Well yep it is,,,look at the deck first to check its not tight to turn look for sezed up bearings,,,then check that the drive belt/s are tight and not flopy and slipping also it would be a good time to check the cutting blades they need to be sharp and not blunt or they strain the belts and start them slipping too also the engine wont like the extra load put on it
Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
