FixYa.com
Tags:
Epson Stylus C43SX InkJet Printer
Resist printer
posted by Jenelyn on Apr 24, 2008
hello, good morning, I want to ask the procedure, in resitting the Epson Stylus C43sx printer..
hoping for your urgent response.
Thank you.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 15, 2008
Not Rated (0)
nigel_colfer
Rank:Wiz Wiz
Rating: 92%, 13 votes
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 24, 2008
Not Rated (0)
CowboysFanZ
Rank:Wiz Wiz
Rating: 81%, 34 votes
To reset the error download this utility:
http://inkjetprinterhelp.us/epsonSSC.html . Once installed run the program and configure it, closing the main window and right clicking the icon in the tray area, from there choose Configure and select your printers model. After configuration, select Protection counter -> Reset protection counter, it should be able to clear the error message. If that does not actually work, then the only suggestion I can give is to perform a soft-reset before resetting counter. Remove also the Epson status agent, it detects errors and it may hinder communication with the printer, then reboot your pc. As profile choose the one ssc service didn't use after autoconfiguration, check for printer response. Remember that you should also clean the waste ink pads located at the printer bottom. Thanks! //CowboysfanZ
Can you Help with these Printers problems?
Printers
CanoScan
Printers
I have a cannon pixma
I have a cannon pixma mp150. I... Answer This...
Printers
HP OFFICEJET 7210xi (q5561).
hp officejet 7210xi (q5561).... Answer This...
Ink Supply Problem
Can i print if only the black... Answer This...
ink levels cant be seen n red...
have new cartridges n yet red... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
