Question about Keurig Platinum B70 Coffee Maker
Brewer will not turn on. Outlet is working. - Keurig Platinum B70 Coffee Maker
Phone # please
Posted on Aug 01, 2010
I have a bunn 11 the problem im having is sometimes it works fine and other times the machine will turn on and off. I unplug and replug it works then continues to flicker on and off. Any sugestions.
There is a ready light (green but sometimes red) that will go on and off as the brewer heats up. It will periodically turn off when re-heating but should light when ready. This is normal.
* Bunn have red rocker switches that are sometimes lit when in use. Some do flicker but still work. Call for service if not.
* Rocker (RED) switches should have a definite click sound from the switch. these are usually the warmer plate or on/off switches. Some may flicker but you can check the warmer plate if it's working. Ask the vendor to change it the next time they come by as it still works but annoying.
* The black rockers (unlit) should snap to all EXCEPT the brew switch which tends to be mushy with a spring back. The only way to know if it works is the plate gets warm.
* Check the outlet if any other machine shows intermittent power. Some places overload the outlet and trip the breaker or GFRI so frequently most people unknowing think the power blacks out all night but really someone just reset the breaker. Have maintenance move the brewer on another outlet (and breaker) or have the breaker checked as it may be worn.
* Call your vendor anyway as there may be an electrical short or loose wire inside the brewer. Many times I've found the warmer plate wires burnt or fell off the terminals.
Aloha, ukeboy57
May 16, 2017 | Bunn Coffee Makers & Espresso Machines
I have a Keurig 2.0 when you plug it in the power button comes on, on the lcd screen but when you touch the power button nothing happens. It won't turn on. Any suggestions. Thank you.
Found the below from this site: http://coffeestylish.com/keurig-problems/
Keurig 2.0 won't turn on
To turn on your Keurig 2.0 plug in the brewer, then press and hold the power button (the power icon will appear in the bottom right corner of the touchscreen). You should see a welcome! note. If it doesn't turn on you can do few things:
Check to make sure that the brewer is plugged securely.
Unplug and plug in the brewer.
Plug the brewer into a different outlet.
As a last step, Keurig even recommends resetting your home's circuit breaker just in case.
If nothing works, then you should definitely call Keurig customer service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/josh_8e641fe76e154b02
Jan 24, 2016 | Computers & Internet
The power button doesn't work. How is this fixed?
The power button is directly associated with the main circuit board and any applied voltage or high current can disable it. Generally, disruption is a result of a power surge or outage. If power was out and came back as the brewer was on or plugged into the outlet; excessive current applied to the main board could blow sensitive electronics.
Mar 25, 2015 | Keurig B40 Single-Cup Brewer
My bunn water coning out is warm not hot
Make sure it's getting power, and that the "vacation" switch isn't on.
If on a GFCI outlet, press the RESET button - Do Not press the "test" button. If GFCI is located upstream on another outlet, or the breaker (not uncommon), try resetting the breaker or that other outlet.
If still no joy, check that the outlet is hot by plugging something else into it. If that item doesn't work either check the circuit breaker for that outlet by moving the lever all the way to the Off position, then back to the On position. You should hear a click like a light switch.
May 17, 2014 | Bunn 10 Cup Home Coffee Brewer
The outlet is working but the unit will not turn on
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 18, 2011 | Keurig B60 Coffee Maker
My machine will not power on. We have checked the outlet and know that it is working.
heatman101
Jul 21, 2011 | Keurig Ultra In Home Single Cup Brewer...
We have had our Keurig Limited Edition B 66 Keurig brewer for almost a year. Worked fine until now. The Power will not turn on. We tried plugging other things into the same outlet & their is power;...
Sorry to read about your problem, I hope this helps you out.
It sounds like you unit has a major malfunction. and they do break
Keurig does not make repair's or carries replacement parts for their units. you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Keurig B50 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
70 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
