I have a maytag neptune washer modle # MAH8700AWW and the door is opened and will not shut the lock is locked on the washer how can i fix this
    President:
  • 2,468 Answers
Try unplugging the unit and see if it resets itself after 5 minutes
Posted on Jul 28, 2010
Have a Neptune Maytag frontload washer. The door is open but the lock mechanism is locked so cannot shut the door. Is there a code for this??
try un pluging washer for 15min and plug back in to see if it resets. if not u may need new latch but first make sure u don't have a loose wire to lock
Apr 06, 2014 | Maytag Neptune Washing Machines
My maytag neptune MAH8700AWW shows an error code OE and the door is locked, how do I fix it?
Opening a locked door , click for a visual demo: Door locked#
It is possible that the actuator to the lock has failed and so is not releasing or there is a error on the control panel.
Jul 05, 2012 | Maytag Washing Machines
My Maytag MAH2400A Front Load Washer will not open. Locked inside of the chamber is a load of laundry. How do I open the door without damaging the mechanism that keeps it closed?
As I sit here with my Maytag Neptune MAH8700AWW torn apart, I can tell you it is impossible to unlock and the 800 number is no help. They tell you to unplug it for 5 minutes. Some web posts talk about a "magical release cord" under the top cover but it does not exist.
Nov 24, 2010 | Maytag MAH2400A Front Load Washer
I have a maytag neptune modle mah8700aww the door won't unlock
Getting rid of the Maytag Neptune is the only solution!
Feb 14, 2010 | Maytag Washing Machines
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune front load washer with FL code
The "FL" is indicating that the door has failed to lock or it locked but the control does not sense the door has locked.
It could be caused by:
faulty door lock solenoid
loose wire connection
faulty door lock switch
faulty door lock sense switch
bad control board
I recommend calling a service technician to diagnose and repair your washer.
but try this first just in case....unplug it for 1 minute plug back in and see if the fault code clears.
good luck.
Jan 03, 2018 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Leaking From the Door
possibly door lock not latching could be a bad wax mtr (within door lock asm) or control board
Dec 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer Maytag Neptune
Check the door lock,if the latch does not fall in place correctly the door will send the message to the electronic board that the door is open.
May 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
241 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
