Question about Canon PIXMA iP90 Mobile Printer
Black won't print
I've tried all the cleaning and alignments. I tried the hot water with the towel. I tried cleaning with alcohol.
What else can I do?
Try Magic Inkjet Flush on Ebay = comes with a clever Mini unclogger for Canon Black print head
http://www.youtube.com/v/zQHRJNPAqSg
Posted on Apr 27, 2008
    Novelist:
  • 150 Answers
Alcohol is probably the most effective and the strongest
head cleaner I would dare to use, without dissolving the
plastic. You may even try soaking the head in alcohol
overnight or try using a bath style ultrasonic cleaner,
but ultimately, if the head is really plugged up, or if the
electronic firing mechanisms inside the head are damaged
you are probably out of luck.
Replacing the heads may be possible, but hardly cost effective.
Some heads are part of the ink cartridge, others are separate.
You may also try to wiggle the ribbon cable feeding the
moving print head to make sure it has a good connection.
Finally you may find that buying a new cheap printer for $50
is more cost effective than wasting tons of ink, trying to
clean the one you have.
I have had many printers from every brand imaginable,
ranging from $45 to $1200, and I find that the more
expensive the printer is, the more of a let down it is,
and the sooner the ink becomes obsolete.
My favorite is the last one, which came with 6 full sized
ink cartridges for $65. When the ink runs out, i will replace
it with another new printer. :)
Also if you do mostly B&W printing, an $89.00 laser printer
is a far better investment. It prints faster, with better quality
and lasts for ever. No ink covered hands, no headaches.
Martin
Posted on Apr 24, 2008
Mx870 nozzle check prints no yellow
take yellow head under the pipe with the hot water running, it should leak yellow ink, take paper towel and gently clean (plain water, NO alcohol), if its not working then read :
http://www.nifty-stuff.com/forum/viewtopic.php?id=241
Mar 17, 2013 | Office Equipment & Supplies
Won't print black, prints every other colour ok
1. try to cleaning head
2. remove the black cartridge only, (if it doesn,t changed after you cleaned head)
3. provide some warm/hot water on a bowl or plate.
4. enter the HEAD of black cartridge in to hot water. soak with depth about 2mm up to 5mm. while you see the ink is come out....
5. after the black ink has come out. pat dry with a paper towels/tissue.
6. replace the cartridge in to printer.
7. cleaning head again and print test page
good luck....
Jun 19, 2011 | Canon Pixma MP500 All-In-One InkJet...
Problem with printhead please consult user guide
Use the printer's utility program to self-clean the printer. This process may need to be repeated as many as 5 to 10 times. Often this will resolve the problem.
Turn the printer off, preferably overnight, if the self-cleaning utility has not worked. The ink may need to soften before the self-cleaning utility will be successful. Turn the printer on and try the self-cleaning utility again several times.
Determine from the owner's manual where the print head is located. Epson printers, for example, are usually in the printer. Many other brands place the print head in the cartridge.
Remove the cartridge. For models where the print head is in the printer, drop seven to 10 drops of isopropyl alcohol (rubbing alcohol) down the ink receptacle area. This is the hole where the ink flows into the head from the cartridge. Run a few self-cleaning utilities. If necessary, allow to sit a few hours or overnight and repeat the self-cleaning utility.
Soak the cartridge print head in hot water if the print head is in the cartridge. Allow to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
Place the cartridge print head in isopropyl alcohol if the hot water soak did not unclog the print head. Leave the print head covered in alcohol overnight. Use a damp paper towel to wipe off the print head area. Dry carefully. Try the self-cleaning utility again.
Purchase a new cartridge if the alcohol soak did not unclog the print head in the cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the print head.
Mar 01, 2011 | Office Equipment & Supplies
I suspect that the black printer head is clogged up, is that seomething that I can repair myself?
Hello
Yes you can repair by trying the following steps:-
Hope it helps, if so do rate the solution
good luck
Dec 27, 2010 | Brother MFC 7300C InkJet Printer
On my HP Officejet 4215, my black cartridge doesn't print. The cartridge is nearly full.
