Question about Eljer & Patriot& Elongated Toilet Bowl
I have an Eljer elongated toilet 1988 in tank and I have replaced all parts including the 2 tank bolts. For some reason I continue to lose water and have have cleaned all areas and have a new flapper. What is causing me to lose water?
    Genius:
  • 1,040 Answers
My toilet keeps leaking water and then fill ups on its own. Where could the leak be how do I fix it? Also I have to hold down the flush lever awhile for the toilet to completely flush. Can this be fixed ?...
If you are not getting puddles on the floor then it is probably the 'FLAP" that holds the water in the tank. It is the rubber part that is connected to your handle. Any hardware store will carry that part since it is an item that will fail, especially in hard water. It is probably the cause of both problems.
Jul 25, 2011 | Eljer & Titan Elongated Toilet Bowl
I need a Toska toilet seat replacement
Toska seat is called Manarque seat, for the Herbeau toilet.
I searched for square toilet seat.
Site shows toilet seat for the Herbeau $135
http://www.bizrate.com/miscellaneous/herbeau-toilet-and-toilet-seat/
http://www.faucetdirect.com/herbeau-0651-monarque-elongated-toilet-seat-with-cover-and-finish-matched-hardware/p671327?source=shz_671327&aid=228165868
Pdf from Eljer showing Tosca toilet looks very similar to product shown on links above.
1.6 gallon water-saving flush tank.
http://dallas.eljer.com/Products/Toilet/CatalogPage/0912000.pdf
Dec 14, 2010 | Eljer Toilet Seat Tosca 124200000
No water in bowl
check the water stopper in the bottom of the tank is it closing all the way.
Apr 25, 2010 | Eljer & Elongated Toilet Bowl
The toilet continues to run after flushing, i.e.e
The fill valve is stuck on and needs replacement, checking this part every year is a good idea.
Mar 27, 2010 | Kohler K-3384-2 San Raphael Elongated...
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
I have 40 year old eljer toilets seat cracked,
This website appears to have what you need
http://www.plumbingsupply.com/eljertoiletparts-patriot.html
Hope this helps?
Jan 20, 2010 | Eljer & Patriot& Elongated Toilet Bowl
Actuator/lever is broken
well there is a ring just 2 inch up from butim of tank on the fluhmater ....you can twist it up and adjust your water
Sep 28, 2009 | Kohler K-3422 - Wellworth Elongated...
Eijer toilet shooting water out of the tank
There is a shut off valve under the stool. turn the water off and go to walmart and get a new valve. Take the one out of your stool so you get the right one. hope i was helpful
Aug 27, 2009 | Eljer & Patriot& Elongated Toilet Bowl
Describe your Eljer &
I have not heard of any toilet manufacturers offering a lifetime guarantee (except maybe for defects in manufacturing), especially since flappers tend to deteriorate with exposure to chlorinated water, fill valves eventually fail, and toilet seats do break. Pick out a replacement that suits your fancy, unbolt the old one from below, and install the new one. Don't overtighten as the porcelain could break.
Jul 17, 2009 | Eljer & Patriot& Elongated Toilet Bowl
In the tank, when I flush, water comes shooting out of the black plastic thing, about 2 feet high! How can I make this stop so it flushes properly again? (its an eljer 2001)
is the black thing between the the tank and the bowl?
if so, go to any of the home center or plumping store for the seal.
shunt off the water and unbolt the 3 bolts that holds the tank to the bowl from the buttom. you may need a flat screw driver to help hold the bolts. pull up the tank slowly, and lay it on the side, replace the seal, reseat the tank on to the bowl and tighten the bolts. make sure all bolts are equal pressure and the tank is level.
May 05, 2009 | Eljer & Patriot& Elongated Toilet Bowl
Eljer & Patriot& Elongated Toilet Bowl  Logo
64 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
