Question about Refrigerators
Helloi have a Maytag Plus side by side refrigerator (about 10 years old) and I'm having trouble keeping the refrigerator side cold enough. This unit has dual slide bar controls on the ceiling of the refrigerator with settings from 0 to 9. I've set the refrig bar to 9 and the freezer bar to 4 or 5 and the refrig is just cool and the freezer is freezing but just barely. any help you could provide would be most appreciated. regards tim kotschwar geneva ne
    President:
  • 2,468 Answers
Remove the rear panel inside the freezer,your evaporator coil is iced over and cant transfer cold anywhere,deice it,then check the defrost heater under this coil,its probably open and cant heat to defrost the unit
Posted on Jul 28, 2010
MAYTAG SIDE BY SIDE MSD2650KEU
Check to see if the compressor is running and hot. Post back your results.
Dec 05, 2012 | Maytag Refrigerators
Hello, Problem with Maytag plus Side by Side refrigerator model MZD2766GE.The Freezer part is working fine but the fridge part is not cold at all even after I adjusted the temperature to number 8. I do not...
You most likely have a defrost heater and/or defrost term switch. (switch is built into heater on your fridge).that needs replaced causing your coil to completely freeze up and blocking cool air flow to fridge side. Here is the part you need to order.
http://www.appliancepartspros.com/part_details.aspx?part_id=4069923
Thanks, Randy
Feb 07, 2011 | Maytag MZD2766G Side by Side Refrigerator
K68625FJBL01 KitchenAid Sidebyside Refrigerator Freezer compartment was not cold yesterday so I cleaned the dog hair off the coils and the freezer is still warm and fridge side is not cold enough now. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Maytag Plus side by side refrigerator stops cooling. I unplugged it for 24 hours. When I plugg it back in, it works fine for about 2-3 months. Then it stops again and works fine after being unplugged for...
Take food out of the freezer, take out the racks, take off the back panel on the bottom/back ( probably 4-6 screws).. You will see a fan. If that fan has ice around it, then take it all off, chip it, hair dryer, what ever you want. Unplugging it for 24 hours is not enough for all of the ice to melt so it is probably taking a couple months to build back up. Generally this happens in a high humidity time of the year. It will probably happen again, do not freet. Just clean it again. I know one customer that had it happen two years in a row and that was about four years ago. He has had the unit (Maytag Plus side by side refrigerator) about 10 years and is just fine with it. Little inconvience, but sometimes that is the breaks in life. Good luck.... f067b6b.gif
Nov 30, 2009 | Refrigerators
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Maytag side by side not getting cold enough
look in the back should have a fan in the bottom probably very dusty if it is it cant cool fridge clean it and it should work unplug it to clean
Jun 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
GE Selext TFX22GR Not cold enough, already changed timer, heaters plus
Hello beadaholic,
Welcome,
You said, you have a TFX22GR by GE, it has been a very good unit all of these years. Anyway, recently it stopped keeping things cold enough.
Thanks for any help! I am pretty stubborn! hehe
Laura
I wish I only could have told you this earlier on!
Laura, I feel you spent to much money on this very old and inefficient fridge.
I would love to help you repair it!
But I would be doing you a disservice if I advised you to put even one penny more in to your fridge.
A new fridge would pay for it self in only a few years. They are so much more efficient today!
Do not put anymore good money into bad.
Here is an article I just read that you will find interesting and to the point.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Please remember to enter a rating before you sign off!
God Bless, &Thank You, HUUUM
Oct 05, 2008 | Refrigerators
Refrigerator not cold
Very usual issue - defected defrost control unit - replace it and keep warranty paperwork from part supplier. :))
Jul 22, 2008 | Maytag MSD2456G Side by Side Refrigerator
Side by side Sub Zero not cold enough.
How old is "OLDER" ? If there is no frost buildup on the back wall of the freezer you could have one of two problems. On older units the compressor wears out with years of service and no longer pumps efficiently. Or it could possibly be low on refrigerant charge. ether one of these two problems is a sign that is time to update to new unit.
If you have frost buildup on the back wall of the freezer section you then would have a problem in the defrost circuit attributed to the timer, defrost heaters or defrost thermostat.
Jun 11, 2008 | Refrigerators
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