If you haven't used the black print option, as in to print without using the color cartridges, then the black print head may be 'gummed up'.
You can try to clean the print head using the 'clean' function, which may work.
You can also try to get the print head to work by using ammonia and hot water. If the cartridge has its own print head, you can use some hot water on a paper towel and set the print head onto the soaked towel for a few minutes. After it has sat for a while, gently dab it dry with another paper towel, and try to use it. If it works, you're done. If not, you can use ammonia to try to clean the print head using the same tactics as using water. Try water first, then ammonia.
If the print head is fixed in place, you have to remove the whole assembly from the printer, and then try to clean the print head using the same method.
tom
Aug 11, 2010 | HP OfficeJet 4215 All-In-One InkJet...
My printer won't print anything - only blank pages. However, both ink cartridges have ink. Please help!
If the self-cleaning cycle does not solve the problem, try turning the printer off overnight to allow the ink to soften. Turn the printer on the next day and try printing a test pattern to see whether the problem has either disappeared or become less noticeable. This ink-saving procedure can work effectively because sometimes the dried ink on the print head needs time to soften before the printer head can be cleaned completely. Try running the self-cleaning utility again one or more times.
Steps for Manually Cleaning the Printer Head
If the overnight cleaning still does not work, there may be a layer of thick ink that is blocking the holes of the printer's head. The next option is to manually clean the printer head. Follow these steps:
* Determine from the owner's manual where the print head is located.
* Remove the ink cartridge from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. NOTE: Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets, and if you get isopropyl alcohol on the gaskets it could dry them out.
* For models where the print head is in the printer, drop 7 to 10 drops of isopropyl alcohol (91% denatured isopropyl alcohol - not 'rubbing' alcohol) down the ink receptacle area where the ink actually flows from the cartridge into the head. Run a few self-cleaning utilities. If possible, allow the printer to sit a few hours or overnight and repeat the self-cleaning utility.
* If the print head is in the cartridge, soak the cartridge print head in hot water. Allow it to soak overnight. Dry the print head area with a paper towel. Repeat the self-cleaning utility.
* If the hot water soak did not unclog the print head, place the cartridge printer head in isopropyl alcohol and allow it to soak overnight. Use a damp paper towel to wipe off the print head area and dry carefully. Try the self-cleaning utility again.
* If the alcohol soak did not unclog the print head in the cartridge you may need to purchase a new cartridge. This will provide new print heads that won't be clogged. Contact a service technician for repair of print heads in the printer if the alcohol did not unclog the printer head.
Jun 09, 2010 | HP DeskJet 5150 InkJet Printer
Canon pixma mp130
1. Take out black and coloured ink cartridges.
2.Clean golden contacts with a q-tip dipped in alcohol'both on the print head and on the cartridge.
3. Dip the cartridge in a hot water bowl, let all the ink left flow out.
4. Wipe with a paper towel.
5. Let the parts dry out for at least 24 hours
Oct 03, 2009 | Canon PIXMA MP130 All-In-One InkJet...
HP 2210, screen says to press enter to aling cartridges
Once you replace a cartridge on a 2210 ya page prints and you must put that page on the scanner window and then press enter. Your computer will go through a calibration to align the print head. once this is done you can throw away the paper and printing will be normal
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
Canon i560 printer
It's likely the print head is clogged. You have 2 options:
1) Remove and clean the print head. Open the printer and lift the gray lever and just pull out the print head. There are no tabs to push, it simply slides out. Search the web for cleaning techniques. Looks like people have tried hot water, isopropyl alcohol, and ammonia. I don't know what the best technique is. It's probably a good idea to finish with a distilled water rinse and soak up the excess water with regular towels or paper towels. Remember to clean the ink jet at the bottom of the print head and not the electronic circuitry at the back of the print head.
2) Buy a replacement print head for $50-$65 off the web.
Hope that helps :-)
Jul 23, 2008 | Canon BubbleJet i560 InkJet Printer
HP inkjet 1100 not printing yellow
Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge.
Nov 15, 2006 | HP LaserJet 1100 Printer
Canon PIXMA iP90 Mobile Printer Logo
75 people viewed this question
old marine
old marine
