Question about Maytag Neptune MAH5500B Front Load Washer
During the wash cycle the word "suds" began to flash on screen
While doing a load of laundry the word "suds" appeared on the screen
    President:
  • 2,468 Answers
You need to cut down on the amount of soap you are adding per wash,run an empty wash to purge any residual soap from the tub,then use less soap there after
Posted on Jul 28, 2010
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
SUD AND F-35 PROBLEM
SUD= The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future
As far as F35. Check your owners manual to see if its in there. Also if you remove the top lid ( a couple screws in back hold it in place) and check inside you will get the technician diag sheet which will have codes.
Jul 28, 2011 | Maytag MAH6700AWW Neptune Front-Load...
The water is still soapy after many rinses. I am using very little soap
I am having the identical problem with a Maytag washer! The first 2 or 3 rinses are effective somewhat, (but not like the Whirlpool I had for 22 years) and I think, "one more for fabric softener"---but suddenly I have a full inch of bubbly white, white, very soapy suds! Picture half a washer of water with a cup of tide! It's that soapy and I cannot figure out where the soap is coming from! Tonight, I had not even used a regular soapy detergent in the previous 15 cycles, having switched to an eco detergent from Costco and used little. I even ran a few cycles with no laundry and no detergent--no soap then!
Btw, the washer has only cold water rinses--I had not noticed the tiny print on the front of the washer--or I'd never have bought it. We learned in fabric class that icy cold water (it's snow melt here in Oregon) shocks fabric as badly as hot water, and it fails to get soap out as well. And everything comes out scratchy stiff like cardboard, and hurts my face--skin even peeled before I began opening lid to check on rinse cycle. I got rashes and dry skin from all the soap and ice water...until I began doing 7 or 8 rinse cycles on the items like washclothes, towels etc. Clothing gets hardly any soap, or I hand wash it now--am exhausted and want new machine! Can't sell this junk tho.
Anyway, so the way I rinse with warm or cool (not melted snow) water is I stop the washer and start over the wash cycle to get warmer water for the rinse. Then, I move the dial to extra rinse cycle for the rest of the rinse, after the water has filled, so it cannot go on to do an ice water rinse after competing the "wash" cycle that's really a rinse cycle with no soap.
I would hurt the person who designed this washer! It seems to add soapy water back into the rinse on the 4th rinse cycle! Sounds bizarre, but I always think that everything is finally rinsed ok and one more with a little fabric softener will do it, but when I look inside to add the downey, there's an inch of suds on top! I don't have suds like that on my wash cycles! It's bizarre...I've wondered if neighbor's suds are coming in, or am I haunted?
Last week, I hand-rinsed my washcloths and kitchen towels and put them in washer for the spin cycle, at end of the rinse cycle, just to get water out of them for dryer.... To my dismay, the spray of water while spinning (have no idea why washers add icy snow melt to my warm rinsed laundry during the final spin but they all do, you can hear the spray) was soapier than my original wash cycle--which has a teensy bit of suds which is gone in a minute or 2! Honestly, my washcloths etc were fully soapy again! I'd rinsed them so well that immersing them in warm water left the water clear and clean, but after the spray, they were just as soapy as after the earlier rinse cycles that had the inch of suds... I had to take everything out and spend another hour hand rinsing and wringing befor the dryer....
I have taken to using pint-sized tupperware to get the suds off the top rather than letting it go into the laundry or washer. I skim it out and put it down the kitchen sink. It's so soapy I'd have to do dozens of rinse cycles to rinse it out, so I skim it out manually. So new soap must keep getting into the washer! It also does not seem to matter whether the wash is full or half. Tonight the previous rinse cycle had been full, and pretty clean. But when I o;pened the next one to add fabric softener, it was only half full of water, and an inch or soap suds. I had wondered if the soap was outside the basket, and came in through the holes, once water got that high, but no. Does not matter. And I had wondered if it was caused by suction from stopping the rinse cycle during spin...but I went load after load for 10 days, never stopping a cycle early and it still put all that soap in the 4th rinse cycle. Or in the 3 cycle's spin at the end of rinse, when it sprays water on the spinning laundry.... This is a horror. Maytag ignores my emails. The handyman says new washers are terrible and wants nothing to do with it. I wish I'd paid whatever it took to fix my old whirlpool. 22 years and never an issue ever, never more than 3 rinses and then only a 3d because I'd used double soap to get out dirt from gardening or road trips like Santa Fe in the winter when shih tzus got covered with red clay dirt used on snow and ice--that stuff is lethal! Normally I added fabric softener on 2d rinse cycle and things were so clean. Now things are not clean, come out ripped, or with pilling like they aged 10 years in one night. So I handwash anything I want to keep nice. Washcloths are getting frayed, towels look bleached or faded....and I am relating to my grandmothers on wash day. Sorry it's just more problems not solutions.
Jan 23, 2011 | Kenmore Washing Machines
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
How do you get the 'suds' to stop appearing on the screen. have tried rinsing but it wont let me.
SUDS = suds detected during wash cycle.
Do you see suds visible in the drum?
Do you have any other failure codes appearing?
Unplug unit and plug it back in attempt to run the rinse cycle. If it does not work it could be a clogged filter.
Remove lower front panel place a pan under the white filter. located near the pump. Remove the unit and clear any debris.
Nov 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Le code appears during normal cycle
LG recommends unplugging the washer for 15 - 20
minutes to reset the microprocessor.
The most common cause for the LE error code is over-sudsing in the machine from using regular detergent instead of a high efficiency detergent. The HE detergents are designed for lower suds levels and enhanced cleaning performance in front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. LG recommends loading the washer until the clothes in the drum are no more than three-fourths of the way up the window of the door. This will allow them sufficient room for tumbling.
http://tclaundryrepair.com/
Feb 26, 2009 | LG WM1814CW Front Load Washer
Kenmore front load washer 417-44082400
Check your ettings
one of them has been changed
try using different settings till you get the right one back
otherwise your timer my be malfunctioning
Jan 18, 2009 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
186 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
