My pc don't read/pick uo the usb ports, it reads the device, but says it does not recognize it...... its an intel sis 968 bord running on xp home with spack 2, I've formatted the pc, but no luck
  • 415 Answers
Try downloading intel chipset software from the official site it may help.
Posted on Jul 28, 2010
I WANT FULL INFORMATION 15 K86 011000 671T MV.1.0 MOTHERBOARD?
CPU ? LGA775 socket for latest Intel Core 2 Duo / Pentium D / Pentium 4 / Celeron D processor
? Supports Hyper-Threading Technology CPU
CHIPSET ? SiS® 671 & 968
? North Bridge: SiS® 671
? South Bridge: SiS® 968
GRAPHICS ? SiS Mirage 3 graphic engine
? Share Memory: Maximum up to 256MB
MEMORY ? Single-channel DDR2 memory architecture
? 2 x 240-pin DDR2 DIMM socket support up to 4 GB
? Support DDR2 667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS.
For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
EXPANSION SLOT ? 1 x PCI Express x16 slot
? 1 x PCI Express x1 slot
? 2 x PCI slots
STORAGE ? Support by SiS 968
• 2 x Ultra DMA133/100/66 devices
• 2 x Serial ATA 3.0Gb/s devices
• RAID0 & RAID1 configuration
AUDIO ? Realtek ALC660 6-channel audio
? Compliant with HD audio specification
LAN ? Broadcom AC131 10/100 Lan Phy
REAR PANEL I/O ? 1 x PS/2 keyboard & PS/2 mouse connectors
? 4 x USB ports
? 1 x VGA port
? 1 x Serial port (COM1)
? 1 x RJ45 LAN connector
? 1 x Audio port
INTERNAL I/O CONNECTORS & HEADERS ? 1 x 24-pin ATX Power Supply connector
? 1 x 4-pin ATX 12V connector
? 1 x IDE connector
? 1 x FDD connector
? 2 x USB 2.0 headers support additional 4 USB 2.0 Ports
? 2 x Serial ATA connectors
? 1 x CD in header
? 1 x Front panel audio header
? 1 x Front panel switch/LED header
? 1 x SPDIF out header
? CPUFAN/SYSFAN connectors
SYSTEM BIOS ? AMI BIOS with 4Mb Flash ROM
? Supports Plug and Play 1.0B, APM 1.2, Multi Boot, DMI
? Supports ACPI revision 1.0 specification
FORM FACTOR ? Micro-ATX Size, 244mm*220mm
Dec 21, 2014 | Computers & Internet
Hi sir; I have a pc with intel d845wn mother board.It is not supporting usb 2.0.What can i do
You may be able to upgrade the BIOS firmware so it can support USB 2.
You can download the motherboardBIOS upgrade and device drivers from Intel WEB site. Select your
model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers
thatmatches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Apr 29, 2011 | Intel Desktop Board D845WN Motherboard
Ethernet controller
IF YOU ARE ASKING FOR A DEVICE DRIVER FOR YOUR ETHERNET CONTROLLER
THEN FOLLOW THESE STEPS
S1 NEAR THE FRONT USB PORTS A BLACK SITCKER YOU WILL SEE
S2 READ IT MT-M 8177-75G THIS WOULD BE YOUR MODEL NUMBER 81777 USUALY UNDER THIS CONFIGRATION AS YOU HAVE TOLD THIS MODEL NUMBER IS ASSOCIATED IF NOT THEN READ WHATEVER IT IS
S3 http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Network+Connectivity&ProductLine=Intel%C2%AE+Desktop+Adapters&ProductProduct=Intel%C2%AE+PRO%2f100+VE+Desktop+Adapter
DOWNLOAD THE DRIVER NETWORK ADAPTER DRIVER FOR WIN XP
Feb 04, 2011 | IBM Netvista Intel Pentium 4 2.4GHz /...
I have Windows XP. I connected the hard drive according to the directions and the first message read USB device not recognized. The second message read Try reconnecting. If windows does not recognize it...
If it is a desktop computer, try connecting to one of the rear USB ports. sometimes drives won't be recognized properly from a secondary USB or HUB. If it's a notebook go into control panel and see if you can find and delete unknown devices in hardware then attach and see if it connects. XP should not need a driver install.
Aug 24, 2010 | Computers & Internet
I need driver help, yes i am a idiot
No your not.Go to microsoft web site or use the built in Windows Update on your computer.If you haven't downloaded the update tool it will ask you to install it.After it installs the update tool, run it.Pick the updates you need lnstall them some will require you to restart.Later check the automatic update feature to check for updates.Other updates will be from the manufacturer or your PC,check for their updates.Software from their sites.This is not hard.If I were you I would buy a general book on XP you can learn easy steps to keep your PC up to date and won't have to ask anyone (except FixYa.com) good luck
Sep 05, 2009 | Computers & Internet
USB suddenly malfunctioning on Dell TOwer
It does sound like your ports on the front might be bad. They usually connect to a seperate port on the motherboard than the rear ones, and I have seen devices short out the front ports, such as a USB music player.
You can remove the ports on the device manager, and they should come back ok, without worry. However, I doubt that is going to help the front ones. I think you have a hardware problem.
If that is the case, the easiest solution is to get a USB hub, and run a USB cable from the rear, to the front of the computer.
Mar 28, 2009 | Dell OptiPlex GX260 PC Desktop
UPDATE AUDIO DRIVER
if u have windows vista then download this
http://dlcdnet.asus.com/pub/ASUS/misc/audio/Realtek_Audio_V6015473_vista.zip
For Win XP download this
http://dlcdnet.asus.com/pub/ASUS/misc/audio/Realtek_Audio_V51005473.zip
PLS RATE ME FIXYA if i have fixed ur problem
Mar 02, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Dell 1525 the problem is the usb device not recognize un able to read the external( flash ram , hard,printer,DVB, usb mouse)
Goto Device Manager and uninstall everything under USB headings and reboot the computer.
XP and Vista will reinstall the generic drivers for the usb ports.
To access Device Manager;
Hold the
Windows key + Pausebreak
Hardware
Device Manager
Feb 11, 2009 | HP Pavilion DV2911US Laptop
USB Ports not recognizing installed devices
did it come with xp pro or home? pro does'nt have the drivers that home doe's. use a home disk to update the drivers with
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 26, 2007 | IBM ThinkPad T42 Notebook
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
