The belt has slipped off my Matsui washing machine how do i get it back on
5 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: need instructions on how to change the belt in my washer
you have to take back off,,always unplug first..thats it just remove back take screws out all the way around back,,put belt on motor than spin drum pully...
Posted on Jan 06, 2009
  • 212 Answers
SOURCE: belt slipped off machine
rotate pulleys while trying to reinstall belt. if belt slipped off on its own then belt is streched out. replace belt
Posted on Jun 20, 2009
Dissolu
  • 221 Answers
SOURCE: Hotpoint Aquarius WMA32 - belt slipping off?
Probably it wasn't fitted properly. make sure the belt is tight when fitted, and at least 2 groves from either side at the motor shaft.
Posted on Jul 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: belt slipping
Try eBay for fast delivery out of country.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
THE MACHINE RUNS VERY WELL QUIET UNTIL THE FINAL SPIN CYCLE THEN FROM THE BACK OF THE MACHINE THERE IS A SQUEAL THAT GETS LOADER AS THE SPEED PICKS UP
This may well be the drum drive belt in the back of the washing machine. This belt transfers drive from the motor to the drum for both wash cycles and spinning. If the belt is slipping slightly on the pulley then a squeal may well be heard on the spin cycle and will change in pitch as the speed of the drum increases. At lower speeds (wash cycles) the belt probably won't slip. I don't personally know of this model but there is usually a tension adjustment nut/bolt near the motor to tighten the belt and stop it slipping.
Dec 26, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
I have lost the instructions for Matsui M100wm09 washing machine
try: laundry.manualsonline.com/.../matsui.../washer/matsui-m100wm09-o...
Feb 02, 2012 | Washing Machines
How do I change a broken belt on washer
With most machines the back case comes off and its simple to do /Belt slips over the pulley then onto the motor Shaft, with some machines you may have to loosen the motor to adjust belt tension, making sure belt will not slips or be too tight which could result in bearing stress..Good luck
Feb 19, 2011 | Maytag EPIC MFW9700S Front Load Washer
A belt came out from under my washing machine...how do I place it back? It wont drain nor will it spin.
Check the pump to see if it turns free then just slip the belt back on there. No tools needed.d75c0a7.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 10, 2010 | Admiral AW22 Top Load Washer
Washing machine won't turn back and forth
Most likely your drive belt has slipped off. Open up the back of teh washer and see if the drive belt has slipped off and ease it back on with a screwdriver.
Jun 29, 2009 | GE WSXH208A Front Load Washer
Belt slipped off machine
Jun 20, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Need instructions on how to change the belt in my washer
Jan 06, 2009 | Washing Machines
Kenmore washing machine
the belt is slipping if this model still has belts.
lean/tilt it back and look under for belts.
its the belt in the center
Feb 29, 2008 | Kenmore 24032\24036 Top Load Washer
Servis washing machine belt slips off when on spin cycle
You dont stated the brand and model of your machine so all I can say is yes change the belt allways when this hapend to one of my client I change the belt becouse the belt is waring off and loose its trech condition loosing flexibility and slipping out wen ist run at high velocity....good luck and rate me....
Feb 17, 2008 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
