Question about KitchenAid KBRA20ELSS Bottom Freezer Refrigerator
We have a 10 year old side by side kitchenaid refregerator and the compressor just went out.it broke 3 times in ten years so no more kitchenaid ever again for me
    President:
  • 2,468 Answers
Replace the ptc overload on the compressor body and it will run again,unplug it and get a plug in replacement
Posted on Jul 28, 2010
Strange tapping noise
forget about using youtube try googling it and see if u can get help? not sure but the compressor has a seal that separates the coolant from the oil and when it goes or starts to leak u may get weird sounds? sorry cannot help more Ive heard clicking sounds before from the compressor but it was usually due to bad relay having to do with the starting process
Feb 19, 2015 | KitchenAid Refrigerators
Have power but compressor no work
Tried unplug,replug it back in half or an hour later.Most of the time the the compressor will reset and kick in than it work again.This is a temp solution only,because most of the compressors in frig have this intermittent problems will died again because of over heat the design 24/7 plugin doesn't help especially continue of power to it.Replaced the frig if it more than ten years or replaced the compressor if less.
Sep 04, 2013 | KitchenAid KSCS25IN Side by Side...
The knocking noise is coming from inside the compressor unit,it lasts for aboat 5 to 10 seconds,sometimes a full minute.fridge is 5 years old.had this problem for the last year.
Does it do it on start up of the compressor? Sounds like the springs that hold the rotor inside the compressor are getting weak and letting the rotor touch the side of the compressor..... till it comes up to speed and levels out.... There is nothing that you can do except replace the compressor.... I would call the dealer or who ever you purchased it from and check if the compressor is still under Warranty.... If may last a long time but it could lock up tommorow too you never know...... Hope this sheds some light on the problem...
Feb 05, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Refridgerator compressor starts and stops, its a ten year old superba from kitchenaid. i want to think its a relay but if its the compressor, is it going to break the bank to fix?
check to see if the compressor is bad by putting your meter on the ohm setting. check each terminal togther and then also to ground if it beaps when it goes to ground it is a bad compressor. BUT it should beap when you check each termianl togerther. there is three leads one is start one is run and one is common. if you have contunity between these it is a good compressor. i
Jul 09, 2010 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool side-by-side won't get cold, compressor clicks on-off.
Sounds like the start relay OR the compressor is no good. Have a service tech look at it, because there may be a capacitor in the circuit, which could be dangerous for you to fool with.
May 28, 2009 | Whirlpool Refrigerators
Kitchenaid 10 year old refrigerator compressor problem
hi thanks for the question .Did the tech try a new relay if not try one if he did then you have a failed compressor. Thanks the appliance doc
Sep 29, 2008 | KitchenAid (KSRD22FKST) Side by Side...
8 year old Kitchenaid not cooling
the floor has no control over the fridgr or the way it works.you said its 8 years old youve already replaced the compressor once so maybe it time for e new fridge.
Sep 01, 2008 | KitchenAid KSRG22FK Side by Side...
KitchenAid side by side KSRE25F not working
id get rid of it personally its at least 9 years old and it sounds like the compressor may be out on it its your call
Jun 27, 2008 | KitchenAid KSRG22FK Side by Side...
KitchenAid KBRA20ELSS Bottom Freezer Refrigerator Logo
134 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
