Question about Bestec ATX-1956F (ATX1956F) 200-Watt Power Supply
Power supply unit gets power as light on the back shows but pc wont turn on. Have tried differnt PSU and pc turned on but have had unit checked and they said the PSU is working fine. Cant fit standard PSU as wont fit in case.
  • Anonymous Mar 16, 2014
    light on PSU flashes and wont power up unit
    Problem Solver:
  • 14 Answers
Try this to get it at-least back on with your PSU that fits in the case. open up your computer case, locate your power supply. With the AC cord still plugged in , unplugged the connectors to your motherboard from the PSU and wait about 10secs. Then replugged them in. This should power on your PC.
Also, You wanna check around where the PSU connects to the motherboard and make sure there is no damage. No burning,Discoloration anything that could be potential damage.
Hope this works atleast to get the PC booting up.
Posted on Jul 28, 2010
PC Power Issue
It does sound like a psu problem, if you are comfortable with opening your pc then (remember to use anti static wrist band rubber matting etc) and remove the psu and give it a good dusting (as the dust does collect in on the fan and inside the unit itself (please be careful when working with this unit as it is a power unit and can be dangerous) put unit once cleaned back into the pc making sure you reconnect everything carefully. (if you are not sure rather take it to a professional as you can do some serious damage to your mother board and or peripherals. but this should give a few more boot ups ultimately you could replace it with a new PSU.
Nov 09, 2014 | CORSAIR CX Series Modular CX750M 750W ATX...
Lights up but wont turn on
1. disconect the graphic card & the ram cards clean the slots and the matherboard with compresed air and plug it all back...
2. chack that the psu give you the right corents if not replace the psu.
Dec 15, 2013 | HP Pavilion Computers & Internet
My computer wont start up. The power supply light flashes green when plugged in then red. But still nothing , can someone please help?
Try a Power Supply Unit (PSU) Reset: Unplug the electrical cable from the wall and the PSU (Back of Computer)
Move the red voltage selector to the opposite position it is in and then slide it back. If you live in the USA 120Vac to 220Vac back to 120Vac
After you have done this you can plug the power cable back into the PSU. Connect the power cable to the wall power. If the PSU is still serviceable it will no longer be blinking.
2c170cb8-7c41-4ef0-8a3f-ff232e57320e.jpg fd10abb2-6218-42f0-8857-b761fffbcecd.jpg
Jul 08, 2013 | HP Compaq Business d530 PC Desktop
Standby blinking green button went off and now cannot turn on. cord connection ok and eveything unplugged that might interfere
I guess your power supply died. try to disable the power supply and enable it again (switch behind the tower) otherwise you should get it checked out by a professional.
Mar 02, 2011 | Dell Dimension 4700C PC Desktop
Pc power supply,
Must be a poor quality PSU. Sometimes it can be rebranded. Try another PSU. Sometimes a PSU takes out a mobo too
Jun 07, 2010 | Dell 2400 550W Power Supply ** FREE **...
Pc wont start no power, power getting through to
Get the connections checked on the Motherboard.
Possibly the Power Supply Unit on its way out....WARNING....do NOT open the casing of the PSU....dangerous....just replace with another
Jul 11, 2009 | Alienware PC Systems Alienware Area-51®...
The tower wont turn on
Check your power supply. Most common reason for your problem is that the psu has died. Also near your main psu connection on the motherboard should be a little led light. If your board is getting a proper power connection/supply that light should be green. If not it will either be off or red. If it is green then the problem may be your motherboard. If it is red or off then it is most likely a bad psu. Replace with a compatible psu & you should be back up & running. Hope this helps.
Jul 02, 2009 | E-Machines eMachines Desktop PC
Power supply for Philips HEPC 7501/05 failure, can't start my pc! where can I find similar products to replace it?
hi zibby,
power supply are you sure of this,when turn on is the fan inside is not blowing,it easy to replace psu,my power supply is 4 1/2 years before i replace,the price of this made in china more or less $30.00.the important on specification is capacity how many watts
your psu.check on www.psuebay.com
on frigure as sample disconnect psu besure power off and disconnect all connection at the back of cpu.open cover of psu
two quick lock in bolt loosen and slide off cover,
on psu there are multiple colors cable that are supplying your
mother board and others devices such as cd room,floopy anf hardisk, pull out or disconnect supply cable on mother board and other devices,then at the back side of cpu beside psu there are 5
screw loosen this and pull out your psu(power supply unit).then if you have new one just reverse the process of disconnecting psu on connecting back new one.
have anice day,rate me if your satisfied to my solution,thanks a lot.
Apr 29, 2009 | Computers & Internet
No power
Kindly check the cable that is put in your PSU or on/off switch. Maybe you accidentally put it off. If you have Multi Tester you can check the PSU (Power Supply Unit) if there is conection in your PSU.
Jan 18, 2008 | Computers & Internet
Bestec ATX-1956F (ATX1956F) 200-Watt Power Supply Logo
159 people viewed this question
Top Bestec Computers & Internet Experts
Lawrence Oravetz
JonSnell Electronic
JonSnell Electronic
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
