Question about Kenmore 44423 Side by Side Refrigerator
I have a Kenmore side-by-side fridge model 106. 56586501. I'm trying to install the plastic water line (which appears to connect to the filter housing) but there are 2 connections on the housing. 1 looks bigger than the other but I was told that all line are 1/4". The larger of the 2 connections on the housing doesn't grip the 1/4" line. What gives? Thanks
  • 36 Answers
SOURCE: What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
Posted on Dec 12, 2008
SOURCE: Water filter stuck on my Kenmore Fridge
I had the same problem. I coudn't get the knob to turn. I ended up taking the front grill off so I could get a better grip on the knob. Once I did that I still have to put a lot of pressure on the knob to turn it but that did the trick. When I got it turned a quarter turn then it was easy to pull the filter out. Hope this helps!
Posted on Jan 11, 2009
peyton32034
  • 410 Answers
SOURCE: Need to Install a Supco 3 n 1 start capacitor
3 in 1 starters like the supco that you have pictured can and will cause premature failure of your compressor. newer compressors are not designed to handle the start up current the 3-n-1 provides. I reccomend replaing wiht an original oem part the part number is 8201786. If you still want to use the hard start use the 410 model obviously hook up the red white and blak wires to the compressor the 2 left over leads will connect to the 2 original wires that come in to the compressor I beleive they are red and white. polarity does not matter. good luck Peyton
Posted on Feb 28, 2009
  • 11 Answers
SOURCE: Water and ice won't work on kenmore side by side fridge
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
  • 672 Answers
SOURCE: kenmore 106 89482995- How to replace water pump?
Access will be from the rear at bottom. Pump found at Sears website at this link. Love those helpful service people !! link is long, but it works. i used copy and paste http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=10689482995&productCategoryId=0164160&brandId=0582&modelName=AUTOMATIC-ICE-MAKER&diagramPageId=00003&componentDescription=PUMP&documentId=P0306093&backToLink=Return to Sub Components list
Posted on Jul 01, 2009
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Kenmore refrigerator model# 70192001 has funny chemical tasting ice
Do you have a water filter, either inline or inside the fridge side? There is nothing in the water lines or valves within the fridge that will contribute to chemical taste. Unless it's just been connected and the line was dirty. It's either your water supply, and if so install a quality inline water filter will help. Some times if the fridge filter is clogged the water flow to the ice maker is restricted and little bubbles get trapped in the ice and they taste off. You should have crystal clear ice. If not get a filter.
Sep 26, 2009 | Kenmore Refrigerators
Moldy taste from Whirlpool side by side
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
Apr 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water leak at filter
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
Dec 02, 2008 | Whirlpool GS6NBEXR Side by Side...
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Cannot install water line
I too had to scratch my head to locate where to connect the water line for the ice maker. Looking at the rear of the frig on the bottom right you will see a white plastic cover that the black plastic line goes into. There is a screw on the right side. Undo the screw and then pry off the white plastic cover. You will see a black plastic cap over the threaded water line connector. This is where you connect you line as approprite. I hooked up the line and turned the water supply back on and then you have to turn on the ice maker. I works great. Problem is the manual is not clear at all. Guess they assumed that the installler would be hooking it up. Once you know what to do is is a piece of cake. Good Luck. Doug S. in Poland, OH
Aug 11, 2008 | Refrigerators
Water dispenser won't stop dispensing water!
Hi I dont have the knowledge of your fridge, but I'm just going to throw this idea your way , please forgive me if im wrong :)
Perhaps the problem is due to syphonage, the discharged liquids are creating a vacuum along the line.
Did you reposition the height of any supply hoses ? none of them should be above/higher the outlet source itself.
You could also try installing a inline reverse flow suppressor
(small plastic filter that only allows one-way direction of flow.
Jun 10, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser reader not responding
no water flow is caused by the icemaker valve
on the back of the refrigerator
the water line is connected to it.
if it is stuck it will not let water through to the
icemaker
May 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Filtered Water tastes "off"
Could be something foreign in the water line on the fridge side...or somewhere in the ice maker/ water dispenser inside the fridge......when it tastes stale....maybe there is something maybe mold or something that is part of the plastic ????
I usually add an in-line filter to my water line before it reaches the fridge so that 99% of the elements are trapped before it gets to the fridge. My original filter is still good. Maybe someone needs to inspect the ice maker with a a bright light and an inspection mirror to see if there is any thing that looks suspicious....this is only a suggestion but leaving the line disconnected for so long could even cause something like a small insect to crawl inside the line...
Mar 06, 2017 | Kenmore 56872 / 56874 / 56876 / 56879
Kenmore 44423 Side by Side Refrigerator Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
