Question about Dell Axim X5 Pocket PC
Dell axim I have a problem with my dell axim 5. I do i hard and soft reset and it still comes back to align screen. I have tried the fixes listed here but I cannot gte passed the align screen
  • 1 more comment
  • Anonymous May 04, 2008
    I have the exact same peoblem stuck on the screen align bit
  • Anonymous May 09, 2008
    I'm having the same problem. Did soft reset, hard reset, pulled both batteries, nothing seems to work.
  • sothy001 May 11, 2008
    I have exactly the same problem....
    Problem Solver:
  • 10 Answers
This worked for me and was found at (http://www.pocketpcmag.com/forum/topic.asp?TOPIC_ID=13366). The link may not work so below are the instrunctions.
This link will help you visualize the process: http://www.gethightech.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=GHT&Category_Code=_axim_takeapart
Trobbins Instructions:
I have a Dell Axim and was frustrated that my screen was freezing up. I went surfing on the web and luckily stumbled upon the answer. There is likely a burned hole on a small thin mylar piece on the inside of the unit. Before you give up and throw it away, let me tell you how to fix it because it is easy enough that I was able to do it - and I am NOT a computer geek at all.
Back up the unit on your computer.
Take all batteries and the memory stick out.
Turn the unit over and carefull pull the black rubber feet from the top, the black rubber circles out of the bottom, and the black rubber side panels. They are stuck on with a rubber cement compound, so just pull carefully and try to preserve the sticky as much as possible.
Unscrew the six screws along the back and carefully open the unit. (Don't be afraid...it's not working now so you've got nothing to lose!)
On the lower left corner you'll want to pull straight up and out the speaker connection - a small square plastic piece w/ metal prongs.
Just push it back out of your way so you can lift the motherboard out. When you pull it out, look at the bottom right hand side and you'll see a small thin mylar film. Look carefully at the left hand side of it and see if you see something that looks like a burnt hole. If so, that's the problem. It's causing some kind of communication problem with the screen. Here's all you have to do. Take a small piece of electrical tape and place it over the mylar film. Then put the pc back together in the reverse order of how you got it open.
Mine is working like a champ now!! It really is easy so don't be intimidated.
Hope this works for you as it did for me!
Let me know how it works and if you have any questions (grandgregojunk [at] yahoo.com) - An Axim is a terrible thing to waste... when it's easily fixed.
Posted on Jun 14, 2008
I have the same problem too....
Posted on May 11, 2008
All I get from my Axim x30 is the align screen. When I tap all the crosses it just stays in the middle but I dont get the home screen, not even after a soft reset.
take a credit card or bisiness card and slide it in between the edges of the screen gently this should fix the problem if not open it and clean the touchscreen contacts
Aug 24, 2010 | Dell Axim X5 Pocket PC
Screen alignment loop
The only thing I can think of is that the screen might be bad. Has it been hit or dropped? Are you SURE you haven't thrown it against the wall? :P Just kidding, but seriously, my dad's old Palm had a similar problem where if you tried to calibrate the screen, it would loop, and it was because the screen was old and wasn't performing correctly. Although you were pressing it in the right place, the screen wasn't reporting the locations properly, causing the thing to loop to try and get correct readings from the screen.
Dec 04, 2007 | Dell Axim X50v Pocket PC
I have a dell axim x51v stuck on dell logo
First check to see if any of the buttons are stuck. If that doesn't help, try a few simple things with the digitizer, the thing you write on. It could be stuck.If there are any gouges, dents, deep scratches or cracks, that could do it, it's toast - but self repairable if you dare. -However- 2 things to try first just for giggles though if there are no cracks: #1. Use your joystick & enter button to navigate through the Start Menu to Settings>>System>>Screen>> Align Screen and align the screen. Worth a try. #2. There might be some crud stuck between the edge of the digitizer and the edge of the case. That can give you phantom key presses. Take a piece of stiff paper or thin plastic and run it *gently* around under the edge where the case covers the screen to scoop out any stuff that may have settled there. Those blister packs that cut you up when you try to open them works well, credit card is too thick for my taste. #3. If it's been around water, there's a very slight chance that putting it on top of the clothes dryer for a few loads will dry it out.Beyond that, needs technical help.
Mar 16, 2010 | Dell Axim X51v Pocket PC
How do I reset my dell axim pocket pc back to its original settings?
Performing a Reset
Soft Reset
When you perform a soft reset, the device deletes any data that has not been saved but saves any data that has been stored in memory. Try performing a soft reset if the device does not respond when you tap the display or press a button.
To perform a soft reset, use the stylus to press the reset button.
Hard Reset
NOTICE: When you perform a hard reset, you lose all the data stored and any programs you installed on your device.
Perform a hard reset if:
•You want to delete all the data stored on your device.
•You forget your password and need to clear it.
•Your device is experiencing severe operational problems and you have
already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you perform a hard reset. See ActiveSync Help on your computer for more information.
To perform a hard reset:
1 Press and hold the power button.
2 With the stylus, hold the reset button for about 2 seconds.
3 Follow the instructions on the screen.
Thank you for using FixYa! Have a nice day and please remember to to rate this solution.
Warm regards,
BearWeb
Feb 19, 2010 | Dell Axim X30 Pocket PC
I have a Dell Axim x50v running with original ppc2003. Then I upgraded it to Windows mobile 2005, and used for couple of months then it crashed! Now the issue is both soft & hard reset stop loading at 80%,...
Same problem. Soft and hard reset can't even stard any advice screen. When the problem started, it was frozen at the dell round simbol, that i just could turn it off by removing battery. Now, its even worse, the screen is off, even after pressing the two and tree buttons at the same time, it doesn't hard reset. What else should i do?
Mar 28, 2008 | Dell Axim X50v Pocket PC
Dell Axim X5 with Pocket PC 2003 Locked up
With much regret I did a hard reset. It appeared that some how in my carrying case that hard reset got started and I could not get it out of the lock up with out taking it clear through. I hadn't backed up for a couple of month but didn't loose much data. Thanks for the follow up.
Mar 17, 2008 | Dell Axim X5 Pocket PC
All icons are fuzzy and distorted
It may be a screen alignment proble. Try a hard reset -after you have backed up your data of course!
Dec 10, 2007 | Dell Axim X50 Pocket PC
Dell Axim Touchscreen Quit Working
probrably your touch screen component got broken when you drop it thats why it no longer functions....
Oct 29, 2007 | Dell Axim X5 Pocket PC
Axim X5 Align Screen Loop
I am by no means an expert but I have had the same problem that you are having and I found that after I took my X5 apart and cleaned around the underside edge of the plastic housing frame that was at the edge of the screen the problem went away. I also cleaned the front of the screen very well and put a new back-up battery in. I have not had the problem since.
Sep 05, 2007 | Dell Axim X5 Pocket PC
How Do I Perform a Soft Reset on My Dell™ Axim™ X5 Handheld?
A Soft reset will only minimize and temporarily suspend any running programs on your Axim. If you are experiencing issues that require you to perform a Hard reset, refer to Dell Knowledge Base Article:
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
259 people viewed this question
Alun Cox
