Question about Admiral Washing Machines
Sirs: Admiral Capacity Plus, heavy duty, during rise cycle did not shut off filling with water. Flooded laundry room. Shut-off incoming water and finished cycle, water spun out okay. Is there a sensor or selenoid which could need replacing? Thank you for your assistance. Terry at ru_kc2@yahoo.com
  • Admiral Master
  • 8,220 Answers
Easy fix. Remove the control panel dust cover and look and see if that small hose is attached to that water level switch.Sirs: Admiral Capacity Plus, heavy - 1799041.jpg It may have vibrated off the switch. Air pressure is wat makes that switch work. If the hose is on there remove it and blow through it to remove any sediment that may be blocking the air. Reattach it and pump out the washer. Retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 28, 2010
My admiral washer does not work on wash cycle. It will rinse and spin on any cycle but wash
hi Marilyn.
this is what i have found but not sure if this will help you out,if not go to the link at the bottom and see if it helps you out.
Step 1
Make sure the washer's cord is plugged in to a functioning outlet if the Admiral washer won't fill with water. Check your circuit breaker to make sure the power is on and reset it if necessary. Reset the dial and start the washer again. Turn both of the washer's faucets on to full power. Untangle any inlet hoses to remove clogs. If this doesn't work, your hose filter screens could be clogged. Disconnect the hoses from the washer and clean the screens of any residue.
Step 2
Close the washer's lid completely if the Admiral washer will not agitate. The washer will not start if the lid is open. Restart the washer by setting the control dial to the desired cycle. Momentary pauses during cycles can be expected. You may need to wait a minute or two to see if the washer starts. Check the circuit breaker to make sure the washer is getting power. Reset the circuit breaker if necessary.
Step 3
Check and reset the circuit breaker as above if the Admiral washer will not spin or drain. Untangle any of the washer's hoses to allow water into the machine. Check your drains for clogs that may be preventing water to move into the washing machine. Close the lid and restart the washer. The washer will not start if the lid is not completely closed. If there are excessive soap bubbles in the washer, the washer may have locked up because of this. Wash the load again without adding detergent.
Step 4
Rearrange the laundry so it is evenly distributed if the Admiral washer stops or if laundry is still wet at the end of a cycle. Untangle any laundry from the center post in the wash tub. Select the correct water level for the amount of laundry. Select a normal spin cycle for jeans, towels or other heavy loads. Close the lid and start the washer.
Step 5
Check the hoses to make sure they are tightly connected to the Admiral washer if it leaks water. If they are loose, tighten them with a screwdriver. Make sure the drain hose is secured to the drainage area. Avoid putting too much laundry in your machine or soaking laundry for over 30 minutes.
Step 6
Make sure the Admiral washer is on a level plane if it is excessively noisy. If it is not on even ground, move the washer so that it is level. Remember that some washer noise is normal. Thin floors can cause the washer to vibrate and move about and the noise level may rise and fall depending on the speed of the cycle.
admiral washer does not work on wash cycle Google Search
Nov 25, 2017 | Washing Machines
Heavy duty super capacity plus
Check water level switch and associated hose, see my other posts on this solution.
Aug 19, 2013 | Admiral AW22 Top Load Washer
I have an Admiral 20 lb. capacity heavy duty washer, not sure what model. Machine fills up with water but does nothing aftet that, all controlls seem to work fine. Before this issue it would rinse and in...
There should be a module that does the agitation bit for the washer motor(Spins one way shuts off and reverses the spin etc) There may be a capacitor under the control panel that is not working any more so the motor will not start.
Jun 04, 2013 | Washing Machines
I have an Admiral Heavy Duty Super Capacity 2 speed washer. It works great except that it takes forever to fill (3hrs!). I've taken to filling by hose each cycle. Am in a rental so don't have the...
low water pressure..... stopped up or kinked up water inlet hoses.......stopped up water fauset at machine......stopped water filter,s at machine ,,, or at water valve.......or bad elec water valve at machine
Mar 16, 2011 | Maytag Washing Machines
Water not shutting off to begin wash cycle flooded room
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Jun 01, 2009 | Washing Machines
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Washing Machines Logo
153 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
