Question about Jenn-Air Refrigerators
My refrigerator model # JTB2188AEA the bottom half dosent get cold enough and the top half get cold but dosent freeze
    President:
  • 2,468 Answers
Your evaporator coil in the freezer behind a panel has iced over and the fabn can't move air over a solid sheet of ice,remove the panel,defrost it with a hair dryer,then check the defrost heating element and defrost thermostat under the coil and defrost control in the refrige section for proper operation
Posted on Jul 28, 2010
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
WHY IS THE TOP HALF OF THE REFRI. WARMER THEN THE BOTTOM HALF, I HAVE TO LOWER THE FOOD TO GET ENOUGH COLDNESS?
What is the model number. Cold sinks to the bottom and you are having a fan, defrost or vent problem
APPLIANCE 911
Jan 04, 2016 | Refrigerators
My larder fridge sr5045 frosts at top but dosent get cold enough
low on freon, freezing up no cooling, probably just has enough in it to cool your fridge.....
Aug 02, 2013 | Refrigerators
Does the control thermastat have anything to do with the freezer on my refrigerator getting cold but not freezing
If you remove the evaporator cover and look at the frost on the evaporator is it fairly even frost from top to bottom? If you don't have frost on the bottom half of your evaporator then you have a freon leak. Do you have a model number for your unit?
Mar 15, 2013 | Whirlpool Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Both freezer and fridge Not cold on top
sounds like the circulation fans are jammed/seized or faulty -try a full defrost and see what happens after that.
Apr 04, 2009 | Refrigerators
GE Refrigerator cooling system problem
My guess is that you need more refrigerant gas. It may also have a problem with the auto defrost system for the freezer. You have a block of ice in the evaporator instead of clear fins for the air to pass through. Make sure the door is correctly closed and that the magnetic door gaskets are in good condition. Once those are fixed you can turn the thermostat to make the fridge a bit warmer. Another possibility is that the circulation fan in the fridge has failed. Cold air falls to the bottom which is why your veg is freezing. You can't work on refrigeration gas yourself anyway, so call an engineer. Correct diagnosis of the fault will be cheaper.
Google
'<your city> GE refrigeration service'.
Dec 06, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Ge profile fridge bottom freezing up
found the problem .the compressor is not putting out enough cold to freeze the coils' only half the coils are freezing in the bottom of the fridge. the fan draws it's cold air from these coils and pulls it up to the top of the fridge where it's dispersed into the top half of the fridge' hence the stat never see's that it's cold enough to shut off the switch . in other words if the coils down below were all working a lot more colder air would be pulled up to the top and the stat would then shut off . Solution is to seek a refund from the service tech and buy a new fridge . it's not worth putting a new compressor into this one although it is only 5 years old hope this helps someone who has the same problem
Mar 17, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
131 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
