Question about Dryers
Maytag Performa PYET2444AYW elecric dryer heats but drum will not spin. Can manually move drum freely.
  • egraham379 Jul 28, 2010
    Won't know until I get home and try it.
  • 6,784 Answers
HI. I suspect that your belt has failed. If you can clearly hear the motor running, but the drum dose not spin, this will confirm that your belt will need to be replaced or re-applied.
Use this instructional video to help gain access to the belt for inspection:
Posted on Jul 28, 2010
    President:
  • 2,468 Answers
The dryer drum belt has broken and you need to remove the top and front cover to replace this belt
  • danny Hendrickson Jul 28, 2010
    if the drum belt isnt broken,then it could be the idler pulley that keeps tension on the drum belt to turn the drum,or the drum motor isnt running either no power from the control board or the motor is bad
My Maytag Performa Dryer model PYG3360AWW wont turn on it just buzzes when I push the start button. what do I do to fix it?
See if you can turn the drum by hand, there should be some resistance. If its locked you will need to disassembly the dryer and see what is binding. If everything(motor,rollers,pullys)spins freely they you most likely have a faulty motor winding and will need to replace it.
Dec 21, 2014 | Maytag Dryers
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
Maytag washer tub leans to the right
I have a Mayag Washer and dryer The washer someimes spins of balance. the dryer has no heat, this just started. would it be the element?
Oct 23, 2009 | Maytag Performa PAV2200
Very loud vibration on Maytag Performa Dryer
http://www.partselect.com
Check out this site, you can go step by step thur what your machine is doing and they tell you what parts are most likely causing you the problems
Oct 07, 2009 | Maytag PYE2300AY Electric Dryer
Dryer will not turn
There is a belt like a fan belt that goes around the outer tub and onto a pulley that turns the tub, it may have slipped off, you should be able to take the top off of the dryer to check it.
Mar 19, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa runs no heat how do I access the heating element?
Well if it runs then the fuse is ok so what you need to do is pop the top and check the high limit thermostst and heating element located at the rear of the machine. The top on most of these machines comes up easilty if you use a putty knife or five in one. Be sure to disconect the power source. a12fee1.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 19, 2009 | Maytag PYE2300AY Electric Dryer
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Dec 16, 2008 | Maytag Dryers
Dryers Logo
62 people viewed this question
Top Dryers Experts
Marvin
Marvin
