOURCE: Connecting Powered Subwoofer to a Receiver
you will need a line-level converter to use this subwoofer- it is a rectangular-shaped box with wires coming out on one end and red-and-white RCA plugs one the other. The end with the wires coming out will hook to the receiver, and the other end will need to plug into the sub.
Posted on Feb 21, 2009
lynchms
  • 93 Answers
SOURCE: JVC - Problem connecting a Powered Subwoofer to a Receiver
Have you set speaker setup configuration to SUBWOOFER YES? Also check SUBWOOFER OUT ON/OFF button on the front panel.
I have a Kenwood sw 22HT subwoofer. It will work only when I hit it from the back. Can anyone help me find out what the problem is? Thanks!
Sounds to me like a loose connection on a wire. Take it apart and just give it a good looking over. Mainly check the speaker wires and the power supply connection.
If you have a multi tester that would be helpful, but in your
case it sounds like a simple fix.
Feb 04, 2015 | Kenwood Audio Players & Recorders
Can I connect a Kenwood sw-900 super woofer to a onkyo HT-R391 receiver home theatre sysyem
If your Kenwood super woofer is powered, look for an RCA subwoofer connector on the rear panel of your Onkyo and use that.
Dec 20, 2014 | Audio Players & Recorders
Kenwood powered subwoofer no power
There may be a blown fuse internally
Nov 16, 2012 | Kenwood SW-38HT Subwoofer
Connect a Sony SA-W3800 powered subwoofer to a kenwood receiver
Yes. It needs to know you have a subwoofer or it won't send low frequencies out to one. Then you have to calibrate its level to match the rest of your speakers. Hit the SETUP section in the manual (available at retrevo.com).
Jul 02, 2010 | Kenwood VR-309
How do i connect it to a the subwoffer sw 50 ht
on the back of your receiver is a subwoofer pre-out, connect one cable here, and connect the other end of this cable to your subwoofer - line level in. (depends on your subwoofer and receiver) but that's how mine is connected. yours will be similar.
Feb 10, 2010 | Kenwood VR-505 Receiver
My SW 22HT Kenwood subwoofer stopped working.The fuse was bad it was replaced and the new fuse blew again
The reason the fuse blew again is that an overload has occured. It could be a faulty part in either the power supply section, or the amp section. Follow the curcuit from the fuse, be on the look out for damaged, burnt parts, suspect anything on a heat sink.
Nov 30, 2009 | Audio Players & Recorders
Powered subwoofer will not work anymore
Make sure you are pluged into the sub pre out and not the six channel line in,its a easy mistake to make.
hope this helps.
CABLE GUY.
Jan 06, 2009 | Kenwood Audio Players & Recorders
Sep 22, 2007 | Kenwood VR-507 Receiver
1,081 people viewed this question
 Grubhead
Grubhead
