Question about Brady GlobalMark MultiColor (76800) Label Printer
How do we print logos using brady's global mark printer and process color ribbon
  • 4 Answers
This can only be done if you have the printer hooked to a PC. You should be able to save your logo as a image file (i.e. bmp, jpeg, gif), then use the "Insert Graphic" button in the MarkWare program, navigate to your image, select it and presto.... It WILL NOT cut out the image though. If you want it cut out you must use the multi-line tool and trace around the whole image outline.
Posted on Aug 18, 2010
I have Fargo DTC550 ID printer printing double image can someone help
Hi Arthur -
If by "double-image" you mean that you see multiple identical images printed, but each is slightly offset and appear in yellow, magenta, or cyan ink colors, then it seems like the card is slipping within the printer as it prints. These printers print 1 color at a time, with a total of 5 passes to complete 1 card image - 1 pass each for the yellow, magenta, cyan, black & clear overlay panels of a standard YMCKO ribbon. If the card doesn't get positioned properly for each new panel on the ribbon, then the subsequent image will have a slight offset to it.
The fix could be as simple as a thorough cleaning - with supplies from a Fargo dealer (like us!) that are appropriate for that model. It could also be that the printer requires a ribbon-sensor calibration. To do this, you could need to download the Fargo Workbench Utility program from the HID Global website here: (Drivers Downloads) . There is a "Printer Information" view in this utility, and then a "Test" you can run called "Ribbon Calibration" - do it regardless of the cleaning.
If still not resolved, contact us or your Fargo dealer for further support.
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Nov 17, 2017 | Fargo Office Equipment & Supplies
Print preview looks fine but just get a blank label from label mark. prints ok when not done from pc
You likely need to use Brady's software to create the label on the PC, and your PC will need the correct printer drivers to communicate with the Brady. The software and drivers should be available from Brady.
Apr 02, 2015 | Brady TLS 2200 Label Printer
I have ribbon and am using photoshop,how do i print uv with hdp5000?
To print with UV on a Fargo HDP5000 printer you first need to get a UV color ribbon: YMCFK. The part number is 84061.
After you have your UV ribbon installed you will have to load your cards and tell the printer where you want that special UV logo/design to go. The easiest way to do this is by using Asure ID Solo 7 software. This design software is made by Fargo and has a check mark box on the top where you can either turn the UV design on or turn it off depending on how you plan to create your card. Asure ID Solo 7 costs about $150 but it's very easy to use and makes the print process easier.
There is a second option which involves not using Asure ID and instead creating your UV design through Fargo's "Work Becnch". This process of creating UV designs through work bench is slow and not the most efficient but it is free.
Sep 28, 2011 | Fargo HDP5000 Thermal Printer
Hi - My Brady IDPAL says it is printing, but nothing actually prints... silence. I was reading about the "insert labels" contact issue. It not that.
Hello, this is a response from Brady's technical support team. Please try this:
The three contact pins in the printer are not making contact with the smart cell computer chip (the shiny silver pad at the bottom of each cartridge). The occurs after the printer is dropped or after shoving
cartridges in at an angle.
To remedy, remove the cartridge and look at the bottom of the cartridge opening (just above the Power button). Take tweezers or needle nose pliers and pull slightly on the pins (outward, and towards you). Please double-click and View the file below for a picture of the pins. Once these metal contacts are out far enough to make contact with the smart cell (computer chip) on the label/ribbon cartridge, the printer will know that labels are loaded.
In addition to the Insert Labels error, contacts that get pushed in can result in two other issues:
One, the printer will only print if the cartridge is pushed down
(which makes the smart cell touch the contacts).
Two, if one or two, but not all three, contacts are not all the way out, the printer may only print on half of the labels (because it is only reading some of the silver bars on the cartridge's computer chip, and narrow media activates only one or two bars, where as wide
media activates all three).
We'd be happy to help you directly if needed. Brady Technical Support at 1-800-643-8766 ortech_support@bradycorp.com. Please leave your name, and phone number or email address, if you are unable to speak to someone. Our Technical Support business hours are Monday through Friday, 6:30am to 6:30pm US Central Time.
Jun 15, 2011 | Brady ID PAL Thermal Label Printer
I looking Print head for Brady Model 1344 please find to me .
The Brady 1344 printer is really a Datamax E4304 printer with 300dpi print head. A google search will produce numerous companies selling this printhead
Hope this helps
May 15, 2011 | Brady 1344 Thermal Label Printer
Brady printer 2461 is receiving a message position fault. How can this be corrected?
If you are using die-cut and reflective media you have to perform a Positioning Calibration that sets the TOF and calculates the label length of the media. This process also calibrates the ribbon sensor on printers equipped with the thermal transfer option. To do this;
1) Turn ‘On’ and enter the media setup parameters in the Media Settings-Menu
2) Load media (and ribbon, if equipped with the thermal transfer option)
3) Calibrate the Media Sensor
4)
Press and hold the FEED key for approximately 4 seconds or until 2-3
labels advance. Upon completion, the ‘Ready’ message will be displayed.
Please ask if you need any further details.
Aug 04, 2010 | Brady 2461 Thermal Label Printer
Ribbon cut when printing a standard test card
Check for ribbon setting in driver. Run self adjustment process
Aug 03, 2010 | Evolis Dualys ID Card Printer Smart Card...
Unable to print a dark green logo?
Use Photoshop. Also their are Color Profiles you can install on you computer. n windows
Rt click an Goto properties/Settings/advanced.
THe last tab is where you can install them.
They will only allow you to match you screen to the printer color better.. Google where and what on you need.
In Card5 id I remember. There should be a setting that comes up when the print is initiated.
You should be able to set card of to control the color and not the printer. Or visa verso.
Also you can get a Solid Resin Green Ribbon.
Selvol
Jun 16, 2009 | Zebra Eltron P310 Thermal Printer
HDP600 print ribbon will not align properly. Using the diagnostics section, the color ribbon, ymckk, will not align to its correct starting point so that an accurate id card can be produced. The data is...
If card image is spread out into the yellow panel and the next magenta panel ...and so on skiping panel of the ribbon, then is defenitlly a sensor mis calibration problem. Check if you working in a place where to much natural light is present. The printer needs to detect the diffrent colors of the ribbon panels to print without skkiping them. re-calibrate the sensor. also as to "see or sense" the timing white marks on the ribbon that separates each panel.
I hope i help
ventas@intesys.org
Feb 25, 2009 | Fargo HDP600 Thermal Printer
Brady GlobalMark MultiColor (76800) Label Printer Logo
171 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
