Heat pump start cap went bad. replaced and when unit turns on compresser hums-won't start. push contacter in and it stats fine. it's a two speed. ?
    Novelist:
    Champion:
  • 246 Answers
The reason the compressor starts when you push the contactor in is that you have an "open" in your control voltage. I would suspect that the thermostat was bad - since that is 'usually' the only component you have in that circuit.
Since you indicate this problem 'surfaced' after you had the "start cap" replaced - I might be suspicious of the new start cap and how it's wired in - but "assuming" it is correct I would probably change the thermostat.
Note: as with any Air Conditioner - when you start 'changing parts' you run the risk of changing out a perfectly good part (thus wasting perfectly good money) - so - if possible I would see if I could find someone to electrically trouble-shoot the AC to determine 'exactly' what was causing the problem.
hope this helps
Posted on Jul 29, 2010
AC-heatpump won't turn on unless I push n hold the contactor switch. I let go,it stops. I have 24v coming in the motherboard from stat, but no 24v coming out to the contactor. Is my motherboard bad?
Sounds like a pressure switch. Have you tested continuity on the switches? If no multi meter put a jumper on HP and LP. (HIGH AND LOW PRESSURE) Turn system back on. If contactor pulls in...bingo! Do not leave jumpers on, get the freon problem fixed. Hopefully high pressure problem ;) Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 10, 2017 | Heating & Cooling
Aquaflow 07140001-6 hums but can be manually starter
This usually means you have a bad motor. It has found a flat spot on the windings.
You will need a new pump for the fix.
Rod
US Parts Center
Jan 10, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
1984 190e humming sound but won't turn over
Sounds like a Starter remove it and test it on the battery keep a tight hold as it turns quit sharpley if it works its possible it could bevthe cylanoid replacevthe full starter its just as cheap mine was 90 pound originall merc part
Sep 01, 2017 | Mercedes-Benz 190-Class Cars & Trucks
Car turns over but does not start. Battery good
If it over heated, could have bad head gasket's, fill radiator with water, crank engine with radiator cap off, if water is push out of radiator while cranking, bad head gaskets', also remove spark plug's, crank engine if any water, bad head gasket, also when spark plug's removed, check for any water on them.If there is any water on plug's, bad head gasket, also could try doing a cylinder compression test, if bad compression, head gasket, no compression, wont start that way.
Aug 30, 2010 | 1990 Ford Thunderbird
I have a intertherm furnace and split intherm heat pump when i turn the thermostat on it just seems to hum out side at the heat pump whats the problem
First thing to check is to see if you have electric out there. The hum is probably the 24 volt relay that is telling the a/c to come on. The 24 volt relay gets it's power from the indoor unit.
Jul 06, 2010 | Intertherm P3RC-030K Air Conditioner
RUUD heat pump system does not cool properly.
With a heat pump system there are always going to be a back up heat strip inside the Air Handler.
If you detect a faint humming in the Condenser call your local service company and ask them to come and replace your capacitor in the condenser. The humming is from the contactor engaging but not being able to start the compressor due to not having the required Microfarads to start it.
Let me know if this helps
May 07, 2009 | Heating & Cooling
Heat Pump hums, clicks and does not come on sometimes
yes the start capasitor starts the fan motor and the contactor pulls together when the t-stat tells it to start and it has a spring in it that gets week , some brands of units have a delay in the outside units board to stop it from starting at the exact same time as the airhandler
Jan 08, 2009 | Heating & Cooling
My heat wont turn off
Whan your room is up to temp or room is set at 70 and your stat is at 70 do you hear the stat click off .if not its a bad stat. you will have a little flam on your stat that should go off also
Dec 28, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
MY AIR CONDITION ONLY PUT OUT WARM AIR EVERYTHING SEEMS TO BE OK FILTER TURNS ON OK BUT THE OUTSIDE UNIT HUMS BUT DOES NOT FAN
Sounds like a bad start run capacitor. The exhaust fan motor may be bad too. Be careful, this unit delivers 220volts of electricity.
Jun 17, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
