Question about LanTech (HR-114 P) Router
Please tell me what is the "LanTech HR-114 pro" DMZ setting Website(IP)? 請告訴我LanTech HR-114 pro的IP設定網頁為何?
How do I set a static route lan side on a tew-733gr
You need to download the user guide from here
TRENDnet Support
Basically
1. Make the computer or network device (for which you are establishing a DMZ link) has a static IP address (or you can use the DHCP reservation feature to ensure the device has a fixed IP address) (see "Set up DHCP reservation" on page 29).
A. Signing up for a Dynamic DNS service (outlined in the DDNS section) will provide identification of the router's network from the Internet.
2. Log into your router management page (see "Access your router management page" on page 22).
3. Click on Access, and click on Firewall & DMZ.
4. Next to DMZ Enable, click Enabled.
5. Next to DMZ Host IP, enter the IP address you assigned to the computer or network device to expose to the Internet.
6. To save changes, click Save Settings.
May 23, 2014 | Trendnet Computers & Internet
I whant open in ps3
I take it that you want to change NAT type in your PS3. To open NAT type you first need to get port numbers from PS3 people. Once you get the ports check what the IP add on the PS3 is.Once you have this information login to the router interface and punch in the port numbers and the IP add and your NAT type should be open.
Hope this helped.
Jan 23, 2011 | LanTech (HR-114 II) Router
Default user name & password
The default username and password is written on a sticker at the back of every router.
CreativeTECH
Jan 13, 2011 | LanTech (HR-114 II) Router
I need default password
From my research it shows that it doesn't have a password.
Username: press enter
Password: press enter if that doesn't work try the word root all lowercase.
Jan 12, 2011 | LanTech (HR-114 II) Router
Lost my password
ask for a new one in your router site.
May 02, 2010 | LanTech (HR-114 II) Router
Password to sign n router
Hi friend
I hope this will work for you
By default both the username and password are blank.Donot type anything.
Regards
Chiranjeet Mitra
Oct 09, 2009 | LanTech (HR-114 II) Router
How to configure dmz on linksys wireless n router?
  1. Log into your router. (If you need help how to do it let me know!)
  2. Go to th "Application & Gaming" tab.
  3. click on "DMZ"
  4. choose "Enable"
  5. Enter the IP address of the computer you want to put in the DMZ.
  6. Click "Save Settings"
Some notes:
  • Putting a computer in a DMZ is pretty risky, because all ports to this computer are opened. Make sure that all recent patches are applied and your virus software is up to date! A more secure solution is to use portforwarding. (See this site how to do that for a specific software for your router.)
  • Your computer should be set to a static IP. For two reasons:
  • A) DMZ will not work if your DHCP server (your router) assigns at one point a different IP address to your computer,
  • B) If a different computer gets the Ip address assigned that you specified in your DMZ settings, then that machine is exposed.
If you don't know how to assign a static IP address, let me know and I walk you through the steps.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | Port Designs Linksys Wireless-G Broadband...
Forget Pass.. !!! HELP !!!
you must reset to factory default
there is a reset button
Jul 09, 2009 | LanTech (HR-114 II) Router
Hang
change the firmware of the router then you get it after then shows same problem then replace it the router go to the tp-link or zyxel
Apr 16, 2009 | LanTech (HR-114 P) Router
Pro ev0 09 not working on the net
Are you using a router to connect your computers to the internet? Your router holds all the info for your LAN. You can get into the router software via your web browser, and find the ip assigned to the ps3. Next put that ip into the DMZ of the router. POst back if you have questions so I can walk you through it.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
LanTech (HR-114 P) Router Logo
52 people viewed this question
Top LanTech Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a LanTech Computer and Internet Expert? Answer questions, earn points and help others
