Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
I have a sumsung 50" DLP. After grinding, cracking, and popping it stopped working. I opened up the side compartment to change the bulb. Bulb is intact but there was broken glass that I couldn't tell where it was coming from. Is this enough info to tell me if it is worth fixing? Thanks
If the bulb is ok your colour wheel is broken you must open up tv take out engine kleen all glass and replace colour wheel this repair will cost about 200 dollar
Posted on Jul 28, 2010
I have an RCA M50WH72syx12, 50" DLP.
Yeah could be expensive if it isn't the lamp.
Mind you could be a little easier, might just be a fuse on the video relay. If you are confident in being able to open it up, check the relay that runs from the video input to the power capacitors and there should be a small fuse along that circuit.
If the fuse has a broken capsule then you may just be in luck. Failing finding a broken fuse, then I would agree with you on the bulb. But check the blub for any markings or cracks because they usually only make noise when the vacuum fails.
Hope this helps and good luck mate! :D
Nov 23, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
How do I change the lamp? Lamp came with no directions. This is a HD72.
Hello there,If your movie projector light bulb has stopped working, there are some simple steps to take to get your movies playing again. The hardest part may be finding the correct replacement bulb. There are so many different models with their own specific bulb. Here are some steps to follow to replace your burned out light bulb.
  • Locate the bulb in the movie projector. You may need to use a screwdriver to open the bulb compartment. Check your owner's manual for proper procedures.
  • Step 2.Remove the movie projector light bulb or lamp. The bulb must be cool before you take it out. Use a tissue or cloth to remove the bulb because the glass bulb is very fragile. Do not throw away your bulb yet, you may need it to help find a replacement.
  • Step 3.Find replacement bulb. The Better Lamps website offers a wide variety of light bulb models. From their homepage select the brand of movie projector you have and using the model number from your old bulb, buy a replacement.
  • Step 4Replace the movie projector lamp or light bulb. Do not touch the bulb with your skin. This can transfer oils from you onto the bulb resulting in a hot spot which can make the bulb burst. Use a tissue or cloth to handle the new bulb to screw it back into place and then replace the cover.
  • Jul 31, 2010 | Optoma HD70 DLP Projector
    50 inch rca dlp tv. new bulb. makes a loud
    Color Wheel needs to be replaced. Call PartStore.com
    1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
    Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
    MY TV TURNS ON AND STAYS ON FOR 5SECONDS AND THEN THE SCREEN TURNS BLACK BUT CAN STILL HEAR THE SHOW PLAYING. TURNED IT OFF AND EVEN UNPLUGGED IT FOR ABOUT 5 MINUTES, BUT STILL THE SAME THING HAPPENS.
    the lamp is likely bad .. they only work a few thousand hours .. then must be replaced .. your lamp can cost a couple of hundred (maybe even more if bought locally) .. here is one for less if you have someone handy that can change it.......
    http://www.purelandsupply.com/50PL9126D-37-Bulb-Philips-DLP-TV-Bulbs.html
    ..... of course make sure power is off (unplugged) and make sure things are not hot .. there is usually a little cubby in the back where the lamp is located .. you an see what the lamp looks like at the above URL .. dont get finger prints on the bulb . that will cause it to crack when hot .. if you are unable to change the bulb then a call to philips service should do the trick. make sure you ask what the bulb replacement and labor will cost ..
    Jan 27, 2010 | Philips 50PL9126D/37B 50" DLP TV
    Describe how to replace bulb for magnavox hdtv #50ml6200d37
    easy. pop off the front cover.. Start at the right edge. The front part that covers the speakers comes off as a complete cover. Then there is a square panel that must be removed on the left side front about three screws. once the panel is off there is three thumb screws .. loosen them.. they do not come out. then when they are loose pull on the panel handle and out comes the bulb unit. then follow the install instructions of the new bulb. Do not touch the bulb with your hands... It goes back the same way .. The exterior panel must be in place for the tv bulb to fire up..
    Oct 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
    I just replaced the DLP Lamp and housing on a 50' Samsung DLP tv.
    CK your Fans make sure they are running or set will not come on.also if you can solder resolder power supply board.
    Apr 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
    Hlp5063w 50'' DLP samsung Experiancing The Word LAMP green letters flashing for 20 second followed by clicking noise then shut off.. then repeats that same process twice then TIMER / STANDBY/TEMP/LAMP...
    Sounds like you've already gotten into the repairs. The three major things that fail on DLP are the bulb, the ballast and the color wheel. If your bulb is new and you aren't getting anywhere, replace the ballast, if that is still a no go, then move on to the color wheel. If replacing those three doesn't fix the problem, you will have to whip out the multimeter and start looking for problems on the PSB. You can get a ballast on ebay for about $100. Start there. The color wheel should be very freely moving. If something is grinding and hindering the movement at all, you need to replace it. That grinding may not seem like much but it is likely enough to keep the wheel from spinning at proper speeds. The sensor then kicks in and tells the brain that there is a problem and the brain keeps the ballast from firing the lamp.
    Good luck.
    Feb 18, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
    Replacing FPS running light
    If I remember Correctly you have to take out the whole headlight Assembly to change that1 little bulb
    Dec 30, 2008 | 1991 Honda Accord
    Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
    check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
    Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
    Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
    91 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
