Apple iPod touch Logo
Posted on Jul 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Menu icon on screen can't reduce to normal
After click one menu (not remember which one) the icon became large and can't find menu to reset back to normal even click on reset screen.
Anonymous
Level 3:
  • Master 881 Answers
  • Posted on Aug 18, 2010
Anonymous
Master
Level 3:
Answers
881
Questions
Helped
420803
Points
2851
Simply use 3 fingers to double-tap on your iPod's screen to put everything back to their normal sizes.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: [email protected]
How do I make my screen size smaller? It just became huge suddenly
You likely zoomed in with control-scroll up/down, try control-scroll to zoom back out. If only the font (not the windows) got larger, reset font view size with apple-0 (command-zero). HTH.
tip
Removing oversized icons and fonts on your Mac OS X Desktop (Mac OS X10.4 -...
Have you ever experienced your Mac desktop looking normal like this:
Then suddenly, your screen fills up your entire Desktop screen like this:
And when you scroll, it still looks like this?
What you are experiencing is an oversized screen, where every font and pixel on your monitor screen is blown way out of proportion.
So how can you get your Desktop back to normal like this?
Believe it or not, it is easier than you think.
What you will need to do is select System Preferences on your Dock or from the Apple menu icon:
* Select System Preferences on the Dock:
* OR locate the Apple Menu icon and select System Preferences from the drop down menu:
You are going to have to open System Preferences and select the "Universal Access" pane, which looks like this:
Click on it to launch the Universal Access page and make sure
you move your mouse around, in order to see rest of the window.
Now work down the oversized window and click the "Off" radio button under "Zoom:"
And just that fast... Back to normal view!
As you can see in this screen shot, all you had to do was turn off
the Zoom setting in Universal Access, in order to keep your screen from looking like this:
The Zoom feature is one of Apple's assistive devices for the visually impaired who actually need greater magnification in order to truly see, what is on their Desktop screen.
The Zoom feature can be triggered if the "On" radio button is turned on, or is the Zoom feature is on, BUT, has been reduced to normal magnification after this keyboard combination is pressed:
Apple Command Key + Option Key + the Plus (+) Key
(Which will enlarge the desktop screen with increasing magnification)
You can also click the Apple Command key + Option Key + the Minus(-) key, which will reduce the magnification back to normal view.
This feature comes in handy if you are sharing your Mac OS X Desktop with a loved one, friend or client, who may have a visual impairment or poor sight and you (in the kindness and consideration of your heart) have enable this Universal Access Zoom feature, for their convenience.
This of course will work out great for both of you, because now you know just how to reduce the magnification of your Desktop back to normal when it is your time on the Mac.
So now you know how to reduce that Oversized Super-sized screen issue on your Mac... it should not throw you for a loop the next time it should occur!
Thanks for viewing this Mac OS X tip from FixYa Support, I hope it will be of use to you one day!
Regards,
-Mactechtrainer
on Feb 17, 2010 • Computers & Internet
Display is too large for screen
Hello Dr. Bankert and thank you for contacting Fixya, I will be glad to assist you.
What you need to do is turn off a setting within the System Preferences > Universal Access feature within your Power Mac G5.
To do this, you need to click on the Apple menu icon, located in the upper left corner of your screen. When you do click on that menu icon select System Preferences from the drop down menu:
Then go into System Preferences and look for the pane (icon) entitled Universal Access 9_16_2012_10_06_45_pm.png
• Click on the Universal Access and you will see this view:
Under the Seeing tab, make sure Zoom is turned to Off
This should bring your enlarged screen back to its normal size.
You can now also click the Show All button located at the top of that window (on the left side) to return back to System Preferences main window.
From within System Preferences, select Displays and try selecting a lower resolution like 1280 x 1024 or 1024 x768 for example and see if selecting one of those resolution settings helps to reduce the size of your display window.
Please let me know if any of these simple recommended steps help.
If you have more questions, I will be glad to assist you further.
Regards,
-The MacTechTrainer
How do I change the font or Text sizen
  1. Go into your Control Panel by first clicking on the Start Button.
  2. Then click on the Control Panel icon located in the right column of the Start Menu.
  3. If your Start Menu is set to the CLASSIC VIEW then begin by clicking on the Start Button.
  4. Then click on Settings, then click on the Control Panel icon to open up the Control Panel.
  5. Now, Double click on the Display icon to open up the Display Properties Window.
  6. Then click on the Appearance tab at the top of the screen.
  7. At the bottom left side of the screen you will see an area to change the Font Size:
  8. Use your mouse to switch between normal, large and extra large according to your preference.
  9. Then click on the OK button to save your changes and exit Display Properties window.
  10. Windows XP will immediately adjust to your new Font Size without restarting your system.
  11. Then close the Control Panel to return back to your Windows Session.
Increase my font size
You did not specify your operating system.
For Windows XP
If your Start Menu is set to the Classic View, then begin by clicking on the Start Button.
The icon display is taking up too much of my screen and I would like to reduce it.I can't seem to find the file that has that feature. I have done it before but can't remember how.
Hello amionalden, to make the [Icons] smaller; do the following. From the "Desktop Screen" paul7of9_74.jpg (Right) click on the "screen," there will be a 'list' of items, choose the "View." when you point to it a 'side window' with the [Arrow] will open. There will be another 'list' example: Large Icons, Medium Icons... Choose the {Medium Icons}, this will make them 'smaller.' "I hope this information is helpful? Thanks for using FixYa, paul7of9."
1helpful
New Acer 5532 laptop; v.wide screen but not v.deep. Currently large toolbar icons take up some 25% of the screen unecessarily - how to reduce their size down ?
Follow the easy steps to reduce the size of icons
  • first right click on the deskstop
  • Click the properties
  • Click the next tab named "appearance"
  • Now look at the bottom and change it to normal
  • and apply
thanks
New Acer 5532 laptop; v.wide screen but not v.deep. Currently, large toolbar icons take up some 25% of the screen unecessarily - how to reduce their size down ?
Depends on which Windows version you have, unstated.
Right click on screen anywhere except other icons, go to "properties" and adjust screen res to max and also check under appearance that icons are "normal"
1569helpful
13answers
My IPhone screen is magnified and it won't go back to normal size. All icons are very large
Easy, take three fingers and double tap your screen. Now that your phone is back to normal, change your settings so that this doesn't happen again. Go to settings, click on general, click on Accessibility, click on Zoom, then turn it off. Now, this wont ever happen again.
3answers
Laptop
I have no idea about the date part, your question is too vague.
The icons, right click on the desktop, and when the menu comes up click View-->Medium Icons.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
