Question about Sony NEC Optiarc AD-7670S DVD-RAM Burner
Dvd laptop have no power but it can detect.. the last thing that i did is to update drive on device manager. what it may cause?
  • 415 Answers
Roll back your driver
remember 1 thing about updating drivers......
IF IT AIN'T BROKE DON'T FIX IT
Posted on Jul 28, 2010
Dvd drive wont work on laptop
when was the last time was it working???
have you tried doing a system restore.
check for the device manager if the drive is detected under CD/DVD option.
if not try to instal the basic chipset drivers for your laptop and see if that works.
Nov 22, 2014 | Dell Inspiron 600M Notebook
Dvd drives says no disc in drive
Try updating the drivers for the dvd player.
Go to Start
Click in box and type Device Manager
Click on Device Manager in the list
Click on Disk Drives
RIGHT click on your dvd player drive
Click on update drivers
Click on Search automatically for updated driver software
Mar 29, 2013 | Lifetime Gateway NV58 Replacement Laptop...
DVD A DS8A1H ATA drive is not detected by Device Manager at times and will drop out sometimes after running for awhile. The problem seemed to start the last time that I used the itunes program. The device...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 18, 2011 | Computers & Internet
My laptop couldn't detect my dvd drive as if it was not installed, i've been using it before this thing happened.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope thishelps
Mar 14, 2011 | HP Compaq DVD Drive
My dvd drive couldn't be detected. could you help me with this, thank u
go to device manager, by clicking on start, right click on my computer and go to manage and see if it is detected in device manager, if it is, it may just need a new driver. Look for any Yellow ! or ?
If it is not then scan for newly added devices. If it still is not detected and in a laptop, WHILE POWERED DOWN, press gently on the DVD drive door like you are pressing it to be closed. if it has come unseated this may help. If on a desktop this wont help and you will need to verisfy that the cables have not come undone, rare but can happen especially with travel. If neither works, and in a desktop you can power off and put in a different drive. if this works you know your last drive has failed and that you can now be the proud owner of a new drive! If in a laptop a bit harder a not may people have a spare DVD drive that will fit yours just lying around. Try placing a different disk in the drive say a cd and see i it is still not finding it.
Mar 13, 2011 | Computers & Internet
My pen drive & usb cards not detected in my laptop
If your laptop is in warranty you may go to vendor if it's not try updating usb drivers and one more thing check whether USB devicies are enabled in BIOS if it's ok go ro START -> RUN -> enter services.msc select device manager(last option in device manager) and check whether USB ports are blocked this should definetly solove you problem.
Feb 26, 2011 | Computers & Internet
My dell inspiron 9300 reads and plays DVDs, but does not detect any other type of CD in the CD/DVD drive (music, data, etc.). i've had a problem before where it didn't read CDs or DVDs and it turned out to...
Go to the support.dell.com webpage, enter the service tag number, located on a label on the bottom of the laptop, and download the latest BIOS update and drivers for the CD/DVD drive. You can verify the drive type in Device Manager. Once you have downloaded the files, upgrade the BIOS, this will restart the system. Next, remove the CD\DVD in Device Manager and then install the new driver for the drive. When the driver has been installed, Open Device Manager and right click on My Computer at the top of the list and left click on Scan for changes. The drive will be detected adn installed with the new driver and the registry will be updated.
Good luck, and please let me know how it works for you.
~Spoem
Dec 14, 2009 | Dell Inspiron 9300 PC Notebook
DVD/GD Rom not detected by system under my computer, device mmanager or in BIOS.
having that the PC could not configer the dvd rom then you must install it with its drive software .the thing is that the operating program has no drive for it
May 25, 2009 | Computers & Internet
Vista Won't Detecting My DVD Drive
ok go into windows devic manager and see if the dvd drive shows up there it might have a little ! in a yellow triangle if it does dont worry it should offer a soultion to get to device manager go to (start type device manager and then click on it)
also try installing the device driver again hope this helps
Jul 19, 2008 | Computers & Internet
Sony NEC Optiarc AD-7670S DVD-RAM Burner Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
