Question about Dell W4201C 42 in. Plasma HDTV
How to reset the parental control code - I forgot the code and want to reset with a new one
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Posted on Jul 28, 2010
2 Suggested Answers
  • 395 Answers
SOURCE: How do you cancel parental control?
If you forget your password, simultaneously press and hold the MENU/
OK button on the front panel and VOLUME down button on the
remote for three seconds. This resets the password only and unlocks the
TV; all other settings in Parental Controls are not changed.
Page 48 of the manual.
Posted on Jan 14, 2008
Master key for parental control
  1. Navigate to the Wii Menu by pressing the HOME button on a Wii Remote and selecting "Wii Menu."
  2. Look at the date and time displayed on the Wii Menu and ensure they are correct. If incorrect, they will need to be changed in order for you to complete the PIN reset process. You will not be able to reset the PIN until the date is correct.
  3. Select the Wii Options icon in the lower-left corner of the Wii Channel Menu.
  4. Select "Wii Settings."
  5. Click on the blue arrow to reach the Wii System Settings 2 menu options.
  6. Select "Parental Controls," then "Yes."
  7. Enter your PIN or select "I forgot."
  8. Answer your secret question or tap "I forgot."
    • If you know the answer to your secret question, enter it to unlock parental controls. The system will go to the change parental controls screen and you will be able to change your PIN.
      • Be sure to enter the secret question exactly as you originally typed it, as the answer is case sensitive.
    • If you don't know the answer to your secret question, tap "I forgot."
  9. A screen will appear showing you a request code.
  10. With that request code, you will need to do a request that involves charging US$0.50 from a credit card, to confirm that you're an adult. Or should your kids try to circumvent your parental code, it will show up on your credit card bill.
You can request the reset here:
Parental Controls PIN Reset Nintendo Support
If you need further instructions on how to do that, simply look here:
Forgot Parental Controls PIN Wii and Wii mini Nintendo Support
Mar 04, 2015 | Nintendo Wii Console
Parental cantrol
Or get a more detailed step-by-step instruction here:
I forgot my 3ds pin I need a master key
There is only one way to solve the solution and that is bye calling nitendo and the number should be located on the back of ur 3da and they will give u a inquiry code i mean thell give u a pjn u type it in and it resets ur parental settings
Nov 16, 2012 | Video Game Consoles & Games
How do i unlock parental control, if i forgot my pin
Go into the settings menu, Parental controls, reset parental controls. Click through the confirmation screens, and then it will give you a confirmation code and ask you to call Nintendo.
Instead of calling Nintendo, go to this form and enter the code. Even though it was originally written for the Wii, marcan's reset code generator will give you a valid code that you can enter into your DSi to remove the parental control.
Jul 17, 2011 | Nintendo DS Lite
My parental controls have been set - not by me. Need them reset
1) Go into the Parental controls itself 2) Click "I forgot on the Pin" 3) Click "I forgot on the Secret Answer" 4) Write down the displayed 8 digit confirmation code will be on the next page. 5) Enter that code into the box at this website http://wii.marcansoft.com/parental.psp 6) Write down the code it gives you 7) Use code from step 6 on the Wii
Jun 18, 2011 | Nintendo Wii Console
I am the forgetful parent and need to reset the
1. Turn on your Wii console and go into the Wii Options Menu
2. Click on Wii Settings and click the right arrow until you see “Parental Controls”
3. Say “Yes” to “Change Parental Controls?”
4. Click on “I forgot” when it asks you to enter your pin
5. It will ask you for your secret question, click on “I forgot” again
6. The screen will read “If you have forgotten both your PIN and secret question, call the consumer service number listed in the Wii Operations Manual and provide the confirmation number below. You will be issued a master key.”
7. Call Nintendo at 1-800-255-3700 and give them the confirmation code listed on the screen. They will give you a new Master key to enter on the next screen.
8. The PIN is now reset/disabled
Aug 20, 2009 | Nintendo Wii Console
Overriding parental block code
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
May 24, 2008 | Televison & Video
Parental Control Code?
if you forgot your password you can reset it ,turn tv off press and hold vol< on tv and clear on the remote for 5 sec.,enter a new password next time you access the parental control menu.
Apr 16, 2008 | RCA F19436 19" TV
Parental control
Here is the procedure to reset the parental lock code:
  1. From the XBOX dashboard screen, go to settings and then parental control.
  2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
  3. Enter in a new password, or disable parental control entirely.
fixya!
Feb 07, 2008 | Microsoft Xbox Console
Parental Code
OR TRY THIS..
Bill
Jan 30, 2008 | RCA TruFlat 27F520T 27" TV
Dell W4201C 42 in. Plasma HDTV Logo
4,457 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
